P0320 No Crank Reference Signal at PCM - Dakota Durango Forum
post #1 of 5 Old 09-12-2008, 10:02 PM Thread Starter
txndak4x4
txndak4x4's Avatar
Vehicle: 2001 Dakota CC 4.7L 4x4
Modifications: Superchips 3715, Cold Air Intake
My truck threw a P0320 today while driving it, now its drving horrible. Where is this sonsor located and is it something i can fix on my own? I have a 4.7 by the way. Thanks guys
______________
-Superchips 3715 -UWS Toolbox
-Cold Air Intake -T/B Lift
-Flow 40 Dumped -265/75R16
General Grabber AT2's
txndak4x4 is offline
post #2 of 5 Old 09-13-2008, 01:00 AM
Ranger50
Just a poor shlep......
Vehicle: 95 Dakota Sport 3.9/2wd
Check the camshaft position sensor and related wiring first. That sensor has a nasty habit of screwing everything up. It shares power and ground with the crankshaft postition sensor. Only the signal return wire is seperate. Even when the PCM doesn't need the CMP, it can "steal" the power and ground from the CKP and throw this light.
If all that checks out, most likely the CKP is junk, replace it.
Brian
95 Dakota Sport
"Never trust an intelligent man with no money to play fair."
Ranger50 is offline
post #3 of 5 Old 09-14-2008, 04:41 AM Thread Starter
txndak4x4
txndak4x4's Avatar
Ok i looked over everything and everything checked out, now im in the process of replacing the CKP, but i cant for the life of me get it out. It will twist but will not pull out, how in the world does this thing come out? is their a special way to go about it or what? And also now im getting a P1682 and a P0700, wth?
______________
post #4 of 5 Old 09-14-2008, 06:26 AM
azdurango
Benz Tech
azdurango's Avatar
Vehicle: 2001 Durango SLT+
There is an o-ring seal on it so you may need to pry on it to get it out. The other codes are related to the crank problem, the computer went into limp mode. Once you replace the crank sensor and erase the codes you'll be fine.
5 DOOR WHORE # 110
Performance mods: SCT tuned, H.O. cams, 2008 intake, Fastman 70mm TB, k&n intake, transgo shiftkit, magnaflow exhaust, JBA headers, 180 t-stat, Jeep GC e-fan
Exterior mods: Winch bumper made by toy4whatever, xrc10k winch, T/S lift, 3 inch body lift, pro comp 1069 wheels, goodyear duratrac 33x12.50x15, billet fuel door
Interior mods: Gen III viper seats, Blackcat gauges, RB1 nav, AEM wideband
azdurango is offline
post #5 of 5 Old 09-14-2008, 06:34 AM Thread Starter
txndak4x4
txndak4x4's Avatar
Ok well that makes me feel better knowing its just a limp mode, i have tried everything i can to get it out, it will pull out about 2 mm then feel like there is something catching it. I've also managed to break off the the tab that the bolts onto the block by trying to pry it out.... the location of this thing sucks, can hardly get my arm in their much less get a good angle on it. Well at least i how ill be spending my day tom.
______________
