wheres my headlight fuse? - Dakota Durango Forum
General Parts Inquiries Can't find it in any other category?
post #1 of 7 Old 07-15-2008, 06:21 PM Thread Starter
dakotapimpc
dakotapimpc's Avatar
Vehicle: 99/Dodge/RT
Modifications: southeast r/t built 408 w/ paxton
i have a 99 dodge dakota rt and both headlights stoped working where is my headlight fuse i noticed its not in the panel inside the drivers door
Fully Built Forged 408 Stroker,Paxton Novi 2K on 16lbs,Smc Meth Injection,65lb Injectors,Sct tuning done by PIE
dakotapimpc is offline
post #2 of 7 Old 07-15-2008, 06:52 PM
lowlife12
hobby or addiction?
lowlife12's Avatar
Vehicle: '98, Dodge, Dakota
Modifications: 408 stroker, eagle crank/rods, probe pistons, eddy 2.02 heads, crower cam, roller rockers, 24lb fuel injectors, 52mm TB M1 intake manifold. Tom Fox flash, soon to be SCT
if its not in the panel inside the drivers door, then its in the fuse box under the hood. I had that problem and it was my dimmer switch. And didnt you have the motor of out that? Make sure all your grounds are hooked up...
'98 408 5 speed Dakota
lowlife12 is offline
post #3 of 7 Old 07-15-2008, 06:53 PM
mtlcafan79
TKO'ed
Vehicle: 99 5.9 TKO600
It's either there or under the hood. There's a relay for those too in the PDC. You can try swapping it. Hopefully you didn't pinch anything doing that swap.
mtlcafan79 is offline
post #4 of 7 Old 10-18-2008, 07:42 PM
PhL0aTeR
Trailer Trash
Vehicle: 2001 Durango R/T
Modifications: Anything that requires gas or bullets.
Im in the same boat.... my brights work, but lows do not.
01 Durango - Nothing in the "under the hood" fusebox says "headlight" so im stumped....
WHERE THE HELL IS THE HEADLIGHT FUSE? lol
PhL0aTeR is offline
post #5 of 7 Old 10-18-2008, 11:59 PM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
A lot of cars & trucks do not have specific headlight fuses.....there is a circuit breaker built into the headlight switch itself. On some, there is a headlight relay under the hood in the power distribution box....
Someone here said they have high beam only, but not low beam...remove the plug from the headlight bulb, test the prongs for power when you have the low beams on....if you have power to one of the prongs, your bulb is probably bad....if you don't have power when low beams are on, but you have power when your high beams are on, then you probably have a dimmer switch issue.
Little Blue Guy is offline
post #6 of 7 Old 10-19-2008, 12:46 AM
PhL0aTeR
Trailer Trash
well i still dont know where it is, but its a freaky coincidence that both lopw beams go out at the same time, but they did, i replaced both bulbs and its good.
PhL0aTeR is offline
post #7 of 7 Old 10-19-2008, 12:54 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Quoted: 22 Post(s)
I would have the charging system checked...if alternator is overcharging, and you have the headlights on...that might have blown both at the same time.
I don't think you are going to find the "headlight fuse" that you are looking for....bet your truck don't have one
Bryan
