If my truck rolls back on a hill without holding itself...bad?? - Dakota Durango Forum
post #1 of 9 Old 08-21-2007, 01:32 AM Thread Starter
cyrjm
cyrjm's Avatar
Vehicle: 2000 Dodge Dakota
Modifications: 3 in PA lift, 32x11.50 BFG All Terrain Tires, Pro Comp Rims, Custom Truck Cap, Yakima Rack System with Loadwarrior Basket + Spare Tire Mount, Rockford Fosgate Sound, MBRP Custom Exhaust, 360 Air Intakez
is this an indication of my tranny going bad? 112k miles on, sometimes it shifts awkwardly but otherwise i don't know if it's going. maybe my tourque converter going? just being cautious since i have to tow the largest uhaul trailer they got 2,000 miles from utah to georgia...don't want it to crap out in the middle of nowhere....
thanks!
jc
2000 Dodge Dakota, 4.7l V8, 3 in PA lift, 32x11.50 BFG All Terrain Tires, Pro Comp Rims, Custom Bed Cap, Yakima Rack System with Loadwarrior Basket + Spare Tire Mount, Rockford Fosgate Sound, MBRP Custom Exhaust, 360 Air Intakez
cyrjm is offline
post #2 of 9 Old 08-21-2007, 02:38 AM
realdeal7369
G.F.Y racing president
realdeal7369's Avatar
Vehicle: 2005 dodge magnum rt
Modifications: Cold air intake.
Send a message via Yahoo to realdeal7369
i wouldnt tow it, sounds to me its getting weak.
1997 dakota, 5.2v8, msd wires, trans cooler, K&N cai, 1.6 rr's, stinger 1700 battery, updated big 3. aeroturbine 3030 muffler, high flow cat. conv
realdeal7369 is offline
post #3 of 9 Old 08-21-2007, 02:41 AM
02roadtrack
Crown on the Rocks
02roadtrack's Avatar
Vehicle: 02 Dakota R/T rc
Modifications: Superchips, K&N FIPK, 52mm tb, M-1 2bbl
I am guessing auto since you said torque conveter. I would guess you didn't get in park all the way or shifting linkage is a little sloppy. No way it should roll if in park( tranny in trouble, unless 4x4 and transfer case is bad. Now, if stick, clutch is bad, engine compression is bad or was parked with to high a gear, my owners manual said 1st or rev.
1 of 59 metallic graphite
RCC #67
Mods--K&N Cai, F&B 52mm tb, 4bbl M-1 with2bbl adapter, ASP ud pulley, Spintech duals, SCT Tuned by Hemifever
02roadtrack is offline
post #4 of 9 Old 08-21-2007, 03:10 AM
ucimaplaya2
ucimaplaya2's Avatar
no i think he means while its in drive and hes stopped
how steep of a hill was it?
John
ucimaplaya2 is offline
post #5 of 9 Old 08-21-2007, 04:05 AM Thread Starter
cyrjm
cyrjm's Avatar
sorry guys, trying to post too quickly...yes, it is an auto and it is while i'm in drive on a hill. i'm just about due for some tranny service...flush, filter change but i'm considering getting it rebuilt by AAMCO or any other reputable tranny place in the area.
cyrjm is offline
post #6 of 9 Old 09-10-2007, 03:54 AM
thirsajohn
thirsajohn's Avatar
Vehicle: 00 durango rt
Modifications: stroked 360 kenne bell sct 42#fms ported rt2.02heads
hey, those are my initials and my last name too! And interestingly enough, I'm at the point of a torque converter. jm cyr
thirsajohn is offline
post #7 of 9 Old 09-11-2007, 02:37 AM
92dakotahd
GenII Owner
92dakotahd's Avatar
Vehicle: 92 Dak CC 5.9L 2WD
Modifications: My truck and Harley-Davidsons
Send a message via AIM to 92dakotahd Send a message via MSN to 92dakotahd
I'm not sure, I've driven lots of cars and it seems to depend on the tranny.
Zach
92 Dakota CC 2WD
360 Swap DONE
2001 5.9L
MSD Wires
Doug Thorley/Mopar Headers
RiceKiller Modded TB
A500 with it's days numbered...
92dakotahd is offline
post #8 of 9 Old 09-11-2007, 03:32 AM
Blue93Dakota
408,R3,Indy Heads,Twin66s
Blue93Dakota's Avatar
Vehicle: 93 CC 2wd
Modifications: Bone Stock... check fQuick in signature
Garage
Just depends on your stall speed of your torque converter. Mine never used to do this except on fairly steep hills/driveways. Now it does not take much with my higher stall converter. I don't think it means anything.
"Never argue with an idiot, he will drag you down to his level and beat you with experience." -Unknown
Joe
'04 Altlantic Blue Durango Limited 4X4 Hemi
20" Chrome Ram Wheels
'04 Bright Silver Durango Limited 4X4 Hemi
Blue '93 CC Dak MS3XEFI 408 R3 Indy Heads Twin Turbos
My fQuick (Mods)
R3 Twin Turbo Build
MS3EFI
Link to current pic
513-Motorsports-LLC
Blue93Dakota is offline
post #9 of 9 Old 09-14-2007, 09:34 PM
PhL0aTeR
Trailer Trash
Vehicle: 2001 Durango R/T
Modifications: Anything that requires gas or bullets.
just FYI, my mechanic pulled the bottom off mine and found a couple snap rings from the forward clutch, the symptom you described is similar to one of mine. another symptom i had was a weird shift from 1st to 2nd.
PhL0aTeR is offline
