Part-Specific Photos: Brakes - Dakota Durango Forum
post #1 of 11 Old 12-17-2007, 06:46 PM Thread Starter
SinCity R/T
That's my stapler.
SinCity R/T's Avatar
Vehicle: 2003 408ci Dakota R/T
Garage
Send a message via AIM to SinCity R/T
This thread is being configured for people to post pictures of aftermarket brakes installed on their trucks. Please add photos even if there is another truck with the same item in the thread - it can be very helpful to see how this product looks with various body colors and other modifications.
If you need assistance with posting photos, see this FAQ:
http://www.dakota-durango.com/forum/...ad.php?t=13624
SinCity R/T is offline
post #2 of 11 Old 04-19-2008, 05:58 AM
Fluffy
Hi. ImAnAsshole. Bye.
Vehicle: Durango on 24s yo
Send a message via AIM to Fluffy Send a message via Yahoo to Fluffy
Summit Cross-drilled/Slotted rotors with Hawk pads.
Quickly read the post above, as it will more than likely be deleted within the hour.
Fluffy is offline
post #3 of 11 Old 04-19-2008, 06:43 AM
viperkota
Mods Addict
viperkota's Avatar
Vehicle: nope
viper srt10 brakes...stock rotors, stock calipers, stock pads (appear to be ebc greenstuff)
viperkota is offline
post #4 of 11 Old 10-10-2008, 02:34 PM
captaintrps
Vehicle: 2003 durango
2003 Durango 5.9L 4wd rear stock
captaintrps is offline
post #5 of 11 Old 05-16-2009, 02:04 AM
jellyhead
Vehicle: 2000 Quad Cab 2wd 4.7
Here's some pics of 03 durango brakes installed on my 2000 Dakota 4WD.
Front:
Rear:
How they look behind my 20" KMC Stealth wheels:
Front:
Rear:
jellyhead is offline
post #6 of 11 Old 12-26-2010, 10:47 PM
celicoupe
celicoupe's Avatar
Vehicle: 1999, Dodge, Durango
@jellyhead Was that a pretty easy conversion? Specifically the caliper brackets and parking brake stuff. Thanks.
celicoupe is offline
post #7 of 11 Old 12-26-2010, 11:13 PM
SPC. Brinkmeyer
Jason is the name
SPC. Brinkmeyer's Avatar
Vehicle: 2004, Dodge, Dakota 3.7L
Modifications: 3" Body lift, 285/75/16 BFG A/T K.O.'s, 5% tint on rear windows and sun shade, 20% on front doors, Flowmaster 40 Series Single in Dual Out exhaust 8" long 3" tips, Line-X black Bedliner
Quoted: 2 Post(s)
Garage
Send a message via Yahoo to SPC. Brinkmeyer
unless you upgrade piston numbers or size of your calaper or rotor should be as simple as changeing your own brakes and rotors.. with the addition of seperating your old calaper from your brake line and screwing in your new ones and bleeding them
Posting And You
04' dak QC 4wd, 285/75/16 BFG's_________________________________________06' 300C SRT8
SPC. Brinkmeyer is offline
post #8 of 11 Old 12-28-2010, 09:21 AM
jellyhead
The front was very easy, once I installed the durango front spindles, everything else just bolted on normally. The rear wasn't that easy, since I used the whole rear axle from a 2003 durango I needed to remove the spring perches and shock mounts and weld them on the other side of the axle. The ebrake was kind of a challenge. I was able to use the durango left side cable but it needed to be modified. I had to make clevice to use the original dakota right side cable because the durango housing was way too long. I also needed to cut the cables and use a ferrule tool to get the cables to the proper length.
The rears were more cosmetic than an actual upgrade. most of the improvement in braking was due to the dual piston durango front calipers
post #9 of 11 Old 03-11-2015, 04:30 PM
blackdent
Vehicle: 2001 dodge dakota
Modifications: HO cam, hombrew CAI, optima yellow top, 265/75/16 goodyears, offroad lights, stiff shocks.
Quoted: 2 Post(s)
EBC yellow stuff pads and custom ebay sourced rotors- rear; tow/haul drum brake pads and hd pistons.
Click image for larger version
blackdent is offline
post #10 of 11 Old 03-11-2015, 06:51 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 190 Post(s)
2003 Disc brake upgrade/comparison. Pulled this set up off a 2003 Dakota R/T in a junkyard. Paid $372 for everything. So far the front has bolted right on, and the rear should as well since it came off a Dakota R/T and is going onto a Dakota R/T.
Side by side rotor comparison. the slotted/crossdrilled rotor is what I had on my '00.
2000 rotor stacked on top of 2003 rotor.
caliper comparison. single piston 2000 to dual piston 2003
and old slotted/cross drilled rotors behind my wheels(from Ebay)
2003 rotors/calipers behind my wheels
and my 15" wheel with my slicks test fit on the rear axle to check clearance(not installed on truck yet)
hskrRT is offline
post #11 of 11 Old 01-31-2016, 07:19 PM
cbr600rx7
Quoted: 25 Post(s)
EBC rotors.
cbr600rx7 is offline
