A/C compressor always running? - Dakota Durango Forum
post #1 of 10 Old 12-06-2008, 05:04 PM Thread Starter
scarface
Vehicle: 1999 Dakota/2005 Durango
Send a message via AIM to scarface
on my 99 Dakota whenever the HVAC is on any position other than off the compressor cycles? Is this normal?
If it isnt, any ideas how to stop it? My gas milage is poor with the 5.2 to start with, this cant be helping.
Thanks
-Dave
scarface is offline
post #2 of 10 Old 12-06-2008, 07:15 PM
70Cuda383
Don't be "That Guy"
70Cuda383's Avatar
probably not normal. I think the HVAC switch is a vacuum switch since it's primary function is to control which vents are open/closed which all operates off engine vacuum. maybe there's a vacuum operated relay that's stuck closed, turning the compressor on all the time?
70Cuda383 is offline
post #3 of 10 Old 12-06-2008, 08:14 PM
GWhaley
Vehicle: 2001 Dakota Q.C.
Does it run all the time? Or does it just cycle every so often....... if it runs all the time, then you could have either a bad ambient air temp sensor,switch. etc. Could be as simple as a bad ground (bad grounds wreak absolute havoc with electrical systems. You could also have a stuck relay (which i would check first).......if it is cycling all the time on you, then pull the A/C compressor clutch relay out of the power distribution box for the time being.
on a side note, most systems are designed now to cycle when you put the HVAC into defrost mode, to help eliminate dried out seals and seized up compressors due to lack of use in winter months.....
GWhaley is offline
post #4 of 10 Old 12-06-2008, 08:24 PM
Dakudaman
Big mouth heavy foot
Dakudaman's Avatar
Vehicle: '98 Dakota R/T CC
Modifications: Going Fast
On your vehicle this is normal it only cycles when it needed for temp correction. It is also on with the heater to keep your windshield from fogging up!
Don't worry just drive that bitch! LOL!
April '08 TOTM
The BLUE BEAST!SOLD
Dakudaman is offline
post #5 of 10 Old 12-06-2008, 09:18 PM Thread Starter
scarface
so it should cycle all the time whenever the HVAC switch is on? it cycles every 10-20 seconds regardless of outside temps.
Its not really hurting anything, I was just curious. I only has 60k on her, and I try and keep up with everything that may be going wrong.
scarface is offline
post #6 of 10 Old 12-06-2008, 09:21 PM
Dakudaman
Dakudaman's Avatar
This is correct my friend!
April '08 TOTM
The BLUE BEAST!SOLD
post #7 of 10 Old 12-07-2008, 04:21 PM
70Cuda383
Don't be "That Guy"
70Cuda383's Avatar
sort of....
it's not to prevent seals from drying out from non-use, its to dry the air out so you're blowing dry air onto the windshield which helps pull the water vapor (fog) off the glass.
you know how in the summer time your AC drips water out? that's because the air blowing over the cold coils cools the air down, and any water in the air will condense, fall out of the air and form water drops that eventually drip out onto the ground, giving you cold dry air. this air then goes over the heater core and heats back up. now you have hot dry air to help defrost/defog your windows in the cold winter months. the heat helps melt any ice that formed on the outside, but the dry air blowing on the inside helps keep the water vapor that forms fog on the inside of your window clear. this fog comes from your breathing, rain that dries off your coat when you get inside, snow on your shoes that melts and evaporates into the air, etc.
post #8 of 10 Old 12-08-2008, 09:33 PM Thread Starter
scarface
Sweet! I love it when stuffs not broken.... now if my 05 durango wasnt such a POS...lol
scarface is offline
post #9 of 10 Old 12-09-2008, 01:49 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
Little Blue Guy is offline
post #10 of 10 Old 07-08-2012, 08:53 PM
99v6Dakota
O/D off = Hardass mode on
Vehicle: 1999, Dodge, Dakota
Modifications: Hifonics Zeus Components, 3-ways, and Subs. Crunch 1000w 2ch Amp
Send a message via Skype™ to 99v6Dakota
Don't we all haha
Always brewing something new to put on or fix.
99v6Dakota is offline
