Dead engine - Dakota Durango Forum
post #1 of 13 Old 12-19-2008, 02:35 AM Thread Starter
Launderman
Vehicle: Dakota Supercab 2002
Dead engine
My engine went dead (2002 4.7l 4x4 Dakota), a read code P1389, after reading the forums I checked all relays at the box next to the battery and all are OK. I injected starting fluid at the throttel body and the engine started momentarily. I don't know if this has to do too but the speedometer went to 120mph, all other instruments are ok. I erased the code, attempted to start the engine again and code P1389 appears again.Any idea????
Launderman is offline
post #2 of 13 Old 12-19-2008, 06:55 AM
mthandt
mthandt's Avatar
Vehicle: 2002 Dakota QC
Modifications: K&N 77 series,Superchips 3715.
Send a message via AIM to mthandt Send a message via Yahoo to mthandt
P1389 No ASD Relay Output Voltage At PCM No Z1 or Z2 voltage sensed when the auto shutdown relay is energized.
P1389 (M) No ASD Relay Output Voltage At PCM An open condition detected in the ASD relay output circuit.
IDK what that means but I thought I would post it up. Sorry I can't help more.
My truck is cool.
mthandt is offline
post #3 of 13 Old 12-19-2008, 07:54 AM
atvrider07
atvrider07's Avatar
Vehicle: 00 Durango
Quoted: 2 Post(s)
maybe the PCM took a crap on ya
2000 Durango 4.7 4x4
atvrider07 is offline
post #4 of 13 Old 12-19-2008, 08:51 AM
Flat Black
Flat Black's Avatar
Vehicle: 1987 Dakota, 1989 Dakota
Dodge Trouble codes
This is what Ive found
Dodge / Chrysler / Jeep Specific Trouble CodesCode Description
P1192 Inlet Air Temp. Circuit Low
P1193 Inlet Air Temp. Circuit High
P1195 1/1 O2 Sensor Slow During Catalyst Monitor
P1196 2/1 O2 Sensor Slow During Catalyst Monitor
P1197 1/2 O2 Sensor Slow During Catalyst Monitor
P1198 Radiator Temperature Sensor Volts Too High
P1199 Radiator Temperature Sensor Volts Too Low
P1281 Engine Is Cold Too Long
P1282 Fuel Pump Relay Control Circuit
P1283 Idle Select Signal Invalid
P1284 Fuel Injection Pump Battery Voltage Out Of Range
P1285 Fuel Injection Pump Controller Always On
P1286 Accelerator Pedal Position Sensor Supply Voltage Too High
P1287 Fuel Injection Pump Controller Supply Voltage Low
P1288 Intake Manifold Short Runner Solenoid Circuit
P1289 Manifold Tune Valve Solenoid Circuit
P1290 CNG Fuel Pressure Too High
P1291 No Temp Rise Seen From Fuel Heaters
P1292 CNG Pressure Sensor Voltage Too High
P1293 CNG Pressure Sensor Voltage Too Low
P1294 Target Idle Not Reached
P1295 No 5 Volts To TP Sensor
P1296 No 5 Volts To MAP Sensor
P1297 No Change in MAP From Start To Run
P1298 Lean Operation At wide Open Throttle
P1299 Vacuum Leak Found (IAC Fully Seated)
P1388 Auto Shutdown (ASD) Relay Control Circuit
P1389 No Auto Shutdown (ASD) Relay Output Voltage At PCM
P1390 Timing Belt Skipped One Tooth or More
P1391 Intermittent Loss of CMP or CKP
P1398 Mis-Fire Adapter Numerator at Limit
P1399 Wait To Start Lamp Circuit
P1403 No 5 Volts To EGR Sensor
P1475 Aux. 5 Volt Output Too High
P1476 Too Little Secondary Air
P1477 Too Much Secondary Air
P1478 Battery Temp Sensor Volts Out of Limit
P1479 Transmission Fan Relay Circuit
P1480 PCV Solenoid Valve
P1482 Catalyst Temperature Sensor Circuit Shorted Low
P1483 Catalyst Temperature Sensor Circuit Shorted High
P1484 Catalytic Converter Overheat Detected
P1485 Air Injection Solenoid Circuit
P1486 Evap Leak Monitor Pinched Hose
P1487 Hi Speed Rad Fan CTRL Relay Circuit
P1488 Auxiliary 5 Volt Supply Output Too Low
P1489 High Speed Fan CTRL Relay Circuit
P1490 Low Speed Fan CTRL Relay Circuit
P1491 Rad Fan Control Relay Circuit
P1492 Battery Temperature Sensor Voltage Too High
P1493 Battery Temperature Sensor Voltage Too Low
P1494 Leak Detection Pump Switch or Mechanical Fault
P1495 Leak Detection Pump Solenoid Circuit
P1496 5 Volt Supply Output Too Low
P1498 High speed Rad Fan Ground CTRL Rly Circuit
P1594 Charging System Voltage Too High
P1595 Speed Control Solenoid Circuits
P1596 Speed Control Switch Always High
P1597 Speed Control Switch Always Low
P1598 A/C Pressure Sensor Volts Too High
P1599 A/C Pressure Sensor Volts Too Low
P1602 PCM Not Programmed
P1680 Clutch Released Switch Circuit
P1681 No I/P Cluster CCD/J1850 Messages Received
P1682 Charging System Voltage Too Low
P1683 Speed Control Power Relay Or Speed Control 12 Volt Driver Circuit
P1684 Battery Disconnected Within Last 50 Starts
P1685 Skim Invalid Key
P1686 No SKIM Bus Message Received
P1687 No Cluster Bus Message
P1688 Internal Fuel Injection Pump Controller Failure
P1689 No Communication Between ECM & Injection Pump Module
P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
P1691 Fuel Injection Pump Controller Calibration Failure
P1693 DTC Detected In ECM Or PCM
P1694 No CCD Messages Received From ECM
P1695 No CCD/J185O Message From BCM
P1696 PCM Failure EEPROM Write Denied
P1697 PCM Failure SRI Mile Not Stored
P1698 No CCD Messages Received From PCM
P1719 Skip Shift Solenoid Circuit
P1740 TCC Or OD Solenoid Performance
P1756 Governor Pressure Not Equal To Target At 15–20 PSI
P1757 Governor Pressure Above 3 PSI When Request Is 0 PSI
P1762 Governor Pressure Sensor Offset Improper Voltage
P1763 Governor Pressure Sensor Voltage Too High
P1764 Governor Pressure Sensor Voltage Too Low
P1765 Trans 12 Volt Supply Relay Control Circuit
P1899 Park/Neutral Position Switch Stuck In Park or In Gear
Have fun, Drive safe and watch for motorcycles.
1987 Gen 1 long bed.
Going for the chopped,dropped, and cropped look!
Flat Black is offline
post #5 of 13 Old 12-19-2008, 01:36 PM
flyboy121785
Vehicle: 2002 Durango SXT 4.7L
ASD relay, automatic shutdown. Shuts down the engine in extreme instances. Replace it and see what happens.Could be a 15 dollar fix
flyboy121785 is offline
post #6 of 13 Old 12-19-2008, 01:57 PM
bwdakrt
Posts: n/a
Quoted: Post(s)
Just exchange the ASD relay with the fan relay and see if it fires up. If it does, then you know you have to get a new relay. If it don't, then you know you have other problems.
post #7 of 13 Old 12-19-2008, 10:01 PM Thread Starter
Launderman
I can't identify the asd relay but I tested all with the fog lamp circuit and the are all ok. I found a pink square fuse blown 30amp, changed it and the engine started. At idle it seems ok, very smooth, but if you try to rev, it will begin to knock and do a very rough aceleration as if a couple cylinder were not working, let it idle again and will come smooth again. I erased all codes and got the same p1389 along with 352 353 and a couple more.....
post #8 of 13 Old 12-20-2008, 12:10 AM
caulk04
Vehicle: none
0352 and 0353 should be injector malfuction codes IIRC. Could be clogged, I'd not think it's an electrical problem since it idles ok.
caulk04 is offline
post #9 of 13 Old 12-20-2008, 12:11 AM
caulk04
Vehicle: none
Also, check over your engine/chassis ground thoroughly, I wonder if something got shorted and blew that fuse which may have also broken a ground connection.
Reset the PCM as well, never hurts. Pull the connectors off the PCM for a couple min, then reinstall.
caulk04 is offline
post #10 of 13 Old 12-20-2008, 05:27 AM
Turbo47
Vehicle: 2003 4.7 / 1995 GT-R
I'd check the power supply wire to the coils/injectors for a short. It is the green wire with a red stripe. That is the 12+ volt ASD circuit, it provides power to the coils and injectors. Sounds like something might be shorted out. If you cannot find a short, I'd test the resistance of each injector and coil. IIRC, the injectors are 12ohm and the primary coil winding is 2ohm.
Turbo47 is offline
post #11 of 13 Old 12-20-2008, 05:09 PM
scjeep4.7HO
scjeep4.7HO's Avatar
Vehicle: 97 dakota, 04 G. cherokee
Modifications: 2004 Grand Cherokee. Supercharged 4.7L HO, cammed. meth injected, SCT tuned, 72mm F&B throttle body, 180* T stat, Magnaflow exhaust, Trans go shift kit W/ deep trans pan.
Pull all your plugs and make sure they are not messes up which would be an indication of a bigger problem obviously. Change them if nescessary. Like they said run some good gas with cleaner like seafoam through it. See if it gets better.
Paxton NOVI 2000 supercharged Jeep 4.7L HO, Cammed, Heads, Built Motor, Custom COG supercharger drive sysem, Custom ATI dampner w/ custom cog pulley, Both Sheet metal intake or stock intake, Turbo Smart race port BOV, 72mm F&B throttle body, Meth injected, SCT tuned, 60# injectors, Billet fuel rails, full Fuel system, True dual Exhaust W/Magnaflows, Iridium plugs, Built Transmission W/Trans-Go shift Kit, Deep trans pan W/Trans cooler, 180* T stat, 275 60 R17 rubber, ETC....
scjeep4.7HO is offline
post #12 of 13 Old 12-21-2008, 03:48 PM
Jecht
Mods Addict
Jecht's Avatar
Vehicle: 03 Dakota QC
how long have you let the engine set before getting it fixed to fire up. I know on my ranger I had. I let it set for a week and it had a heck of a rough idle and after running it up and down the road it finally blew out whatever built up in the engine.
Jecht is offline
post #13 of 13 Old 12-23-2008, 05:56 AM
N-gin
N-gin's Avatar
Vehicle: 2002 Dodge Durango
Modifications: K+N, tornado, Stereo system, raamat insulation
ont believe that if the fuse sends the signal to the injectors cause he said tha the fuse was blown, and he also said that he injected starting fluid had stared momentarily.
One thing is for sure is that fuses just dont blow for no reason.
If it idles fine and it has hard time accellerating, also if it knocks or "cackles" upon throttle, then do a fuel psi test.
N-gin is offline
