head gasket - Dakota Durango Forum
post #1 of 4 Old 01-30-2009, 05:18 AM Thread Starter
01_Durango
01_Durango's Avatar
Vehicle: 2001 Dodge Durango
Send a message via AIM to 01_Durango
head gasket
how hard of a job will it be to change the head gasket on a 2000 4.7 durango
FIVE DOOR WHORE #90
2001 Durango R/T
2002 Durango R/T Sold
2001 Durango Slt ***SOLD***
01_Durango is offline
post #2 of 4 Old 01-30-2009, 03:57 PM
razman131
Home Owner....
razman131's Avatar
Vehicle: 1999 Dakota R/T
Modifications: to many to list, plus standard bolt ons and suspension mods.
Send a message via Yahoo to razman131 Send a message via Skype™ to razman131
hard to say as the 4.7 has been pretty much trouble free from what ive seen and heard.
most people that have probs with it end up doing a swap vice repair. if your good with tools and have access to a lift, pull it and work it on a stand. only prob i see is the cams and chain(s).
1999 Dakota R/T (mild to heavy mod)
2006 Magnum SRT8 (not *yet* modded)
2004 Dodge Caravan SXT.... Momy Mobile
BEATER: 1991 Honda Civic DX 4dr
razman131 is offline
post #3 of 4 Old 01-30-2009, 04:18 PM
02SLTQC4.7
Mods Addict
Vehicle: 89 Ford Probe GT Turbo
ya OHC are a pita to change head gaskets on you ahve to really carefull not to throw the timming off
02SLTQC4.7 is offline
post #4 of 4 Old 01-30-2009, 09:02 PM
1reddurango
What tha duece?!
1reddurango's Avatar
Vehicle: 2000 Durango SLT 4.7L
I recently did mine. Its a real pain in the a$$. The headbolt under the brake booster is impossible to torque. Do not remove the center timing chain. Make sure you check your chain guides(PLASTIC) and tensioners as these are prone to breaking and sticking respectively. The gasket between your chain cover and the block is $70....replace it. Replace your waterpump gasket too. Make sure you set everything up at top dead center BEFORE you tear it down and try not to rotate the motor when you are pulling the front pulley. Also, there is a special puller for the front pulley. Autozones loaner tool program is the $hit, tell them you need the pulley puller for late model Dodges.. You might as well change your plugs, oil, filter, thermostat while you are at it as you will get a little water in the crank case when you pull the heads off the block. Take the whole head with cams and lash adjusters/ rockers to a good machine shop to be resurfaced. Have the valve stem seals replaced and let them reinstall the cams and stuff. Its much easier that way. Check your fan clutch since it will be off and replace it if necessary. Consider replacing your water pump too. Just a little extra insurance. I was getting a huge amount of water in cylinder # 1 and 3 in my 2000 Durango. Good luck and have lots of gause on hand as you will bust a couple of knuckles!!
"USAF weapons; Giving the enemy the opportunity to die for his country" "
5 Door Whore #68, I owe you one...
1reddurango is offline
