Engine Code P1594 - Dodge Durango Forum and Dodge Dakota Forums
  #1
Old 06-23-2008, 05:01 PM
Swashbuckle Swashbuckle is offline
Vehicle: 2000 Dakota RC R/T
Reputation: 10 Swashbuckle is just getting started
Engine Code P1594
Hi everyone,
this is my first post, however I have been lurking for quite a while. I got this code a couple of weeks ago (P1594 Charging System Voltage Too High Battery voltage sense input above target charging voltage during engine operation) and have yet to find a solution to it. The battery is seemingly getting way overchaged enough that it is leaking through the top caps, however I didn't see any overhcarge when I tested with a voltmeter.
I have had the battery and alternator tested and both were fine, my next guess is going to be the battery temperature sensor and lastly the PCM.
Has anyone had any kind of experience like this?
Its driving me crazy.
The truck is a 2000 R/T
Thanks
Ben
  #2
Old 06-23-2008, 09:28 PM
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
don't feed the bears
Vehicle: 2001 Dakota
Reputation: 197 Jarheadoo7 is a name known to allJarheadoo7 is a name known to all
thats nuts! where did you get the battery that is in it?
__________________
  #3
Old 06-23-2008, 10:10 PM
Canadian Tire here in ontario, they won't replace it under warantee either because it still tests good.
  #4
Old 06-24-2008, 01:02 AM
TazRango's Avatar
TazRango TazRango is offline
Jersey Boy
Reputation: 163 TazRango is a name known to allTazRango is a name known to all
__________________
"Ever had one of those days where you want to light someone's face on fire and try to put it out with a fork?"
Remember that a government big enough to give you everything you want is also big enough to take everything away from you. -Gerald Ford
"Through this inscription I wish to enter my dying protest against what is called the Democratic party. I have watched it closely since the days of Jackson, and know that all the misfortunes of our nation has come to it though this so-called party. Therefore beware this party of TREASON." -Nathaniel Grigsby (1890)
"How many times is Biden gonna say something stupid?" -Barack Obama
  #5
Old 06-24-2008, 01:36 AM
bwdakrt
Posts: n/a
What does your gauge on the dash read? If it's above 14 volts, then the voltage regulator in the alternator has gone bad and is over charging the battery and you will need to replace the alternater.
  #6
Old 06-24-2008, 02:14 AM
I tested the battery at the terminals with the truck idleing it read 13.55V and at 1500 RPM it read 13.68 or something like that. The voltmeter in the dash when the truck was running always read a hair above 14V Ive never seen it any higher than that.
  #7
Old 06-24-2008, 02:24 AM
bwdakrt
Posts: n/a
Then it's defintely not the alt then!
  #8
Old 06-24-2008, 06:13 AM
txlen txlen is offline
Vehicle: 1997 Dakota CC 5.2L 4X4
Reputation: 10 txlen is just getting started
nope..is the sensor under the batt on the bottom of the tray still there???
  #9
Old 06-24-2008, 12:15 PM
The sensor is still there but was thinking it may be the culprit, is there anyway to test it out? They are asking $70 for them at the dealership!!!
  #10
Old 06-24-2008, 01:37 PM
only way i know is to look at the DRB and see what info it's getting... is it touching the battery???
  #11
Old 06-24-2008, 07:18 PM
I dont' know about that. I'm going to try swapping out my pcm to see if the problem goes away, just sucks because I dont want my MOPAR PCM to be messed up.
  #12
Old 06-24-2008, 09:17 PM
if yer sensor doesn't touch the batt it will screw up the charging that the pcm sees.....
  #13
Old 06-25-2008, 02:55 AM
well I swapped out the Mopar PCM and put the factory one back in, now I have no codes and the battery is no longer leaking.
I guess my next question is can anyone fix the regulator in the PCM or is it garbage?
CRAP.
  #14
Old 06-25-2008, 03:44 AM
CRAP.
it's garbage !!
  #15
Old 07-03-2008, 12:53 PM
FRIG, even after I switched out the PCM I'am still having this problem. Is it possible for an alternator to test good on a bench test but still put out too much voltage? Another strange thing is that I have not recieved this engine code since I put the stock PCM back in but the battery still leaks.
I'm going crazy!!
You may not post new threads
You may not post replies
