rear main seal - Dakota Durango Forum
post #1 of 3 Old 04-06-2007, 04:26 PM Thread Starter
infernorage999
well hell....
infernorage999's Avatar
Vehicle: 1998 Dodge Durango
rear main seal
I know what I have to do to change it but I want to know what is the easiest way to drop the front end.
I have a 98 durango 4x4
or is there an easier way to get the oil pan off ?
Five Door Whore # 24
Hey that ryhmes
need points pm me 10 for $1000
infernorage999 is offline
post #2 of 3 Old 04-06-2007, 11:16 PM
Dman98
Procedure for oil pan gasket/rear main seal replacement
Front axle removal
1) Remove skid plate
2) Remove skid plate crossmember
3) Mark CV joint and axle flange
4) Separate axle shafts from axle flange
5) Mark propeller shaft and pinion yoke
6) Remove propeller shaft
7) Remove axle vent tube
8) Support differential with floor jack
9) Remove bolts holding axle to engine
10) Lower jack and remove axle from vehicle
Oil pan and main seal removal
1) Remove dipstick
2) Drain oil
3) Remove engine to transmission support brackets
4) Remove transmission inspection cover
5) Remove oil pan and gasket
6) Remove oil pump from main bearing cap
• Have bucket handy to catch oil in pump during removal
7) Remove rear main bearing cap and discard lower seal
8) Loosen two bearing caps forward of the rear main bearing
9) Remove upper seal with removal tool
Notes:
• Remove negative battery cable
• Place cardboard under vehicle to protect cement from dripping oil
• Clean all mating surfaces of old gasket and sealer
• Make pan installation dowels with 1 1/2- 5/16 bolts cut off bolt
heads and make a slot for screw driver removal
YOU MAY HAVE TO REMOVE THE ENGINE MOUNTS, IF THIS IS NECESSARY SUPPORT THE ENGINE ON EACH SIDE WITH A HYDRAULIC RAM, LONGS PIPES OR 2X4'S
Rear main seal and oil pan installation
1) Lightly oil new upper seal with engine oil
2) Rotate seal into block with white facing rear of engine
3) Lightly oil new lower seal with engine oil
4) Install seal in lower main bearing cap white facing rear
5) Apply locktite 515 to each side of main bearing cap(don’t allow
locktite to contact rubber seal)
6) Align bearing using slot alignment dowel and cap bolts
7) Install main bearing cap w/cleaned and oiled cap bolts
• alternately tighten bolts to 85ft lbs, starting with the two main
bolts loosened during removal and working toward the rear main cap
• Tighten all main caps to 85 ft lbs working from to rear
8) Install oil pump torque to 30ft lbs
• Prime pump with oil prior to installation
9) Apply black RTV sealant to the bearing to cap block joints
10) Install the dowels (2) at each end of the block
11) Slide gasket over dowels onto block
12) Install oil pan and torque bolts to 215in lbs
Front axle installation
1) Raise axle into position, loosely install the bolts and nut to the
brackets
2) Tighten all bolt finger tight, then to the following
• Axle to engine mount bolts 75ft lbs
• Axle to engine to transmission 40ft lbs
3) Install axle vent tube
4) Align reference marks on propeller shaft and pinion yoke, install
5) Align reference marks on C/V joints and axle flanges, install
6) Install skid plate crossmember support and skid plate
7) Make sure vehicle is level and check differential fluid
• Add fluid if necessary
8) Remove all supports and lower vehicle
9) Replace filter, add oil, start engine and check for leaks.
_______________
Dman98 is offline
post #3 of 3 Old 04-07-2007, 01:04 PM Thread Starter
infernorage999
well hell....
damn.... why can't it just be easy It's easier to change the rear main seal in a humvee
Hey that ryhmes
Gear in this thread - Powered by O'Reilly Auto Parts
