Codes P0442, P0455 - Dodge Durango Forum and Dodge Dakota Forums
  #1
Old 08-05-2008, 05:35 AM
KRD KRD is offline
Vehicle: 2002 Dodge Dakoda QC
Reputation: 11 KRD is just getting started
Codes P0442, P0455
P0442 (M) Evap Leak Monitor Meduim Leak Detected A small leak has been detected in the evaportive sysem.
P0455 (M) Evap Leak Monitor Large Leak Detected A large leak has been detected in the evaporative sysem.
These 2 code have been on my truck since I started driving it. Should I be concerened, how do I fix it? Not real sure where to start.
I think I will reset them tomarrow and see if they pop again.
Zak
  #2
Old 08-05-2008, 05:37 AM
KRD KRD is offline
Just found the gas cap post. Gonna give that a try.
I know, I should search first.
  #3
Old 08-05-2008, 06:05 AM
rt59dak's Avatar
rt59dak rt59dak is offline
I got lost on the www
Vehicle: 2001 Dakota CC R/T
Reputation: 49 rt59dak must have done something right
Don't feel bad. I've been reading everything I see on these codes to see if i can get a feel for a fix. I'm not convinced a gas cap will fix with the medium and large leak codes. Thinking my other option is to replace the lines from the cannister forward with fuel line.
So let me know if the gas cap works out for you. Good luck.
  #4
Old 08-05-2008, 06:10 AM
Silver&Blue4x4's Avatar
Silver&Blue4x4 Silver&Blue4x4 is offline
Just another guy...
Vehicle: 2004 Dodge Dakota
Reputation: 48 Silver&Blue4x4 must have done something right
^^ x2, somebody correct me if I'm wrong, but I thought the gas cap fix was for the P0441 small evap leak detected code. That's what I had earlier this year, and the gas cap fixed it, but I thought I remembered reading that the P0442/P0455 codes meant you had bigger problems. Still though, start with the easy stuff and change the gas cap.
-Ryan
__________________
2004 Dakota Quad Cab / 4.7L V8 / K&N CAI / Fastman TB / Spintech Exhaust
  #5
Old 08-05-2008, 06:20 AM
aristeidis aristeidis is offline
Vehicle: car
Reputation: 98 aristeidis is a jewel in the rough
Send a message via MSN to aristeidis
i had the same trouble code when i had my quad cab...first thing i did was change the gas cap...didn't work so then i took my truck to the dealer to have a smoke test done and the hose was roted where the smoke test machine contacts..they cut that piase out and boom..no more code.
To have it smoke tested cost $49
  #6
Old 08-05-2008, 04:17 PM
AmberFireDaK's Avatar
AmberFireDaK AmberFireDaK is offline
Vehicle: 2000 Dakota R/T
Reputation: 64 AmberFireDaK has a spectacular aura about
Send a message via MSN to AmberFireDaK
I've heard of the gas cap causing medium leaks.....either way it's the easiest thing to check so why not?
After that you need to check all the evap hoses going to the charcoal tank under the truck (black box in front of the gas tank) and all the hoses in the engine bay. Don't just glance at them actually look at every inch make sure everything is connected and undamaged
__________________
- Justin
  #7
Old 08-05-2008, 06:05 PM
buzzbass's Avatar
buzzbass buzzbass is offline
Shoo Shoo Retarded Flu !!
Vehicle: 2002 Dakota R/T
Reputation: 52 buzzbass has a spectacular aura about
filling up with the engine running can cause the large leak code too.
  #8
Old 08-05-2008, 06:31 PM
mlobitz's Avatar
mlobitz mlobitz is offline
Vehicle: 2002 Dodge Dakota QC
Reputation: 28 mlobitz must have done something right
Gas cap fixed mine...
  #9
Old 08-06-2008, 02:03 AM
rt59dak's Avatar
Not in the habit of filling up with the engine on, so no dice there.
The way my luck runs I might as well start with the lines and then go to the cap. Then I won't have to worry about the lines later on (hopefully).
Think I'll keep my $50 and skip the smoke test.
Unless somebody can figure out a way to remove the system completely...and so far looks like that's still major "iffy" at best.
  #10
Old 08-06-2008, 02:18 AM
Vehicle: car
sometimes the hole could be a little pin hole and you might not see it by checking the lines with your eyes.
  #11
Old 08-06-2008, 04:34 AM
KRD KRD is offline
So far I just reset the codes and it is still fine? About how long should it take for them to pop again? I droved it for maybe 10 miles after reseting.
  #12
Old 08-06-2008, 05:08 AM
Vehicle: car
everytime i reset mine i would drive about 300km and it would come back on.
  #13
Old 08-06-2008, 06:10 AM
rt59dak's Avatar
I know I might not see the hole, just thinking I'll replace lines. Kinda got it stuck in my head to do so...
  #14
Old 08-06-2008, 06:20 AM
Vehicle: car
If you can't see any holes just take it in and get it smoke tested...by the time you start repalcing hoses it would have cost more money then its worth...my.02
You may not post new threads
You may not post replies
