What's a good easy engine swap for a 4.7L - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
post #1 of 72 Old 11-13-2008, 09:26 PM Thread Starter
mrr1hemitonga
Vehicle: 2000 4.7L Dodge Durango
I'm looking to replace a first Gen 4.7L out of a 2000 Durango. I've not found anyone local that will do the 5.7L swap. Is the 2000 5.9L RT swap an option or any other swap with minimal wiring issues?
mrr1hemitonga is offline
post #2 of 72 Old 11-13-2008, 09:39 PM
HemiDak
Mods Addict
Vehicle: ​
The 5.7L is your best option.
HemiDak is offline
post #3 of 72 Old 11-15-2008, 03:37 PM
Jecht
Mods Addict
Jecht's Avatar
Vehicle: 03 Dakota QC
of course you would say this
yeah go with the 5.7 if your going to spend the money on an engine swap. might as well go fwd and not backwards.
Jecht is offline
post #4 of 72 Old 11-15-2008, 04:46 PM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Vehicle: 2002 QC RAM 4.7L *SOLD*
Modifications: 2011 Grand Sport Corvette :)
Quoted: 6 Post(s)
If you must do a swap then go with a 6.1L! It will bolt in just like any 5.7L ... just bigger.
But you could build a 4.7L to make more HP then a mildly built HEMI for less then it would cost to drop in a stock HEMI/PCM/HARNES/CUSTOM BRACKETS... The 4.7L would be a direct bolt in PLUG & PLAY swap as well.
Yeah once you have a HEMI you would have more potential... I will not argue that. But For about the same amount of money it would cost to drop in a stock HEMI you could build a 375-400HP 4.7L...
SPEED SAFE, AIR RAM
AIR_RAM is offline
post #5 of 72 Old 11-15-2008, 08:54 PM
HemiDak
Mods Addict
Vehicle: ​
Except the programming issue and it being 3-4x more than a 5.7L.
He said he was looking to replace the 4.7L, not upgrade it.
HemiDak is offline
post #6 of 72 Old 11-15-2008, 10:21 PM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Quoted: 6 Post(s)
And I agreed that if he where to upgrade it why sell yourself short with a 5.7L when you could just put in a 6.1L... Go big or go home! I mean if your going to go through all the trouble with an ENGINE/PCM/HARNESS transplant then why go with a smaller 5.7L? The 6.1L is the better of the two and they will take the same amount of time and extensive work to complete.
Now I only brought up building his current 4.7L because he could EASILY make HEMI HP for less then a HEMI SWAP and it would be a DIRECT SWAP "PLUG & PLAY" engine... And he could make even MORE then HEMI HP with a good build up . When you did your swap there was little to nothing that could be done to the 4.7L... So a HEMI swap was a valid alternative and the cost where justified... but that's not the case today and many people dont know whats available for the 4.7L engine... so they just assume nothing can be done.
FYI: There is NO programing issue with the 2000 4.7L... SCT can handle EVERYTHING needed to build a 4.7L to what ever HP level your looking for. Its no longer limited to the factory PCM or a worthless "FLASH" that never workes... SCT can adjust your engine for N/A or Supercharged... So again, PCM issues with the 4.7L are in the past and have been for quite a while.
SPEED SAFE, AIR RAM
AIR_RAM is offline
post #7 of 72 Old 11-15-2008, 10:34 PM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Quoted: 6 Post(s)
I agree... but why not go with a 6.1L for MORE CUBES and the same amount of trouble?
SPEED SAFE, AIR RAM
AIR_RAM is offline
post #8 of 72 Old 11-16-2008, 03:26 AM
HemiDak
Mods Addict
Vehicle: ​
Because you can make a 5.7L MUCH more powerful for the cost of a stock 6.1L.
HemiDak is offline
post #9 of 72 Old 11-16-2008, 03:37 AM
03DakStampede
SRT-8 Dakota
03DakStampede's Avatar
Vehicle: 2003 Dakota Stampede
Send a message via AIM to 03DakStampede
Last time i checked the price of a 6.1 was about $2000 more then the price of a 5.7 with all accessories, harness and comp. Go with the 5.7. Granted if your not wanting to build hp and go fast then go with the 4.7. Of coarse if cost is an issue then deffantly go with a stock 4.7 or 5.9
03DakStampede is offline
post #10 of 72 Old 11-16-2008, 03:49 AM
HemiDak
Mods Addict
Vehicle: ​
I haven't seen a 6.1L go for less than $5000 in a long time. Most of the 5.7L's I have seen are almost always below $2000, and getting one for less than $1500 isn't very hard.
HemiDak is offline
post #11 of 72 Old 11-16-2008, 03:50 AM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Quoted: 6 Post(s)
LOL Now that's FUNNY! My current N/A 4.7L will leave most HEMI's way behind...And thats just with bolt on's. Never mind building one.
But I'm willing to bet this will make more HP for less money then a HEMI SWAP! And it will be cheaper!
And before somone try's to quote what the original question was... I will quote it again to save you time:
And I say the answer to that is build another 4.7L!
SPEED SAFE, AIR RAM
AIR_RAM is offline
post #12 of 72 Old 11-16-2008, 03:55 AM
Jasoon
Jasoon's Avatar
Vehicle: 2001 Quad Cab Dakota 4x4
But I'm willing to bet this will make more HP for less money then a HEMI SWAP! And it will be allot cheaper!
SPEED SAFE, AIR RAM
Did you factor in the cost of grinding off that blue oval?
MOPAR THUNDER...2001 Dodge Dakota Quad Cab 4x4, 4.7L V8, 120,000 miles.
Still passes the 8 foot test.
In search of a fiberglass tonneau Cover
Jasoon is offline
post #13 of 72 Old 11-16-2008, 04:01 AM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Quoted: 6 Post(s)
NOPE... because its an EATON M112.... Since the snout extension kit will replace the SVT stamped snout there is little chance anyone will know where the blower came from unless you told them. Its just there because we have not gotten to that step yet
The EATON M112 is enough to make 450-500RWHP on the 4.7L... Should you go with the WHIPPLE CHARGER (13-28PSI) you could make more then 650RWHP with just under 19psi...
SPEED SAFE, AIR RAM
AIR_RAM is offline
post #14 of 72 Old 11-16-2008, 04:16 AM
viperkota
Mods Addict
viperkota's Avatar
Vehicle: nope
SPEED SAFE, AIR RAM
now this i am liking
the 5.7 would be a good swap and there are tons of parts for them
i would much rather say yeah its a little bitty 4.7 than to say...yeah its got a (fake) hemi
and for those that dont know...the new hemi is not a real hemi...though its output is just as close if not greater than the real one along with efficiency
viperkota is offline
post #15 of 72 Old 11-16-2008, 05:23 AM
Rob454
SPEED SAFE, AIR RAM
I agree. I dont think the 4.7 is a bad motor. yeah there was nothing for it because right after the 4.7 came out the hemi came out and everyone went OOOHHH AAAHHH HEMI and the 4.7 got left behind. There are tons of these motors in dodges and jeeps. besides I always think its way more fun to kick the s**t out of a bigger motor with a smaller motor. its especially funny when you see the owners of the so called faster vehicles say no way I jsut got beat by a take your pick.
For the EASIEST most SIMPLE way to get your truck back on the road is to swap it with the same motor it came in the truck. No mess no fuss. Also you need to think about smog laws if you have them in your area
The human species is the only species who will drown in their own shit.
Originally Posted by Devilbrad View Post
Who the fuck cares??? Taylor Swift could sing Jingle Bells, but god damn, I'd give her thighs the privelage of meeting both sides of my face.
Rob454 is offline
