98 Dakota Hemi Swap - Dakota Durango Forum
5.7L Hemi Engines Does that thing got a HEMI?
Thread Tools Rating: Thread Rating: 27 votes, 5.00 average. Display Modes
post #1 of 204 Old 07-17-2008, 05:27 AM Thread Starter
69rrbruce
Mopar man from Day 1
69rrbruce's Avatar
Vehicle: 1998 Dodge Dakota
Modifications: 5.7 Hemi / 545RFE Trans
98 Dakota Hemi Swap
Well I've been at it for a couple weeks now so I thought I would post some progress pics.
This is what I'm starting with: A 2WD 1998 RC V6 5 speed
The engine bay before the swap began:
The engine bay with the V6, wiring harness, brake booster, clutch master and the front clip removed:
Heres the 5.7 Hemi and Auto trans from a 2004 Ram. Note the steel angle frame jig I used to mock up the motor and trans mounts:
Heres the jig with motor mounts mocked up in the engine compartment.
Motor mounts tacked to frame:
Bruce
1998 Dakota - - 5.7 Hemi - RCC#115 - 6.1 Cam, pushrods & springs, DS Predator 91 tune, LX intake manifold, aluminum fuel rails, 2006+ coils & valve covers, SST dual exhaust, Magnaflow muffler & Pypes tips, 545RFE w/ Sonnax line pressure booster, Lokar floor shifter, 9.25 diff w/ Powertrax Lock-rite locker, Dynamic Grounding system,Viper electric fan, custom aluminum fan shroud & CAI, hood nosed, tailgate and fenders shaved, Sir Michaels rollpan.
My Hemi build thread
69rrbruce is offline
post #2 of 204 Old 07-17-2008, 05:38 AM Thread Starter
69rrbruce
69rrbruce's Avatar
Brake booster was going to interfere with valve cover. I found a smaller diameter one from a Grand Cherokee and it still didn't fit. So the firewall was redrilled to move it 3/4" outboard. Thats the clutch master cylinder opening just below and to the left, it was filled as well. The opening in firewall duct taped shut is the opening for wiring harness:
Well that's it for now. I've got to do some body work so I can paint the firewall, inner fenderwells, rear of cab and door jambs. Then I can install the engine one last time.........Oh I forgot to tell you I'm changing to BLACK hopefully with some candy RED accents.
Bruce
post #3 of 204 Old 07-17-2008, 02:47 PM
kota62
I miss snow
kota62's Avatar
Vehicle: 00 Dakota SLT 2WD
Great work so far...
Is the Hemi/Tranny package significantly heavier that the V6/Tranny package
Gary
00 Dak CC V-6 Auto (42RE) 3.92 LSD, 2WD
K&N Drop-in, Cold Air Intake, TPS Mod, IAT Relocate, V-8 TB, Brass Cap & Rotor, 3923s, JBA 8mm Wires, 180 T-Stat, Clutch Fan Removed, FlowMaster Muffler, UnderDrive Crank Pulley, Lowered 2&2, Clear Corners
kota62 is offline
post #4 of 204 Old 07-17-2008, 03:18 PM
b2
Currently embracing Fords
Vehicle: 06 F250,97 F150,& 08 Kawi
Modifications: Custom Cars and Trucks, Hunting, Fishing, Video Games
Send a message via AIM to b2
Nice! Are you still gonna be able to use your factory gauge cluster?
Sold: 97 Dakota Sport v6
Sold: 84 Power Ram W150
Sold: 06 AB Hemi Ram 1500 4x4
Sold:00 IB Dakota R/T
06 Ford F-250 Powerstroke
97 Ford F F-150
b2 is offline
post #5 of 204 Old 07-17-2008, 05:43 PM
cegpcola
The Mad Scientist
cegpcola's Avatar
Vehicle: 2001 Durango SLT
Modifications: Wife, Kids, Cars
This looks good so far.
cegpcola is offline
post #6 of 204 Old 07-17-2008, 09:29 PM
Metal Hed
Metal Hed's Avatar
awesome post! cant wait to see a finished product
1996 Ext. cab Dakota 5.9L 4"/"5 Drop
1996 Reg. cab Dakota 2.5L Daily driver
1992 Ext. cab 3.9L parts truck pm for parts!
Metal Hed is offline
post #7 of 204 Old 07-17-2008, 09:35 PM
HemiDak
Mods Addict
Vehicle: ​
Looks great so far!
HemiDak is offline
post #8 of 204 Old 07-18-2008, 01:44 AM
03DakStampede
SRT-8 Dakota
03DakStampede's Avatar
Vehicle: 2003 Dakota Stampede
Send a message via AIM to 03DakStampede
looks good keep us updated.
03DakStampede is offline
post #9 of 204 Old 07-18-2008, 05:13 AM Thread Starter
69rrbruce
69rrbruce's Avatar
Gary
I'm not sure how much heavier, that trans is a real PIG. I'm not worried about any added weight the Hemi will take care of itself.
Per YellowKota2k's recommendation I picked up a 2002 Dakota gauge cluster to replace the 98 cluster. Hope I can get it to work.
Thanks all for the kind words!
I'll try and kept you all updated. I know I took some pics of the oil pan and oil pickup mods. I'll have to check on those.
Since I'm in the rust belt I've been spending my time cutting it out and fabbing patch panels. I would like to have a talk with the Dodge engineers who thought it was a good idea to put some kind of spongy material between the body panels at the rear cab corners. It did a great job of holding in the moisture and starting the cancer.
Till next time!
Bruce
post #10 of 204 Old 07-18-2008, 06:17 AM
Starscream
PRAISE THE LOWERED
Starscream's Avatar
Vehicle: 03 CC sport+
Awesome build keep us updated.
The more and more people do this swap the more confident I get about doing mine. Only problem is my truck bagged which will be the hard part.
Starscream is offline
post #11 of 204 Old 07-18-2008, 03:27 PM
b2
What causes you to have to switch gauge clusters? The new wiring harness not work w/ pre-02 clusters? I would like to reuse my 97 cluster if I were to do this swap.
97 Ford F F-150
b2 is offline
post #12 of 204 Old 07-18-2008, 03:37 PM
jmaack727
"][" {[]} {[]} ][_
jmaack727's Avatar
Vehicle: 2 of em.
Subscribed, keep up the work!
jmaack727 is offline
post #13 of 204 Old 07-19-2008, 06:50 AM
HemiDak
Mods Addict
Vehicle: ​
The bus system used in 2000 and older Dakotas is a 2-wire CCD bus; the bus system used in 2001+ Dakotas is a 1-wire PCI bus. If you ever want to have stock gauges again, then you will need to use a 2001+ gauge cluster.
HemiDak is offline
post #14 of 204 Old 07-20-2008, 12:37 AM
b2
Gotcha!
97 Ford F F-150
b2 is offline
post #15 of 204 Old 07-21-2008, 11:05 AM
HEMI5PNTSVN
HEMI5PNTSVN's Avatar
Very Nice!!!!! Post videos.
2005 SILVERED-OUT UNLIMITED HEMI 5.7L DURANGO
Debadged/Detrimmed
"Black Mamba" CAI
Flowmaster Exhaust
HEMI5PNTSVN is offline
