Replacing Brake Booster - Dakota Durango Forum
General Parts Inquiries Can't find it in any other category?
post #1 of 8 Old 08-11-2008, 04:57 AM Thread Starter
98KotaRT
98KotaRT's Avatar
Vehicle: 1998 Dodge Dakota R/T
Modifications: vehicles
Quoted: 2 Post(s)
Send a message via AIM to 98KotaRT
Hey i'm in the process of taking off my brake booster to replace it. Does anyone know how you are supposed to get it off once the 4 bolts on the backside of it are off? I figured you just pull but i was pulling pretty hard. Am i missing something??
1998 Dakota R/T Flame Red 1 of 93
D.Mc
98KotaRT is offline
post #2 of 8 Old 08-11-2008, 05:03 AM
addicted2blue00
addicted2blue00's Avatar
Vehicle: 00 dakota CC 98 dakota RC
Modifications: ..........
POWER BRAKE BOOSTER
REMOVAL
(1) Remove master cylinder.
(2) Disconnect vacuum lines at booster.
(3) Remove clip securing booster push rod to brake
pedal (Fig. 18).
(4) Remove nuts from booster mounting studs (Fig.
19).
(5) Remove booster, spacer and gaskets from front
cowl panel.
addicted2blue00 is offline
post #3 of 8 Old 08-11-2008, 05:04 AM
addicted2blue00
INSTALLATION
(1) Position spacer and gaskets on booster studs.
(2) Guide booster studs into cowl panel holes and
seat booster on panel.
(3) Install and tighten booster attaching nuts to 28
Nm (250 in. lbs.).
(4) Install booster push rod on brake pedal and
install clip.
(5) Install booster check valve if removed and connect
vacuum hose to check valve.
(6) Install master cylinder.
(7) Fill and bleed brake system.
Click image for larger version
post #4 of 8 Old 08-11-2008, 05:08 AM
addicted2blue00
this is for a 00 but i wouldnt think there be any difference
post #5 of 8 Old 08-11-2008, 05:32 AM Thread Starter
98KotaRT
98KotaRT's Avatar
Quoted: 2 Post(s)
Thanks a lot!
You're my boy bluee...
i figured i was missing the step with a clip haha. and man what a pain in the ass to get those 4 bolts off from behind. just took some patience
D.Mc
98KotaRT is offline
post #6 of 8 Old 08-11-2008, 05:35 AM
addicted2blue00
no problem, just glad i could help
post #7 of 8 Old 05-28-2015, 02:43 AM
11durango
did a booster on a 2011 Durango. put booster on and now pedal goes to floor easily. shut off engine and pedal is hard, checked valve and is working properly. pulled vacuum hose off of booster and plugged hose, started vehicle and pedal was hard. any ideas. think I have a bad booster
11durango is offline
post #8 of 8 Old 07-30-2015, 07:41 PM
McMike
Vehicle: 2002 Dodge Durango SLT
Working on an '02/360 now
Mine's the opposite. Normal until I turn the car on, then the pedal hits the floor. Got a kid to hit the brake while I checked and saw the booster leaking. Got the master cylinder unbolted, but it won't clear the studs because the fuse box is in the way. Trying to figure out how to remove THAT now, thought perhaps I'd find something here. Going back to tinker, I see these clips around the fuse box...
McMike
'02 Durango, 360
FNG
McMike is offline
