2000 Durango SLT Tire Size - Dakota Durango Forum
post #1 of 17 Old 07-24-2008, 06:29 PM Thread Starter
2000DD
2000DD's Avatar
Vehicle: 2000 Dodge Durango SLT
Picked up a 2000 Durango SLT the other day. Not sure what tire size to get. The door sticker says "P235/75/R15LT" and that is what it has on it right now with factory alloy rims. But I noticed the spare underneath is a Goodyear Wrangler R/TS, 10.5x31.50R15, also on a matching alloy rim (little tread wear, if any).
Not sure but while my wife was following me home in the Intrepid she thought I was going a little slow. I had set the cruise at 65 mph and she thought I was only going 61-62 mph.
Is there a way to find out exactly what tire I should be using on this rig? Maybe by the rim size? Any ideas? I need new tires ASAP.
5.9 Magnum, auto w/OD, 3:55 suregrip (rear).
2000DD is offline
post #2 of 17 Old 07-24-2008, 09:04 PM Thread Starter
2000DD
2000DD's Avatar
I pulled a tire off and the rims are stamped 15 X 8 in the back.
Did the factory use this rim with the P235/75/R15LT tire ??
2000DD is offline
post #3 of 17 Old 07-24-2008, 10:14 PM
kota62
I miss snow
kota62's Avatar
Vehicle: 00 Dakota SLT 2WD
If you go to Tirerack.com you can look up the various sizes that were standard on your Durango...
Gary
This shortcut should take you right there:
http://www.tirerack.com/tires/Select...0&autoModClar=
00 Dak CC V-6 Auto (42RE) 3.92 LSD, 2WD
K&N Drop-in, Cold Air Intake, TPS Mod, IAT Relocate, V-8 TB, Brass Cap & Rotor, 3923s, JBA 8mm Wires, 180 T-Stat, Clutch Fan Removed, FlowMaster Muffler, UnderDrive Crank Pulley, Lowered 2&2, Clear Corners
kota62 is offline
post #4 of 17 Old 07-24-2008, 10:44 PM Thread Starter
2000DD
2000DD's Avatar
Thanks for the link!
Was just trying to find out what tire size actually came with this Durango. Even though the door sticker says P235/75/R15LT, I'm thinking with the like-new 31x10.50 Wrangler R/TS spare in the back, that is what it came with.
Not sure, either way I am going for new rubber tomorrow, probably 31x10.50s.
2000DD is offline
post #5 of 17 Old 07-24-2008, 11:07 PM
kota62
I miss snow
kota62's Avatar
Just a guess:
235 - SLT Overall diameter is 29"
31X10 - 4X4 Overall diameter is 30.4"
255 - R/T
The different diameter will affect the speedo (I think)
kota62 is offline
post #6 of 17 Old 07-25-2008, 01:07 AM
Neil
Neil's Avatar
Vehicle: 99 Durango
The door sticker reflects the standard size which was a 235. Most came with the optional 31x10.5
(Kota62, The Durango R/T size was 275/60/17)
Neil is offline
post #7 of 17 Old 07-25-2008, 03:22 AM
kota62
I miss snow
kota62's Avatar
Thinking about it, that does make sense...
Got caught up in the info on tirerack
appreciate the heads-up
Gary
kota62 is offline
post #8 of 17 Old 11-14-2008, 10:22 PM
digitalkreation
"The Goat"
digitalkreation's Avatar
Vehicle: 1999 Dodge Durango SLT
I've got the 15" stock rims also and am wondering what is the max safe tire size I can get while sticking with the 15" rim, and not having to do any trimming in the wheel well?
I should also note, I'm dropping the Durango just a bit as it seems I have a lot of room in between the stock tires (23575R15) and the top of the wells..
Any and all comments apprecaited!
1999 Durango SLT 5.2L Magnum V8 "The Goat"
Email me if interested in my Durango..
digitalkreation is offline
post #9 of 17 Old 11-14-2008, 10:34 PM
ramayer
ramayer's Avatar
Vehicle: 1999 durango (5.2L)
31x10.5 r15 on my 99slt
mods: Functional ram air hood, 17" rt rims, 3" Magnaflow cat back, Eddy shorty headers,JBA y-pipe, RHS indy heads, 1.6 RR, comp cam .480 lift, MP valve springs, Comp cams double roller timing set, modified kegger intake, TB by Dwight, Grille craft inserts, Infinity Reference speakers all around with 10" Infinity sub in custom fibreglass enclosure, flip down DVD.
ramayer is offline
post #10 of 17 Old 11-15-2008, 01:55 AM
R/Tdurango02
Ford Recovery Vehical
R/Tdurango02's Avatar
Vehicle: 02 Durango R/T
Modifications: CAI Taylor 8mm Spiro Pro wires Bosch Platinums Accel cap & rotor
Definately get the 31x10.5x15;s. I made the mistake of getting the 235 75 15's and they look dumb as hell, there tiny bastards, and it was for my gf's 98 slt not my R/T
5 DOOR WHORE # 132
R/Tdurango02 is offline
post #11 of 17 Old 11-15-2008, 01:59 AM
digitalkreation
"The Goat"
In what way are they different? I guess I am finding it hard to compare, since the measurements are different to me..
post #12 of 17 Old 11-15-2008, 03:27 AM
Rebel13
Mods Addict
Vehicle: 2K R/T
If you have a 4X4, then 31X10.50's are more correct and came stock. Those stickers do become wrong from time to time. Sounds like whoever replaced the tires wentt with what was on the sticker and not the original tire size. That would be the reason for you reading slower then actual!
Rebel13 is offline
post #13 of 17 Old 11-15-2008, 04:20 AM
Trouble Maker
Trouble Maker's Avatar
Vehicle: 02 & 03 Dakota Quad Cabs
I wouldn't believe the sticker either. My truck came with the 16" tire package but the door sticker only lists the 235-75R15.
You may be able to get a build sheet from Dodge to see what it came with.
Russ
His-SASed 02 Dakota Quad Cab Sport 4x4 4.7 NV3500 5spd/Std D44/9.25" 4.88s lockers frt/rr 35" ProComp Extreme MTs frt EPi 9k Superwinch rear LP 8.5k Superwinch
Also his: 09 Power Wagon Hemi 4.56 gears 285/70R17 Duratracs factory winch and lockers
Hers-03 Dakota Quad Cab Sport 4x4 4.7 545RFE 5spd/Auto 3.92 L/S 265/75R16 Dueler RVTs 5th wheel hitch
Trouble Maker is offline
post #14 of 17 Old 11-15-2008, 03:14 PM
R/Tdurango02
90% of the durango;s came with the 31x10.5x15's unless it was the base or 2 wheel model or the R/T. Get the 31's itl look better and your speedo will be fine as well
5 DOOR WHORE # 132
post #15 of 17 Old 11-22-2008, 07:22 PM
digitalkreation
"The Goat"
Just got my 31's installed this morning and man.. they RAWK!
Hilarious up here in Canada at the moment. Everything is sold out or on back-order, because Quebec has just passed a law mandating snow tires in the winter. I got lucky and found 2 stores with a full set of my size, the closest one only 15 mins from my house, so I made an 8am appointment today.
Anyhow, thanks all for the suggestions. These tires are wicked.
