rear end swap - Dakota Durango Forum
Gen I Dakotas 1986-1990 Dakota-Specific Questions
post #1 of 38 Old 02-11-2008, 06:36 AM Thread Starter
kams
Vehicle: 1988 dodge dakota
rear end swap
what year 8 3/4 will fit in the stock location in my 1988 dodge dakota, cause already have a 3.23 sure grip for it, and truck has mild 318 5 speed but want to end up putting turbos on it with a rebuilt engine.
thanks
kams is offline
post #2 of 38 Old 09-03-2008, 04:58 AM
charger_340
charger_340's Avatar
Vehicle: '97 SLT, '99 R/T
I, too, am curious. A 318 will probably grace my first gen's bay after this winter, and I don't think the 7 1/4 will like that.
-Steve
charger_340 is offline
post #3 of 38 Old 09-07-2008, 02:05 AM Thread Starter
kams
66-70 b body rear ends will fit
kams is offline
post #4 of 38 Old 09-12-2008, 05:38 PM
87DakBuilder
Stroked 91
87DakBuilder's Avatar
Vehicle: 13 Durango, 02 Dakota
Modifications: 390 Stroker Twin 66's
Quoted: 8 Post(s)
Send a message via Yahoo to 87DakBuilder
I agree, I have a 68 b body 8.75, and it looks like there won't be any problems at all. I'll be putting it in for a test fit this weekend actually. I'll post up pics and info on it over the weekend. I also know that 70-74 ebody 8.75s will fit as well. Marty from KRC put one in his 96 Dak a few years back. Did a decent write up on it as well. Most of the infor you will need about the swap is over on Bionicdodge.com. Not premoting other sites, but the info is there if you want/need it.
13 Durango R/T
13 Challenger R/T
02 Dakota Sport 3.9 Daily
91 Dakota Ext cab4/4 Drop
390 Stroker W/TKO 600 finally in truck
87DakBuilder is offline
post #5 of 38 Old 09-15-2008, 02:55 AM
WarlocK451
WarlocK451's Avatar
Vehicle: 1988 Dodge Dakota
Modifications: 451 Stroker
Garage
I got a 1970 A-body 8 3/4 with 3.55's under my 1988 Dakota pictured below...handles 530hp that my 451 stroker hits it with. B-E body rear ends are too wide and will not fit right under the truck.
Use an A-body 8 3/4 rear housing because the A-Bodies and Dakotas share almost identical track width. Just cut the original spring pearches off, and have new ones welded in the proper location to accomodate the springs. This rear end fits like it should've been there from the factory when done right.
..........2002 Dakota SXT 3.9 Liter..................................1988 Dakota R/T 451 Stroker............
WarlocK451 is offline
post #6 of 38 Old 09-15-2008, 04:15 PM
realdeal7369
G.F.Y racing president
realdeal7369's Avatar
Vehicle: 2005 dodge magnum rt
Modifications: Cold air intake.
Send a message via Yahoo to realdeal7369
there were many a 7.25" rears behind 318's. my 69 barracuda had one. granted its considers as low performance and all, but its not like a mildly built 318 will bust it any.
1997 dakota, 5.2v8, msd wires, trans cooler, K&N cai, 1.6 rr's, stinger 1700 battery, updated big 3. aeroturbine 3030 muffler, high flow cat. conv
realdeal7369 is offline
post #7 of 38 Old 09-15-2008, 06:09 PM
charger_340
Hmm, I had a friend smoke multiple 8 1/4 in his FS Dodge with a high mile 318 in it, but he also beats the piss out of stuff more than anyone I know. I'll probably run the 7 1/4 for awhile until I find the perfect 8 3/4.
-Steve
post #8 of 38 Old 09-15-2008, 06:38 PM
Captain Chaos
Donating Chicken Helmets
Captain Chaos's Avatar
Vehicle: 99 Durango 4x4
http://www.moparts.org/Tech/Archive/axle/17.html
Heres the info I used for my selection. Go take measurements of your existing housing and go from there.
Originally Posted by slammedR/T
SHIT! I'll check that hunk of shit off,on pump gas and driving to the track.
CHECK!
R.I.P
http://www.dakota-durango.com/forum/...ad.php?t=90566
Captain Chaos is offline
post #9 of 38 Old 11-30-2008, 01:18 AM
rschrum
Vehicle: 89 Shelby
Rear end
I had a 66 charger 8.75 under my 89 shelby. Had to redo the perches and fab shock mounts. These are wider than the A bodys, but if you get the right backspace on your wheels they work fine. When I decided to mini tub and narrow decided to go bullet proof and narrowed a dana 60. Took an old 3/4 ton truck dana and whacked the ends off, welded on new ends and ordered moser 35 spline axels. works great. also remember this, when you break a rear end there is a good chance it will also take out the tranny.
rschrum is offline
post #10 of 38 Old 11-30-2008, 02:12 AM
charger_340
^Wow, do you have any full body shots of that truck? I'd love to see some.
-Steve
post #11 of 38 Old 11-30-2008, 02:19 AM
rschrum
Vehicle: 89 Shelby
rear end
Here is what I have so far. I'm having to compress the images. 410 LA 500HP pump gas with a 150 shot. 2 year project.
rschrum is offline
post #12 of 38 Old 11-30-2008, 02:12 PM
WarlocK451
WarlocK451's Avatar
Garage
also remember this, when you break a rear end there is a good chance it will also take out the tranny.[/
If your going anymore than 400HP with a torque flite, a bolt in sprag clutch is a must. The factory sprag clutch is just pressed in and when the rear end unloads is shocks the sprag so hard that it typically will break loose, its RPM will double that of the engine's and explode...resulting in holes in the floor, roof, you... see my point... many times the explosion is so severe that a explosion shield wont contain it. An eplosion blanket is a must over 600 hp.
post #13 of 38 Old 11-30-2008, 04:02 PM
rschrum
Vehicle: 89 Shelby
Warlock is correct. Bolt in sprag and as many other HD parts as you can afford. I found the weak link in my 518,46rh, when the hub on the back of the input shaft snapped off. Talked with Rick at AA and ended up with 2000.00 in HD parts. Bolt in sprag, billet 2nd gear hub, stainless input shaft and hub etc. Haven't been able to break it since. I'm getting too old to be pulling trany's very often
rschrum is offline
post #14 of 38 Old 12-01-2008, 02:10 PM
1stGen360dakota
Vehicle: 1990 dodge dakota
Modifications: 360 mag 727 PTC 9.5 8.8 rear
I wanted to put a 8 3/4 in my dakota but I couldnt find one that was less than 600 bucks that was set up like I wanted. So I went with an 8.8 out of a 94 exployer 4 wheel drive and it fit great. I found one with a limited slip, 3.73 gears, and 31 spline axles. I ground off the old mounts and put some mopar performance spring mounts and comp. eng. shock mounts. I know that alot of mopar guys would consider this sacreligious but it was a cost thing for me. I got the rearend at the u-pull it junkyard for 60 bucks and although it took several hours to get it out it was well worth it.
1stGen360dakota is offline
post #15 of 38 Old 12-16-2008, 05:51 AM
dakotajr
dakotajr's Avatar
Vehicle: 1992 Dakota CC, big block
Modifications: Gen II, Aluminum headed, 498cu in, big block stroker...
I have an 8 3/4 rear that is 5/8" wider than a stock dakota rear. 5x4.5 lug pattern, 742 center section, just needs backing plates, brakes and drums (which are the same off from an 8 1/4 rear), and the spring perches welded in for a dakota width. I am unsure of the gear ratio. It can be yours for the low, low price of $100. Just PM me if interested.
The 742 housing is the non crush sleeve housing, so it is more desirable.
dakotajr is offline
