P0720 code - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
post #1 of 14 Old 02-10-2009, 07:39 PM Thread Starter
swkmtnbiker
Vehicle: 1999 Dodge Dakota
Question P0720 code
I have a P0720 code causing my truck to rejected for emissions.
Changed the output sensor on the tranny and on the rear differential
reset codes but it comes back on after 15 miles per hour.
Any suggestions ??
Thanks
swkmtnbiker is offline
post #2 of 14 Old 02-10-2009, 08:22 PM
Neil
Neil's Avatar
Vehicle: 99 Durango
I can't help with what may be wrong but the 0720 is associated with the transmission sensor and not the differential sensor.
Neil is offline
post #3 of 14 Old 02-10-2009, 08:24 PM
Neil
Neil's Avatar
Vehicle: 99 Durango
Is your speedo working below 20 mph and are or have the ABS and Brake light been on?
Neil is offline
post #4 of 14 Old 02-10-2009, 08:29 PM
johncs78
what did you say??!!!
johncs78's Avatar
Vehicle: 1999 Durango 4WD 5.9
Send a message via Yahoo to johncs78
according to my book and my code scanner - flash code #15 OBD - 0720 = low output speed sensor , RPM above 15 mph , side notes = output shaft speed is less than 60 rpm with vehicle speed above 15mph"
....maybe something else is going on with the wiring...chase the wires.....just a thought...
"If it has wheels, tubes or boobs...... You're going to have problems with it"
D.O.G.S Member # 42 "TROPHY DOG"
johncs78 is offline
post #5 of 14 Old 02-10-2009, 09:57 PM Thread Starter
swkmtnbiker
speed o is working fine and there have been no abs or brake light problems.
I figured it was the tranny sensor and changed that one first.
I need to check the wires as johncs78 suggests.
Thanks for the response's
post #6 of 14 Old 08-22-2009, 03:47 AM
Barbequepork
Vehicle: 1998 Durango SLT
I have the same error code(P0720) and the ABS and Brake lights come on randomly...I am comfortable working on my car but not sure where everything is and usually use the boards "How to" posts with pics...can someone lend some assistance(pictures..etc) on how to replace the vehicle speed sensor (VSS) on the drivers side of the tranny tail shaft...I have no idea what that looks like..
I wanted to try the method from this post http://www.dakota-durango.com/forum/...ighlight=p0720 but not successful in locating what I need...
Thank you in advance for the responses.
Barbequepork is offline
post #7 of 14 Old 10-22-2009, 10:47 PM
RJ_Hythloday
99 Durango 5.9 part out
RJ_Hythloday's Avatar
Vehicle: 99 Durango R/T
Modifications: 360,heads,cam,headers-full exh,sct
BBQ I'm guessing you must have taken care of this by now. I just got the code and am going to go get out the haynes manual, lmk if you need a description.
RJ_Hythloday is offline
post #8 of 14 Old 10-22-2009, 10:57 PM
Barbequepork
I took it in to get it fixed but would like to know anyway
Thanks!!
post #9 of 14 Old 10-23-2009, 04:31 AM
CBH
Vehicle: 1998 Dakota Sport
I just replaced mine. It is on the drivers side bottom of the tranny. It is molded plastic (even the tightening nut) and has an electrical plug with 2 small pins in it. It is not real tight in the tranny, and you want to be careful when you snug up the new sensor. Put a pan under it to catch the fluid, and have the new plug in your hand so that you can put it in quickly! Advance Auto has them for $17.99.
CBH is offline
post #10 of 14 Old 10-23-2009, 10:00 PM
Barbequepork
I guess I'll be trying to fix it myself...got quoted by Dodge $148 to fix...picture if possible?
I'll have to search the forum to find out how to reset the error after I fix
post #11 of 14 Old 10-24-2009, 01:14 AM
Neil
Neil's Avatar
Vehicle: 99 Durango
After you fix it the code will clear or disconnect the negative battery cable and turn it to on for 30 seconds
Neil is offline
post #12 of 14 Old 11-05-2009, 05:16 AM
Barbequepork
Thank you for the assistance everyone, I was able to change the sensor and reset the engine light.
post #13 of 14 Old 11-05-2009, 05:00 PM
RJ_Hythloday
wow, that's a raping for a $16 part and 2 minutes under the truck.
post #14 of 14 Old 03-06-2014, 01:58 AM
Robbins
Mopar or No Car
Robbins's Avatar
Vehicle: 2002 Dodge Dakota SXT
Modifications: Nothing
Just had this come on in 02 Dakota while spinning my tire coming in to mu shop.
1964 Valiant 340/833/8 3/4---1982 SWB 2WD 318/833OD/8 3/4
1986 RC 2WD 1 ton 440/518/9 3/4---2002 Dakota SXT 2WD 3.9 Auto
2005 Chrysler Town & County 3.3
Robbins is offline
