left turn signal blinks fast but bulbs are good - Dakota Durango Forum
Lights Parts Info Links : Clear Corners * Headlights * Headlight Covers * Tail Lights * Tail Light Covers
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
post #1 of 13 Old 03-13-2008, 01:42 PM Thread Starter
vartz04
My DD is a beater
vartz04's Avatar
Vehicle: 2003 Dakota SXT
Modifications: ARE Camper Top, 2" front/rear lift, 265/75/16 Nittos, Superchips
Send a message via AIM to vartz04
any idea why this is happening, is it the flasher going out? it still blinks front and rear but it blinks like it just did a line of coke.
SOLD - 03 Dakota 2wd SXT 3.9l auto Reg Cab. 3.55 gears
Current Ride - 2008 silverado, 2.5" level kit, 20" pro comps, 33" coopers, LED tails.
vartz04 is offline
post #2 of 13 Old 03-13-2008, 02:05 PM
hwystar
<---1 of none!
hwystar's Avatar
Vehicle: 1994 dakota club cab
Modifications: nascar, military jets, wrenching
Garage
sounds like one of the bulbs are out. Does your front side marker usually blink along with the turn signal? It does on a gen II not sure about a genIII.
Appeared in the July/10 issue of Mopar Muscle
Dakota-Durango Truck Of the Month Aug 07
hwystar is offline
post #3 of 13 Old 03-13-2008, 02:46 PM
mlobitz
mlobitz's Avatar
Vehicle: 2002 Dodge Dakota QC
Modifications: 3" JBA CatBack Exhaust, SuperChips Programmer, K&N Drop In Filter, Airaid MIT Intake Tube, Tint, Tinted Taillights
There are two lights on each side, are they both blinking on all four corners?
mlobitz is offline
post #4 of 13 Old 03-13-2008, 05:47 PM Thread Starter
vartz04
My DD is a beater
vartz04's Avatar
oh i thought it was just one ill have to check that out
vartz04 is offline
post #5 of 13 Old 03-13-2008, 06:06 PM
mlobitz
mlobitz's Avatar
Well, the backs have one, but the fronts have 2...
mlobitz is offline
post #6 of 13 Old 03-13-2008, 06:12 PM
1hotkadota
YOU HUMAN PARAQUAT!
1hotkadota's Avatar
Vehicle: 02 RC 4.7L 2wd
Modifications: HO cams, intake, exhaust, ported & polished exhaust manifolds, '03 cobra injectors, superchips
That happened to me just this last weekend. It was my driver's side rear turn and brake light that went out.
4157 I believe is the proper replacement bulb.
The Dude: Fortunately, I'm adhering to a pretty strict, uh, drug, uh, regimen to keep my mind, you know, uh, limber.
1hotkadota is offline
post #7 of 13 Old 03-13-2008, 06:21 PM Thread Starter
vartz04
My DD is a beater
vartz04's Avatar
if it went out would both front and back still flash?
vartz04 is offline
post #8 of 13 Old 03-13-2008, 06:31 PM
xlofnktax
Neighborhood Dragger
xlofnktax's Avatar
Vehicle: 00 Dodge Dakota
Modifications: Bagged, shaved, and tweeded.
Send a message via AIM to xlofnktax Send a message via Yahoo to xlofnktax
do you have LED's?
JWagner@stylintrucks.com
xlofnktax is offline
post #9 of 13 Old 03-13-2008, 06:36 PM
bwdakrt
Posts: n/a
Quoted: Post(s)
If you don't have led's, you have a bad bulb or a bad socket.
post #10 of 13 Old 03-13-2008, 10:32 PM Thread Starter
vartz04
My DD is a beater
vartz04's Avatar
i dont have LED's but i dont understand how the bulb could be bad if the signals are still working, to top it off i went to fix it and it was working fine, then i drove around a while, and it started again.
vartz04 is offline
post #11 of 13 Old 03-13-2008, 10:42 PM
bwdakrt
Posts: n/a
Quoted: Post(s)
As I mentioned before. You have a bad bulb or a bad socket. Turn the signal on and check one bulb at a time by twisting and wiggling each one until you fine the one that is causing the problem. You have 2 in front and 1 in the rear.
post #12 of 13 Old 03-13-2008, 11:08 PM
SinCity R/T
That's my stapler.
SinCity R/T's Avatar
Vehicle: 2003 408ci Dakota R/T
Garage
Send a message via AIM to SinCity R/T
The 3157 bulb which is used for the front turn signals (2 bulbs per corner), brake lights, and reverse lights is a dual-filament bulb. For instance, the tail light illuminates 1 filament if you just have your lights turned on, but the 2nd filament kicks in when you hit the brakes. Although the bulb appears to work in certain circumstances, it's possible that only one of the filaments in the bulb is broken.
SinCity R/T
2003 White Club Cab R/T
SinCity R/T is offline
post #13 of 13 Old 03-13-2008, 11:50 PM
1hotkadota
YOU HUMAN PARAQUAT!
1hotkadota's Avatar
That's odd. Because when I took out my brake/turn signals out this weekend, they were 4157's.
I do know that even though it looked fine, even with both filaments intact, it still wasn't working, mabye something in the base. Not sure.
Wait, I just remembered something. It was the brake light that was out, not the turn signal part. My wife was driving behind be last weekend and noticed that my brake light wasn't working. I had previously checked the turn signal and it was working because I checked due to the rapid flashing. But I didn't check the brake part. Hope it helps dude!
