4x4 light - Dakota Durango Forum
post #1 of 16 Old 01-15-2009, 08:43 PM Thread Starter
sabrefan68
sabrefan68's Avatar
Vehicle: 98 Dakota SLT 4x4 5.2
4x4 light
when my 4 wheel is engaged, should there be a light on the dash letting me know it's on? was out in the snow last nite and had to feel the shifter to see if i had it engaged, too dark to see it.
sabrefan68 is offline
post #2 of 16 Old 01-15-2009, 10:13 PM
caulk04
Vehicle: none
Yeah, there should be a light. Not sure if you should look for the bulb to be out or the sender.
caulk04 is offline
post #3 of 16 Old 01-15-2009, 10:37 PM
muddigger4x4
MUDDIGGER
muddigger4x4's Avatar
Vehicle: 1999 Dodge Durango 5.9L
Modifications: opened exhaust slightly future change coming
Send a message via Yahoo to muddigger4x4
yea i was wondering the same, mine doesnt work eather, but im thinking the trani has been changed (because of the shifter being off) dunno if they hooked this back up
RIP 5.9L Magnum
5 door whore #155
muddigger4x4 is offline
post #4 of 16 Old 01-15-2009, 10:53 PM
HemiDak
Mods Addict
Vehicle: ​
The switch on your transfer case isn't working like it should anymore. This is the common reason for the lights to stop working.
HemiDak is offline
post #5 of 16 Old 01-15-2009, 11:15 PM
durangoranchero
durangoranchero's Avatar
Vehicle: 72 ford ranchero 500
Different issue, but sometimes when I put mine into part time, or 4 all the time, when I want to get out of it, the light does not want to turn off. I read in the manual that you have to go in and out of four at certain speeds with the tranny in neutral. Could my switch be worn out, or out of alignment if that is possible. Or is it something not to worry about, because eventually the light goes out.
Dave
Da rides
Durango-totaled
durangoranchero is offline
post #6 of 16 Old 01-15-2009, 11:18 PM
HemiDak
Mods Addict
Vehicle: ​
That's true only for 4lo.
HemiDak is offline
post #7 of 16 Old 01-15-2009, 11:28 PM
schusterjo
schusterjo's Avatar
Vehicle: 99 Durango 5.2L
Mine works sometimes and sometimes it don't... I simply make a turn if it is not on to know if it is in 4wd or not.
schusterjo is offline
post #8 of 16 Old 01-16-2009, 03:42 AM Thread Starter
sabrefan68
sabrefan68's Avatar
would it be wise to check the dash light first or is just look for the switch? is this a dealer part or any parts store stock them ? and thanks for the quick replies as usual
post #9 of 16 Old 01-16-2009, 07:23 AM
HemiDak
Mods Addict
Vehicle: ​
The odds of the dash light going out are low, as the lulb is LED, and they have a life-span much greater than your truck has. I'm not sure if auto parts stores have them, but I'm sure most local dealers have them.
HemiDak is offline
post #10 of 16 Old 01-16-2009, 08:06 AM
AKpirate
AKpirate's Avatar
Vehicle: 99 dodge durango/ 03 neon
X2
Mines been out so long I dont even care thats its gone now ...just look down or reach for it if its dark like what was said.
car domain site
5 door whore #11
AKpirate is offline
post #11 of 16 Old 01-17-2009, 02:54 AM
R/Tdurango02
Ford Recovery Vehical
R/Tdurango02's Avatar
Vehicle: 02 Durango R/T
Modifications: CAI Taylor 8mm Spiro Pro wires Bosch Platinums Accel cap & rotor
This is good to know, my fiances 98 rango, the light wont come on if the truck is running but if its off with the key on it comes on just fine. Do you think its the sender for this as well
5 DOOR WHORE # 132
R/Tdurango02 is offline
post #12 of 16 Old 01-17-2009, 05:55 AM
HemiDak
Mods Addict
Vehicle: ​
In all honesty, I have no idea why that is.
HemiDak is offline
post #13 of 16 Old 01-17-2009, 05:14 PM
muddigger4x4
MUDDIGGER
thats a little odd, sounds almost like when my headlights wouldnt turn on if the engine was running , it seemed to fix itself on that though :|
RIP 5.9L Magnum
5 door whore #155
post #14 of 16 Old 01-17-2009, 06:41 PM
trevor
Vehicle: Null
I know mine is 'burnt out' as I replaced the switch on the t-case and it still doesnt come on. (the original switch was bad as well) I'm not going to bother switching the bulb, as I know when it is in 4x4.
A good sharp edge is a man's best hedge against the vague uncertainties of life.
trevor is offline
post #15 of 16 Old 01-17-2009, 08:27 PM
natesimpson74
Vehicle: 1999 Dodge Dakota Sport
What you should do is go under your truck and unplug the connector that is on the top of the transfer case. Stick a paper clip in one of the two holes in the connector and touch it to a GOOD ground on the truck. If the light goes on it is the sensor, if it doesn't it is either the bulb or wiring. If I remember right the left side of the connector will turn on the LOW light and the right side will turn on the 4x4 light.
natesimpson74 is offline
