turn signals dont work - Dakota Durango Forum
post #1 of 8 Old 11-08-2008, 08:52 PM Thread Starter
kka916
Vehicle: 1999, dodge, durango
i have a 99 durango, a few weeks ago my turn signals would cut in and out, they would work for about 4 clicks, then stop. at times they wouldnt work at all, then they would cut in again..... at this point in time they will not come on at all, ive checked all fuses and relays (swapping relays) still i get nothing at all. when i turn the signals on tho i get 1 click noise thats comes out where the relay/fuses are underneath the dash. but it does not flash or continue clicking.
kka916 is offline
post #2 of 8 Old 11-08-2008, 09:29 PM
Dakudaman
Big mouth heavy foot
Dakudaman's Avatar
Vehicle: '98 Dakota R/T CC
Modifications: Going Fast
Sounds like the multi-fuckup switch!
April '08 TOTM
The BLUE BEAST!SOLD
Dakudaman is offline
post #3 of 8 Old 11-08-2008, 09:49 PM
Neil
Neil's Avatar
Vehicle: 99 Durango
Did you ghange the flasher relay on ht back of the fuse panel? That's the part that usually goes.
Neil is offline
post #4 of 8 Old 11-08-2008, 10:57 PM Thread Starter
kka916
ok i found 1 relay that was bright green, my 4ways worked even tho my turns didnt, i pulled the green one out now...i get nothing at all no turn/4ways or clicks..my question now is...are the turns and 4ways on that relay? and could part of it go out that would make my 4ways still work and not my turns (on that same relay)
kka916 is offline
post #5 of 8 Old 11-08-2008, 11:08 PM Thread Starter
kka916
i also forgot to mention that my 4ways still work
kka916 is offline
post #6 of 8 Old 11-08-2008, 11:49 PM
bwdakrt
Posts: n/a
Quoted: Post(s)
The answer to your question is yes. Try replacing the flasher.
post #7 of 8 Old 11-09-2008, 01:21 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
Yea...the turn signal flasher would be the first thing I would check & replace
Little Blue Guy is offline
post #8 of 8 Old 11-09-2008, 06:05 AM Thread Starter
kka916
thank you guys for all your help, ill try that monday and see if it will fix it.
kka916 is offline
