how to turn on 4 wheel drive - Dakota Durango Forum
FAQ's, Tips & Tricks Helpful technical information.
post #1 of 6 Old 04-30-2008, 04:17 AM Thread Starter
loadedgtp
Vehicle: 2001 Dodge Durango SLT
I just bought an 01 durango. It has the 2wd/4hi/4low selector switch on the dash. I put it in 4 wheel drive and can here the little actuator motor working but cant tell if it is in. also, when i switch it to 4 low, the little light flashes and i dont really notice a difference. this is my first 4 wheel drive so I am trying to learn all of this. also i have no owners manual for info this is why i ask.
loadedgtp is offline
post #2 of 6 Old 04-30-2008, 04:36 AM
azdurango
Benz Tech
azdurango's Avatar
Vehicle: 2001 Durango SLT+
2hi to 4hi can be done while in motion or stopped. if in motion shifts can be made up to 55 mph. if stopped ignition must be in the on position with engine running or off. to go into 4lo the trans MUST be in neutral. can be shifted while moving at 2-3 mph or while stopped. just remember trans MUST be in neutral. for all positions, if the light is flashing then transfer case did not engage that gear. hope that helps.
azdurango is offline
post #3 of 6 Old 04-30-2008, 04:40 AM
Jarheadoo7
don't feed the bears
Jarheadoo7's Avatar
Vehicle: 2001 Dakota
i like to switch to neutral if possible to switch.. but i guess you can do the switch to 4HI up to 50 MPH.
i just put it in neutral flip the switch, watch the light.. then back to drive...
for 4 lo the light will flash until it fully engages...
when using 4 low DO NOT rev up the engine (ie playin int he snow or mud).
if you wanna see if the 4wheel is engaged, drive it in 2wd to a nice level blacktop parking lot and hit the switch and make a few tight turns youll hear the front tires chirping.. this isnt so good for the system but a quick test wont kill it..
im sure other people will have different ways.. lets see what we come up with..
Jarheadoo7 is offline
post #4 of 6 Old 04-30-2008, 11:43 AM
03'Dakota
99 Problems
Vehicle: a crappy one
I always put my truck in neutral . I have a 5 speed tho so its pretty easy for me. I would also suggest from my experiences to only put it in 4wheel if your 30mph or less. when doing it at slower speeds it will kick in right away, rather than blinking and then kicking in. I say keep it under 30mph just to be safe.
03'Dakota is offline
post #5 of 6 Old 04-30-2008, 12:33 PM
mlobitz
mlobitz's Avatar
Vehicle: 2002 Dodge Dakota QC
Modifications: 3" JBA CatBack Exhaust, SuperChips Programmer, K&N Drop In Filter, Airaid MIT Intake Tube, Tint, Tinted Taillights
I change mine above 40 all the time with no ill effects. No need for neutral either (although if I had a manual I probably would too).
mlobitz is offline
post #6 of 6 Old 04-30-2008, 09:49 PM
Jecht
Mods Addict
Jecht's Avatar
Vehicle: 03 Dakota QC
one easier way is when your in 4wd and you drive down the road just move your steering wheel back and forth a lil. it will feel like it has more resistance than in 2wd. also from a dead stop floor it and if the tires dont spin then its in 4wd
also its a good idea to enguage it once in awhile (if you dont go 4 wheeling like me) driving on a straight peice of road to keep things lubricated and working. I do it once a month.
4lo like others have said it needs to be in neutral and at either a dead stop or moving slowly. if not the light will only blink.
Jecht is offline
