Check Engine light- p0420- Cat replaced twice! - Dakota Durango Forum
post #1 of 12 Old 12-08-2008, 12:33 AM Thread Starter
scn
Vehicle: 2002 Durango
Hi everyone,
I have had my catalytic converter replaced twice and both O2 sensors as well.
I keep getting a P0420 (cat converter below efficiency threshold) code, but everything that needs to be replaced has been replaced.
I have a Magnaflow cat, not OEM, and a shop told me I should replace it with OEM or CarSound brand. What if this doesn't work? They say the high flow Magnaflow isn't efficient enough.
Thanks
scn is offline
post #2 of 12 Old 12-08-2008, 12:34 AM
dak-rt-2a-XR
Hemi Powered
dak-rt-2a-XR's Avatar
Vehicle: SRT8 and an R/T
third time is a charm
'08 Charger SRT8 6.1 Hemi with extensive modifications
'11 Durango R/T 5.7 Hemi daily driver
dak-rt-2a-XR is offline
post #3 of 12 Old 12-08-2008, 12:53 AM
Dakudaman
Big mouth heavy foot
Dakudaman's Avatar
Vehicle: '98 Dakota R/T CC
Modifications: Going Fast
Put in a simulator and be done with it!
April '08 TOTM
The BLUE BEAST!SOLD
Dakudaman is offline
post #4 of 12 Old 12-08-2008, 01:53 AM
AmberFireDaK
AmberFireDaK's Avatar
Vehicle: 2000 Dakota R/T
Quoted: 2 Post(s)
Send a message via MSN to AmberFireDaK
Some high flow cats just don't work well enough.... what part # did you get? From what I've heard Carsound cats are the same as Maggies
- Justin
AmberFireDaK is offline
post #5 of 12 Old 12-12-2008, 12:23 AM
oldskooloutlaw
oldskooloutlaw's Avatar
Vehicle: 1997 Dakota slt club cab
Modifications: Stock as a rock except cold air kit and headers
Send a message via Yahoo to oldskooloutlaw
I have had 5 cats replaced while under warranty but I had a generic hi flow put on about 4 or 5 years ago with no problems since. Maybe I got lucky or Dodge used genuine junk brand cats I dunno.
"If I can't have fun I won't play"
oldskooloutlaw is offline
post #6 of 12 Old 12-12-2008, 01:57 AM
Five9Dak
Blown and Squirted
Vehicle: 99 Dakota R/T Reg Cab
Send a message via AIM to Five9Dak
Tie the rear most O2 to the framerail, reset your pcm.
'99 R/T- MSIIextra fuel/spark/idle, ZCP mx422 supercharged, ZCP Tbrake 727, PPC 9" 3000, 4.10, (\/) Headers, 2.5" Duals, Truetrac, Boyd Timeless 6's, Hotchkis TVS.
Z Code Performance Website
Five9Dak is offline
post #7 of 12 Old 12-12-2008, 02:46 AM
oldskooloutlaw
Thanks
post #8 of 12 Old 12-25-2008, 01:04 PM
BYTRT
BYTRT's Avatar
Vehicle: 2000 DODGE DAKOTA CC R/T
JUST CURIOUS WHAT DO YOU MEAN BY TYING THE REAR MOST O2 SENSOR TO THE FRAME RAIL. I HAVE CHANGED OUT BOTH O2 SENSORS AND AM STILL GETTING THAT SAME DAMN CODE. I CHECKED MY CAT AND IT SEEMS TO BE OK. I AM BEGINNING TO WANDER IF HAVING A 180 TSTAT MIGHT BE THE PROBLEM.
BYTRT is offline
post #9 of 12 Old 12-31-2008, 05:23 PM
bjamick
bjamick's Avatar
Vehicle: 2002 dodge durango
I also have this code, im thinking of just gutting the cat and going with a simulator and resetting the computer.
bjamick is offline
post #10 of 12 Old 12-31-2008, 05:33 PM
Duner
Turbo Dakota Junkie
Vehicle: '00 4.7 CC, '99 RT RC
Modifications: Motorsports
If you remove the O2 sensor after the cat and tie it to the frame rail, it will always be happy about reading "cleaner" air than the O2 sensor before the cat. No need for a sim.
Duner is offline
post #11 of 12 Old 12-31-2008, 06:57 PM
N-gin
N-gin's Avatar
Vehicle: 2002 Dodge Durango
Modifications: K+N, tornado, Stereo system, raamat insulation
DO you have access to a scan tool that can read running data?
If so look forr the front O2 sensors changing from .900 - .125 at least 6 times in 5 seconds.
The downstream O2 should read between .750-.400 .
I have seen people use a anti fowler for spark plugs on the downstream O2. All you have to do is drill the center out to fit the O2 tip. This takes the Tip of the O2 away from direct contact with the exhaust gasses and tricks the O2 to read slower and more neutral. Thus haveing the computer think every thing is OK.
2002 Durango and two 2005 neons, not pictured 95 s10 pickup, 91 chevy balzer 6.2 diesel banks turbo, 99 chevy s10.
Durango has 3.92 gears tracloc, tornado, K&N, sound system.
Blue neon has highend sound system and fiberglassed trunk for sub.
N-gin is offline
post #12 of 12 Old 12-31-2008, 10:57 PM
caulk04
Vehicle: none
Is the cat the right size? Magnaflow/Carsound (same company) has all of their cats listed for a given engine size, don't want to go overboard.
caulk04 is offline
