How do I remove my damn front driveshaft? - Dakota Durango Forum
post #1 of 10 Old 02-09-2007, 05:12 AM Thread Starter
dannyac
I spent 45 minutes under my Durango tonight trying to pull my front driveshaft off so I can overhaul the thing (new centering ball in the CV unit, new u-joints all around). I pulled the 4 big bolts that appear to hold the circular plate on the differential-side yoke to the circular plate on the differential, and the four small bolts that hold the transfer case side yoke onto the transfer case. The yoke on the transfer case side wanted to seperate fine, but the circular plates on the differential side just kind of spun and would not come off, like they were attached in the middle. I tried tapping it with a rubber mallet, but had no luck, it won't budge. What the hell am I missing?
Here's a terrible MSPaint diagram showing what I'm talking about hopefully
(2000 Dodge Durango SLT) 4x4, 4.7l V8
(1984 Dodge Ramcharger) 360 V8, 36" Swampers, too many mods to list.
dannyac is offline
post #2 of 10 Old 02-09-2007, 09:57 AM
realdeal7369
G.F.Y racing president
realdeal7369's Avatar
Vehicle: 2005 dodge magnum rt
Modifications: Cold air intake.
Send a message via Yahoo to realdeal7369
can you post a pic?
1997 dakota, 5.2v8, msd wires, trans cooler, K&N cai, 1.6 rr's, stinger 1700 battery, updated big 3. aeroturbine 3030 muffler, high flow cat. conv
realdeal7369 is offline
post #3 of 10 Old 02-09-2007, 04:13 PM
TraMotorsports
4morthanu
Vehicle: 1998 Dodge Dakota
Modifications: working on cars
Send a message via AIM to TraMotorsports
if the flange bolts are off it should come apart. Use a pry bar.
TraMotorsports is offline
post #4 of 10 Old 02-10-2007, 04:08 AM
HemiDak
Mods Addict
Vehicle: ​
Yup, that's the easy way.
I have noticed that if I haven't taken my driveshaft off in a while then they tend to not come apart easily. A chisel or screwdriver and a hammer work very well for me.
HemiDak is offline
post #5 of 10 Old 02-10-2007, 05:49 AM Thread Starter
dannyac
Awesome, that seems to be the general consensus on the other forum I posted on too. That or beat the hell out of the flange with a rubber mallet.
Good deal guys, you saved my ass again. I may do a pictorial writeup on pulling the front shaft and replacing the U-joints if anyone would be interested.
dannyac is offline
post #6 of 10 Old 09-13-2008, 06:25 PM
StompinGround
Dakota SLT Quad Cab 4x4
Vehicle: 2002 Dakota SLT Quad Cab
Modifications: No Mods yet except for Paint and Stripes , PowerAid Throttle Body Spacer
Quoted: 20 Post(s)
Seperating Flange From Coupler
I used a large chisel and hammer and tapped at different locations around circumfrence to eventually seperate one from the other . Chance are they are corroded slightly and it is also a press fit , there is a bit of a taper and they lock together when installed and tightened . Don't get too carried away with hitting unit itself , the idea is to get chisel between the 2 parts so they seperate .
StompinGround is offline
post #7 of 10 Old 09-13-2008, 09:31 PM
TazRango
Jersey Boy
TazRango's Avatar
Quoted: 243 Post(s)
IIRC there was a 1/8" or so long centering pin on the flange on my Ramcharger. So you have to remove it from the transfer case first, then slide the shaft back to dislodge the pin.
Use torrents? Already got two copyright strikes with your ISP? Got a slow upload connection? You need an offshore SEEDBOX! Includes a FREE VPN Endpoint in France, The Netherlands, or Canada (allows you to watch Netflix titles not available in the US!!).
CLICK--> DediSeedbox.com - 1Gbps backbone, up to 1TB storage, unlimited traffic, unlimited concurrent torrents, Secure FTP, VPN, and HTTPS access to files <--CLICK
Originally Posted by Big_Texxan View Post
fuck it, Im going to convert those to HID and stick them in my heads, fogs, tails, double heads, and my butt so I make a halo while shitting. It would be like a holy shit, and maybe one around my penis for that illuminating experience a girl has hahahaahahahaah
"How many times is Biden gonna say something stupid?" -Barack Obama (2008) ▼▼▼▼
"And Neal Smith, an old butt buddy, are you here Neal?" -Joe Biden (2/12/15)
TazRango is offline
post #8 of 10 Old 09-13-2008, 10:24 PM
StompinGround
Quoted: 20 Post(s)
Don't know if the Charger would have the same setup as the Front Shaft on a Durango , but even if there was a pin to locate the 2 pieces in question pulling the CV-Joint mounting plate away from the Transfer Case Coupler should also disingage the pin . Like I said , highly doubtful there is a locating pin there anyway , mine just had 6 or 8 bolts holding the unit on at Transfer Case .
post #9 of 10 Old 09-14-2008, 04:23 AM
TazRango
Jersey Boy
TazRango's Avatar
Quoted: 243 Post(s)
He says the flange spins when he tries to move it. So that says to me that it's free, not frozen. It really sounds like there is a pin.
TazRango is offline
post #10 of 10 Old 09-15-2008, 03:23 AM
jmac2000dge
There's about a 1/8-1/4" lip so it seats inside the front flange.....if your driveshaft won't collapse when using a pry bar....then the slip part is seized.......what i needed to remove mine for a new centering ball, i just used a c-clamp and remove the u-joint closest to the front...cause my driveshaft wouldn't collapse at all either.....hth..
2000 D, SLT+, 4.7L, Platinum w/leather
5 Door Whore #43.. :biggthump
jmac2000dge is offline
