check gauges light - Dakota Durango Forum
post #1 of 12 Old 01-20-2007, 05:20 AM Thread Starter
MoPower
5.9L or bust!
MoPower's Avatar
Vehicle: '00 Durango SLT AWD 5.9
Modifications: 2" T/S LIFT, Mopar Perf comp,K&N, Pro-flo Muffler,tint, stereo,HID lights
Send a message via Yahoo to MoPower
check gauges light
My 99 Durango decided to pop up with a "check gauges" light and then went off shortly after. This has only happened twice in the past month or so. The last time it did this my oil pressure gauge went to zero and then back to normal operating pressure. Has anyone had similar problems or know what is causing this???It seems to be runnning perfect other than that.thanks!!!
5.9L = 36D...THAT SOUNDS NICE!!
5 DOOR WHORE #6
MoPower is offline
post #2 of 12 Old 01-20-2007, 05:25 AM
ucimaplaya2
ucimaplaya2's Avatar
could be just a glitch somewhere between the sending unit and the computer or computer to gauge cluster, OR you wouldnt' have happend to be braking when that light popped up would you?
John
ucimaplaya2 is offline
post #3 of 12 Old 01-20-2007, 05:31 AM Thread Starter
MoPower
5.9L or bust!
MoPower's Avatar
both times I was braking.Could this be the problem u think??
5 DOOR WHORE #6
MoPower is offline
post #4 of 12 Old 01-20-2007, 05:33 AM
ucimaplaya2
haha go check your oil level...
John
post #5 of 12 Old 01-20-2007, 05:36 AM Thread Starter
MoPower
5.9L or bust!
MoPower's Avatar
U think it might be low and this is causing the light to come on?? It's never had low oil levels and done this before. thanks, I'll check it out!
5 DOOR WHORE #6
MoPower is offline
post #6 of 12 Old 01-20-2007, 05:40 AM
ucimaplaya2
and then when you find out its low, remove your air intake and with a flash light (and the motor off of course) open the throttle body to full throttle and look at the bottom of the intake manifold. If you see a puddle of oil you have a blown plennum gasket causing you to slowly burn oil without notice. now if all you see is a light and kind of dirty film-like coating on it then its normal. but if there is some significant oil spots or a pool of oil then its blown.
John
post #7 of 12 Old 01-20-2007, 11:34 PM Thread Starter
MoPower
5.9L or bust!
MoPower's Avatar
I checked it and it was 3 qts. low. I have been driving up to the snow quite a bit and going about 80 mph. I thought that may be a reason for the oil consumption. I'll check out the tb.thanks for the advice!
5 DOOR WHORE #6
MoPower is offline
post #8 of 12 Old 01-25-2007, 07:56 PM
Raven
Vehicle: 1999 Durango SLT+
Modifications: Working and Raising a Family
That sounds very familiar! I would put money on the plenem pan gasket!
Do a search and you will find that you are far from alone on that one!
Five Door Whore No. 21
___________________________________________
1999 Durango SLT+ 4x4, 5.9, black on silver leather.
3" polished SS Magnaflow system including CAT
AEM intake, Superchips, SS grille, Stillen Bumper Cover, Diamond Clear headlights, Euro Tail lights, Lund stuff, AVS stuff, lot's of stuff!
Needs gas!
Raven is offline
post #9 of 12 Old 01-26-2007, 04:24 AM Thread Starter
MoPower
5.9L or bust!
MoPower's Avatar
thanks!! I looked at it and there was fresh oil down there. Had the gasket replaced and it runs even better now!! Idles smoother and no more pinging !! I can't believe Dodge doesn't recall this, there are so many that have had problems like this!
5 DOOR WHORE #6
MoPower is offline
post #10 of 12 Old 01-26-2007, 04:31 AM
ucimaplaya2
sorry you had to shell out the money to get that fixed. i know it wasn't cheap. but atleast its running good now.
John
post #11 of 12 Old 01-26-2007, 04:41 AM Thread Starter
MoPower
5.9L or bust!
MoPower's Avatar
I had the gasket replaced, thermostat ,and idler pulley all done for $550. I had a Robert Shaw 180 thermostat in there and the mechanic put a 195 back in. I was thinking of changing it to a 195 anyway because the heater doesn't work for shit. I didn't notice any problem with the programmer with this thermostat. whatcha guys think, switch to 180 or leave it??
5 DOOR WHORE #6
MoPower is offline
post #12 of 12 Old 01-26-2007, 03:36 PM
Daktari
heat em' up
My 99' Dak's heater doesn't work worth a hoot either and it's only got 43,000 miles on it. My Durango has 95,000, has more interior room to heat up and it bakes me. lol
Daktari is offline
