Marker/Turn signal/Headlight - Dakota Durango Forum
Lights Parts Info Links : Clear Corners * Headlights * Headlight Covers * Tail Lights * Tail Light Covers
post #1 of 11 Old 01-16-2008, 05:47 AM Thread Starter
Durangotang
Vehicle: 01 Dodge Durango
This Question may have been answered already, but i'm to lazy to look for it. I am looking for any information on how to remove/replace the headlight/turn signal/marker assembly for a 2001 Durango. Also, would a Haynes manual be a wise purchase? Thanks.....
Durangotang is offline
post #2 of 11 Old 01-16-2008, 05:50 AM
Fluffy
Hi. ImAnAsshole. Bye.
Vehicle: Durango on 24s yo
Send a message via AIM to Fluffy Send a message via Yahoo to Fluffy
There's a torx screw on the top corner of the signal, just under the head light. Remove that and pull the turnsignal out. Unplug the bulbs, take it out fully. There's 3 bolts holding the headlight housing on, take those out and pull out and unplug the headlamp.
The Haynes manual is a good thing to have if you do your own work. Come in handy.
Quickly read the post above, as it will more than likely be deleted within the hour.
Fluffy is offline
post #3 of 11 Old 01-16-2008, 05:56 AM Thread Starter
Durangotang
Marker/signal/headlight
Thanx 2slow4u... is that torx screw accessable from the engine compartment or through the fender well? There is only 1 screw holding in the marker and turn signal?
post #4 of 11 Old 01-16-2008, 06:00 AM
Fluffy
You can get it from the outside, it's a T10, just look in the corner of the light, on top. It's inbetween the sidemarker and the headlight, above the turn signal.
Fluffy is offline
post #5 of 11 Old 01-16-2008, 06:09 AM Thread Starter
Durangotang
Marker/Signal/Headlight
To put the new ones in, do I have to remove the headlight and put the signal and marker in first? Here's the deal, my daughter crunched the signal and marker and I noticed that the headlight seems loose. On the non-damaged side everthing is tight. Do you think I will have to replace brackets also?
post #6 of 11 Old 01-16-2008, 06:13 AM
Fluffy
The headlamp housing is just thick plastic. It's possible she could've bumped it good enough to have it break from the bolts on it. The signal/marker is replaceable without touching the headlight. Just that one screw, pull out a bit and remove the 3 lights on it... and it's out.
Once you have the signal out, you can see the 3 bolts for the headlamp housing and you will be able to tell if they're broken or not. If so, you'd have to replace that whole assembly.
Fluffy is offline
post #7 of 11 Old 01-16-2008, 06:49 AM Thread Starter
Durangotang
Many Thanks 2slow4u.... Sounds like it's an easy project. Maybe I'll have her do it and I'll supervise!!!
post #8 of 11 Old 01-16-2008, 06:55 AM
Fluffy
It's real easy, as much as I've done with my lights in the past 2 months I've had them on and off over 50 times. I should be able to do it in my sleep now.
Good luck.
Fluffy is offline
post #9 of 11 Old 01-16-2008, 12:44 PM
mlobitz
mlobitz's Avatar
Vehicle: 2002 Dodge Dakota QC
Modifications: 3" JBA CatBack Exhaust, SuperChips Programmer, K&N Drop In Filter, Airaid MIT Intake Tube, Tint, Tinted Taillights
If you are replacing the whole thing you don't need to bother with the torx screw. I usually take the bumper off (4 quick and easy bolts) and everything is in plain view with plenty of room to work comfortably. 3 bolts for each housing, pop out the bulbs and put them in the new housing, install, drink beer. Shouldn't take but 10 minutes all said and done this way. Remember to torque the bumper bolts back to 70 ft/lbs though...
mlobitz is offline
post #10 of 11 Old 01-18-2008, 02:32 AM Thread Starter
Durangotang
Anybody know of a good source for purchasing the lights, turn signals/markers. All the better if you know of any in California (Inland Empire). Any "custom" lighting accessories? Thanks.....
post #11 of 11 Old 01-18-2008, 04:51 AM
Fluffy
Your best bet would to be to call a junkyard. They're kind of expensive new.
Fluffy is offline
