starts then dies then no start! - Dakota Durango Forum
post #1 of 16 Old 01-04-2009, 09:31 PM Thread Starter
MadMike
Modifications: CAI, Full Exhaust, Superchips
so my dad's 2000 dakota r/t just started up then while he was backing out of the driveway it died. now if you try to start it will turn over normal but not crank just like if someone had disabled the ignition. also the digital odo reads "no bus" now.
BTW
this has been a on going issue. the truck has a new battery and I replaced a cable that was damaged about a week ago.
MadMike is offline
post #2 of 16 Old 01-04-2009, 09:47 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 188 Post(s)
Could be one of a few things. Either the BCM is freaking out and killing the ignition, the guage cluster took a shit(no bus), or the PCM took a shit.
hskrRT is offline
post #3 of 16 Old 01-04-2009, 09:48 PM Thread Starter
MadMike
alright just noticed that when turning the key to the on position there is no noise coming from the fuel pump like you usually would hear.
MadMike is offline
post #4 of 16 Old 01-04-2009, 10:02 PM Thread Starter
MadMike
just to see if it would connect I hooked up his superchips tuner and it said it couldn't detect ignition on. also i checked the relay and its good.
is there anything at all this could be besides the pcm?
MadMike is offline
post #5 of 16 Old 01-05-2009, 01:01 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 188 Post(s)
Might want to try swapping out the fuel pump relay with one of the other relays in the PDC under the hood.
hskrRT is offline
post #6 of 16 Old 01-05-2009, 01:23 AM
txndak4x4
txndak4x4's Avatar
Vehicle: 2001 Dakota CC 4.7L 4x4
Modifications: Superchips 3715, Cold Air Intake
Try unplugging the PCM harness and wating about 30 seconds, then plug it back in. If the truck starts up, its your pcm taking a dump. The "NO BUS" means there is no communication to the pcm. I just went through this myself.
______________
-Superchips 3715 -UWS Toolbox
-Cold Air Intake -T/B Lift
-Flow 40 Dumped -265/75R16
General Grabber AT2's
txndak4x4 is offline
post #7 of 16 Old 01-05-2009, 03:01 AM
caulk04
Vehicle: none
Not sure how it works on the 5.9 PCM, but I've seen a few 4.7 trucks show 'NO BUS' when the crank sensor went bad.
Do try resetting the PCM first, it's free and you never know when some Bill Gates shit is gonna strike
caulk04 is offline
post #8 of 16 Old 01-05-2009, 11:26 PM Thread Starter
MadMike
did that and the relay was good when I swapped it with the flashers relay. flashers worked but still no pump activity.
my dad emailed this to me to explain it a little more in depth.
Michael,
Could you post this on www.dakota-durango.com ....?
2000 Dodge Dakota 5.9L R/T Club Cab having starting & or charging problems. Initial & all start ups barely able to turn the starter over and resets the radio clock memory. Starter builds speed to normal and starts the engine but occasionally will not hold Idle and stalls. You can manually keep the engine running smoothly with the gas pedal and slowly bring it down to normal idle. Then the truck drives like normal. Initial hook-up of the digital charger shows the battery at 40 to 60 % charge. And 2 amp trickle charging the 2 1/2 year old Optima Red top battery fully takes 4 to 6 hours & seams to correct the problem for a day. Volt gauge in the dash indicates charging to be 14 - 14.5 Volts weather the battery has been charged or not. Disconnecting the positive lead from the battery terminal while running does not kill the engine. The truck is a daily driver but only for 15 minutes of stop & go to 45 mph driving to and from work with the lights on.
Battery check out bad and was replaced with a new Optima Red top Thursday. Truck started and ran fine until Sunday. Then started and drove 20 feet and died like the switch was turned off. When trying to restart engine turned over fine but would not start and "no bus" replaced the digital odometer reading on the dash. I also didn't hear the fuel pump running. Over the next few hours I tried it again several times with no change. Then checked the wiring connectors to the PCM by making sure they were not loose. Everything seemed OK, tried starting it again and it started fine. Pulled it back into the driveway and left it running while I went to get my cell phone. When I returned in a few seconds it had stopped running again but restarted fine. So I moved it back out to the street and parked it. Later I started it and drove it 15 min. to get gas and back with no problems. Any Ideas? I have not checked the alternator or the charge on the battery.
I am taking it to Big "O" Dodge for a diagnostic tomorrow....If it will make it there.
MadMike is offline
post #9 of 16 Old 01-06-2009, 03:59 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 188 Post(s)
Might be a bad ground from the battery swap. Check to make sure all the terminals are tight, and that the ground wire going to the fender behind the battery is tight as well.
hskrRT is offline
post #10 of 16 Old 01-07-2009, 02:13 AM Thread Starter
MadMike
email from my dad
Michael,
I picked up the truck & they said it did show any codes & that then charging system was working fine. The truck drove fine back to work. Then I checked the codes by turning the the key on & off 3 times and it displayed a code p-0702. Then -------, Then p-done. I called the service assistant at the dealership and asked him to find out what that code is from the service tech. He said he would call me back when he found out. That was at 5:00. I'm betting he doesn't call me back. If you don't mind see if someone on the forums can tell us what it is. Wait a minute he just called and said they don't have a code p-0702. He said they have a 700 for the transmission controller & then it goes to 1100. He did say it had a stored code for a trans speed sensor but didn't know the code number. He went on to say the scan showed nothing for the no-bus or not starting. Go figure!.... See if you can find out anything when you can.
Thanks,
Dad
MadMike is offline
post #11 of 16 Old 01-07-2009, 02:25 AM
caulk04
Vehicle: none
Is there a parasitic drain on the battery when the truck is off? Use a multimeter to test for draw from the battery post to terminal (remove the terminal, obviously).
Sounds like classic dead battery issues to me, be it a bad battery or one that's getting killed.
caulk04 is offline
post #12 of 16 Old 01-07-2009, 09:52 AM
muddigger4x4
MUDDIGGER
muddigger4x4's Avatar
Vehicle: 1999 Dodge Durango 5.9L
Modifications: opened exhaust slightly future change coming
Send a message via Yahoo to muddigger4x4
this sort of sounds like my problem, i went out and wiggled the wires on the computer on the pass. fender and it started right up.......wonder, bad/dirty connectors?
RIP 5.9L Magnum
5 door whore #155
muddigger4x4 is offline
post #13 of 16 Old 01-07-2009, 11:03 AM
Flat Black
Flat Black's Avatar
Vehicle: 1987 Dakota, 1989 Dakota
Might want to check and see if all connectors are in their correct place. I dont mean switch around but every now and the one can get moved back and not get a complete connection. Also a little dialectric grease helps to keep out any moisture that may get in there and mess up a signal. Before using that get some contact cleaner, spray it out then add the grease.
Have fun, Drive safe and watch for motorcycles.
1987 Gen 1 long bed.
Going for the chopped,dropped, and cropped look!
Flat Black is offline
post #14 of 16 Old 01-14-2009, 10:09 AM
Altair
Mods Addict
Vehicle: 2001 Dodge Durango R/T
Modifications: Ram Air II hood.
Send a message via Yahoo to Altair
If you are not using the factory programmed key or the chip inside the key goes bad won't your engine start but die when you try to drive it? After so many tries would it then lock out the ignition? Just wondering. What year did the programmed keys come out?
Altair is offline
post #15 of 16 Old 01-14-2009, 03:23 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 188 Post(s)
2001 was the first year for the SKIM key you are refering to. He has a'00.
hskrRT is offline
