Durango won't start - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
post #1 of 10 Old 02-17-2005, 04:44 AM
GaryG
Posts: n/a
Quoted: Post(s)
Unhappy Durango won't start
Our 2000 Durango sometimes will not start. The motor turns over, but will not start. No sputtering or anything indicates that it is even close to starting. Let it sit for a while and it will start easily. There seems to be no pattern to this problem; totally random. Please help.
post #2 of 10 Old 02-17-2005, 08:37 PM
Anthony
Yes it's a lowered 4X4
Anthony's Avatar
Vehicle: 2000 Dakota CC Sport
Send a message via MSN to Anthony
It's hard to tell?? Are you getting any codes?? Check Engine Light??
Could be a dying fuel pump, cam sensor, etc, etc???
How many miles are on the truck??
Anthony is offline
post #3 of 10 Old 02-21-2005, 06:04 PM
GaryG
Posts: n/a
Quoted: Post(s)
2000 Durango Won't Start
The check engine light comes on frequently. I purchased a OBD II code reader and it indicates there are no faults. This should be impossible as the truck has a irregular idle and occasionally will not start. There is about 74,000 miles on the motor. I am beginning to think the PCM is failing and that it is not registering the fault codes due to a malfunction.
post #4 of 10 Old 02-21-2005, 06:20 PM
rockadaous
mod-a-holic
rockadaous's Avatar
Vehicle: 1999 Durango SLT + 4X4
Modifications: Working on truck and GSXR
Do you still have the oem battery? that usually goes first.
rock 5 Door Whore #5 (Fo Sho)
99 Durango SLT+ 4X4
Interior mods
Lotek gauge pod*redline shifter*nu-image panels*rev glow gauge w/chrome bezel*billetpro knobs*titanium pedals
Exterior mods
Cervinis SS Hood*Keystone spoiler*billet gas door*MB Motoring 20X10*Eagle Goodyear GT II*SS speed grille*vent visor*chrome altezza's*Euro diamond cut headlight & parks,chrome differential cover
Engine mods
Intense Performance stage II w/9" bigmouth filter*180 T-stat*billet caps*mopar valve cover*GSport hose*40 series Flowmaster w/duals*reflexx shocks
http://cardomain.com/id/durang0
rockadaous is offline
post #5 of 10 Old 02-22-2005, 01:34 PM
GaryG
Posts: n/a
Quoted: Post(s)
Yes, we do have the original battery. I thought about this as a potential cause, but when the truck refuses to start the motor is cranking very well. Therefore, I thought that probably wasn't the problem.
One thing we found when we were testing, was that spraying starting fluid into the intake caused it to start and stay running. We came across this when we were trying to see if it was a fuel problem. I expected if it was a fuel problem, it might run for a second or two. I was surprised when it kept running; now I don't know.
Yesterday, we replaced the spark plugs. The electrodes were worn and had excessive gaps.
post #6 of 10 Old 04-04-2005, 10:11 PM
Ted 00 R/T
Posts: n/a
Quoted: Post(s)
idle not starting problem
My wife 2k R/T with 75 is doing something similar. She says she is driving along coming too a light slowing down and it just stops. We have just replaced the battery. She said no engine lights. Going to try and get it home now..
post #7 of 10 Old 05-13-2005, 02:08 PM
bgcntry72
Tps/cps
There are two sensors that you need to concern yourself with.
The first is the Throttle Position Sensor, or TPS.
This is located on the side of the throttle body, and can be affected by dirt, water, ect.
Take it off and clean it and the plug and see if that helps.
Maybe time for a replacement?
The CPS is the Crankshaft Position Sensor, and it is located on the upper part of the bellhousing, but not sure where.
Either of these will cause random stalling, or dead engine.
When the CPS went in one of my Jeeps, sometimes it would take 5 tries to start it, sometimes 50. Luck of the draw to get the crank in the proper position to fire.
Good luck.
bgcntry72 is offline
post #8 of 10 Old 05-13-2005, 02:25 PM
lilguido1
"Fuchengruhvin"
lilguido1's Avatar
Vehicle: 2000 Durango Big Blue Bit
Modifications: Cars and anything mechanical
Here's another thought - the starter is getting way too hot - causing a form of "vapor lock".
See if the starter still has the heat sheild intact - if so, you could be headed for a new one. The great thing about the starter is the core charge and I believe they can still test them (haven't replaced one in a while).
Used to happen on my BB Chevelle all the time...
Red, White & Blue...Patriot!
BIG "D" CREW #2 & 5 Door Whore #2
lilguido1 is offline
post #9 of 10 Old 05-13-2005, 02:27 PM
lilguido1
"Fuchengruhvin"
lilguido1's Avatar
Oh yeah, the other thing I used to do is rap it (not extremely hard) with a hammer. Seemed to work 70% of the time...
post #10 of 10 Old 05-13-2005, 06:58 PM
rimfire,22
Vehicle: Dodge Durango
GaryG,
Anythigs possible even the battery. Mine was replaced in a blink of an eye while it was still under warranty! For you my guess would be a started since the engine cranks. It obviously is getting electricty from the battery.
rimfire,22
rimfire,22 is offline
