Dying at Idle - Dakota Durango Forum
2.5L/3.7L/3.9L Engines Questions regarding the I4 and V6 Engines
post #1 of 10 Old 02-03-2007, 04:02 PM Thread Starter
DakWithCheese
SOLD
Vehicle: 1999 Dakota Sport "SOLD"
Send a message via MSN to DakWithCheese
Arrow Dying at Idle
hey guys, my dad needs help bad! He has a 1994 Dodge Van B150 3.9L and its the middle of winter here. He goes to a stop sign, and it just slowly revs down, and then dies. we replaced the coolant temperature sensor already. I'm thinking Idle Air Control Valve. can anyone help??? need ideas!
I know its not a dakota, but I'm still hoping you guys can figure this out.
Thanks!
PERFORMANCE MODS: 3.9L V6
SUPERCHIPS, Fastman TB, K&N FIPK II, Gibson Stainless Headers, Magnaflow Muffler
DakWithCheese is offline
post #2 of 10 Old 02-03-2007, 07:10 PM
Kota04SXT
I Heart SinCityR/T
Kota04SXT's Avatar
Vehicle: 04 Dakota SXT
Send a message via AIM to Kota04SXT
Sounds like an IAC problem, have 3.9's at work all the time that have the IAC shit out that way.
04 Dakota Reg Cab 2WD - 3.7 - 5 Speed - 3:55's - K&N Drop In - Removed Clutch Fan - Magnaflow Exhaust
Crystal Clear Headlight + Corners - 8000K HID's - 3/4 Drop - 35/20% Tint - Custom Tailgate Stripe - Black Euro Tails - Xenon Roll Pan
Kota04SXT is offline
post #3 of 10 Old 02-04-2007, 06:05 AM
KotaSport
KotaSport's Avatar
Vehicle: 2000 Dodge Durango
Modifications: removed 3rd cat, glasspack exhaust, removed clutch fan, CAI, trans cooler, sony deck, mtx 12" 5500, rockford 1300W amp, westin light bar, T/S lift, tail light guards, more work on the way.
Send a message via AIM to KotaSport
I have a 00 dak 3.9 V6... Mine doesn't die when it lowers, BUT you can tell and feel it trying to die, almost does die some times...
Would that be the IAC too(Whats an IAC?..)
00 Dakota 3.9l spd-sold
00 durango 4x4 4.7l-sold
95 ram 5.2l-sold
96 ram 5.9l v8
01 dakota v6-v8 coming soon
KotaSport is offline
post #4 of 10 Old 02-04-2007, 06:12 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
IAC is for Idle Air Control (motor)....it's on the throttle body. Computer tells it where to be for preferred idle. Could possibly be gummed up. Try cleaning or replace. (some are not cheap) Best to hook up scanner and see what it's doing before throwing money into just changing out parts.
Bryan
Little Blue Guy is offline
post #5 of 10 Old 02-04-2007, 09:14 PM
Daktari
can also be...
a dying battery. Especially in winter as it is hard on batteries with the cold. A battery not putting out full juice to the computer will mess up fuel settings. Mine would die at stop signs unless I kept my foot on the gas and the other on brake to keep the revs up, which was keeping a charge going I deduced. It also wouldn't keep running when I first started it either unless I did the gas shuffle. lol After a new battery was dropped in the problem disappeared. At first I thought the choke was out of whack and was ready to take it to the dealer. But when the battery was dead one morning I just figured I'd replace it since it was 4 yrs old. And voila! Problem solved!
Daktari is offline
post #6 of 10 Old 02-05-2007, 05:56 AM Thread Starter
DakWithCheese
SOLD
well, I cleaned off the IAC and problem appears to be solved......for now. I'll keep an eye on it and inform of any changes. My guess was the IAC as well. Guys, if the IAC is your problem too, do the cleanup before you think about dropping any coin into a new one. In this case, a new one would cost ~47.00. Cleaning costs whatever a can of carb/choke cleaner and rags cost.......so not much. This one was clearly gummed up (black). What causes that anyways, doesn't just air pass thru that??? Strange.
post #7 of 10 Old 02-07-2007, 04:10 PM Thread Starter
DakWithCheese
SOLD
problem NOT solved
well, the problem recurred. Van dies again at stop signs. Runs really ruff. Cleaned the IAC and it worked for awhile. Doesn't make sense. Could it really be the battery? Gonna replace the TPS today.
post #8 of 10 Old 02-09-2007, 06:29 PM Thread Starter
DakWithCheese
SOLD
WELL, van is still dying, and running rough even after changing the IAC with a NEW one. I'm running out of ideas. I did the new IAC instead of a new TPS, thinking it was more closely related to the problem. Any ideas anyone? The battery is running strong, shouldn't be that.
post #9 of 10 Old 02-09-2007, 06:43 PM
realdeal7369
G.F.Y racing president
realdeal7369's Avatar
Vehicle: 2005 dodge magnum rt
Modifications: Cold air intake.
Send a message via Yahoo to realdeal7369
spray the tb down with a good cleaner. just for giggle, see if that helps. if it dont, your only out 1.29
1997 dakota, 5.2v8, msd wires, trans cooler, K&N cai, 1.6 rr's, stinger 1700 battery, updated big 3. aeroturbine 3030 muffler, high flow cat. conv
realdeal7369 is offline
post #10 of 10 Old 02-22-2007, 07:31 AM Thread Starter
DakWithCheese
SOLD
Arrow
well, chew on this. I did a tune-up for him, which apparently was the first in 117k mi!!!!!!! i'd say he was "overdue". ironically enuf, it runs better now
