Is replacing Freeze-out plugs hard?? - Dakota Durango Forum
post #1 of 25 Old 03-12-2008, 03:21 PM Thread Starter
Schantzie240
Vehicle: 00 Dodge Durango SLT 5.9L
Send a message via AIM to Schantzie240
Question Is replacing Freeze-out plugs hard??
Hi guys,
I started noticing an antifreeze leak a few months ago. I finally got around to taking it to the dealership to get it looked at since I haven't had the time to check it out myself.
I have been told that 5 out of the 6 freeze-out plugs are leaking and should be replaced. They said that the parts for all 6 plugs are only around $30, but it will end up costing about $500 and another $150 then to flush the coolant system when they are done, so $650 total. They said it will be so expensive because of where 1 or 2 of the plugs are located - the others should be done in less than an hour they said.
Has anyone ever had this done or done it yourself? Is it really all that hard to do and does it take long? ...do you think the $500 estimate is accurate?
Also, is it really necessary to flush out the whole system after replacing the plugs? The guy said it definitely is necessary because there would be 'crud' and stuff in there, especially after taking out the old plugs and putting in the new ones - I dont know if he's trying to help me or just trying to charge me an extra 150 bux that isn't necessary.
Any help/tips on this would be greatly appreciated!
Thanks,
Greg
Schantzie240 is offline
post #2 of 25 Old 03-12-2008, 04:30 PM
razman131
Home Owner....
razman131's Avatar
Vehicle: 1999 Dakota R/T
Modifications: to many to list, plus standard bolt ons and suspension mods.
Send a message via Yahoo to razman131 Send a message via Skype™ to razman131
yo can actually d othis yourself for less than $100.
get the plugs from NAPA, coolant from wally world....
in your driveway drill a small hole in each plug to install an extractor and pull it out. there are other ways to do this. one thing ya dont want to do is install a new one over the pld one. this will put a restriction on your water passages.
a day job, max. a couple may be challenging to get to.
1999 Dakota R/T (mild to heavy mod)
2006 Magnum SRT8 (not *yet* modded)
2004 Dodge Caravan SXT.... Momy Mobile
BEATER: 1991 Honda Civic DX 4dr
razman131 is offline
post #3 of 25 Old 03-12-2008, 04:55 PM Thread Starter
Schantzie240
thanks for the info - I thought about doing it myself, but the guys at the dealership are talking about it like its a HUGE deal. They said that some of the plugs are hidden and you have to take other parts apart to get to them, so that is why it would take so long and would be even harder if only on ramps in my driveway compared to up on a lift at the dealership...
post #4 of 25 Old 03-12-2008, 06:53 PM
xbxjunkie
the DOC can SUCK IT !!!
xbxjunkie's Avatar
Vehicle: 2012 Durango R/T
Quoted: 2 Post(s)
the plugs on the passenger side are the easiest to do if i remember correctly, you'll have to drop the starter to change the ones in the back. the drivers side was a PITA, when i did them on my 99 5.2 4x4, there was a bracket or
mount that blocked some of the plugs.
xbxjunkie is offline
post #5 of 25 Old 03-12-2008, 11:53 PM
new"D"owner
new"D"owner's Avatar
Vehicle: 03 Durango SLT PLUS 4x4
the starer should come out and maybe motor mounts not a hard jub just takes time ps don't do it on a hot engine. flush it out when the plugs are out. if I remember there are some on the rear of the block and you have pull the engine out. I would just pu in some kleen flow sealer and see if that helps
new"D"owner is offline
post #6 of 25 Old 03-13-2008, 02:13 AM
IndyDurango
2000 SLT+ 5.9L Platinum
IndyDurango's Avatar
Vehicle: 2000 Dodge Durango SLT+
Modifications: Gaming, Investing, My D
JB Weld 'em.
If you do have the stealer do it... demand the left over parts to verify that they changed ALL of them. Otherwise, your getting your leaky ones fixed and the 'good-for-now' ones will still be the originals, whether you paid for the replacement or not.
IndyDurango
. . . . .Driving a Durango Cures 5-Door Envy. . . . .
IndyDurango is offline
post #7 of 25 Old 04-01-2008, 06:06 PM Thread Starter
Schantzie240
Do you guys recommend any specific brand sealer?
post #8 of 25 Old 04-02-2008, 06:34 AM
IndyDurango
Nope. I'd never put stuff inside the motor designed to plug up the motor. Not the best of ideas IMHO.
IndyD
post #9 of 25 Old 04-02-2008, 02:59 PM
Fluffy
Hi. ImAnAsshole. Bye.
Vehicle: Durango on 24s yo
Send a message via AIM to Fluffy Send a message via Yahoo to Fluffy
Any stop leak or sealer works, but it's not good for the motor at all. There's a reason it stops leaks, it blocks everything.
I would either let it leak and fill with coolant or bite the bullet and have it fixed.
In the long run a sealer will ruin more than it will do good.
I had to re-do a whole top end of a motor because someone used Bar's Stop Leak in the radiator.
Quickly read the post above, as it will more than likely be deleted within the hour.
Fluffy is offline
post #10 of 25 Old 04-03-2008, 05:14 PM Thread Starter
Schantzie240
thanks for your opinions - I agree. I think i'll just fix it the right way.
post #11 of 25 Old 04-10-2012, 08:16 PM
kjpavey
Vehicle: 1999 Dodge Durango
I have a 99 Durango 4X4 5.2L. Two were leaking on the right side. The first one I could see, no problem. The second was under the motor bracket. I had to jack up the engine and front drive axle. I took all the bolts out of the drive axle except the upper big one one the left side. Then lowered the right side of axle couple of inches to get both bracket thingees out.
kjpavey is offline
post #12 of 25 Old 04-11-2012, 04:33 AM
emjohn4
Vehicle: '02 Dak 3.9 / '02 Dur 4.7
No, it's not hard. However, it is a pain in the ass.
There are two behind the transmission (back of the block), one on the front and back of each head, and one under the starter and passenger motor mount - all of which are hard to get to.
The remainder...? Not bad at all.
If you are going to have them replaced, make sure that they are replaced with brass plugs. If you're doing it yourself - get the "deep" plugs...they are a bit more forgiving to install.
<--Replaced every single core plug on my 3.9...with the engine in the truck.
emjohn4 is offline
post #13 of 25 Old 05-04-2012, 07:12 PM
Pardee
Dakota Enthusiast
Pardee's Avatar
Vehicle: 2000 Dakota
Send a message via MSN to Pardee
Does anyone know the sizes of all the plugs.
I see no one makes an actual kit to replace all plugs.
I'm replacing all of mine while I've got the engine out.
I'll double check the FSM to see what is specified.
I would rather order all of them at once.
Pardee is offline
post #14 of 25 Old 05-04-2012, 08:10 PM
JimLusk
JimLusk's Avatar
Vehicle: 2000 Durango 5.9
Garage
I don't like the description, but Summit shows a kit (I'd certainly call since it says this is for a Buick, but goes here when asked for a 2000 5.9).
http://www.summitracing.com/parts/SLP-381-8002/
As for the expense, it's about all the stuff that has to be removed to get to them. The system needs to be flushed, but you're half-way there once the plugs are removed. I'd be inclined to pull the engine for this job.
1967 Barracuda convertible 440/AT
1968 GTS convertible 340/AT
2004 BMW 330Ci convertible
2000 Durango 5.9
JimLusk is online now
post #15 of 25 Old 01-06-2013, 06:20 PM
emceelovin
Vehicle: 2003 dodge dakota
emjohn4, the free plug located next to my oil filter went bad on me due to severe corrosion, and is now leaking. the rest, that i can visibly see, are fine. you mentioned you had changed all of yours out on your own WITHOUT taking the engine out. how long did that take you and how hard were some of them? the one thats leaking for me seems to be in a good spot as far as changing it out goes, luckily. im pretty sure theres 10 total from what ive read. how did you tackle the one by the oil filter? im gonna start by taking the wheel off, and then going from there.
emceelovin is offline
