Ever replace a hydraulic lifter/tappet? - Dakota Durango Forum
5.2L/5.9L/6.7L Engines Questions regarding the 5.2L/5.9L/6.7L V8 Engines
post #1 of 6 Old 01-19-2007, 03:28 AM Thread Starter
oneoff99
Vehicle: 99 CC Dakota 5.2 2wd Auto
Hey guys, I'm new here, but have had my 99 Dakota since new. I've run into a little trouble here and hope some of you might have some words of wisdom.
I've come to the conclusion that i have a collapsed lifter ---so I'm going to replace them all. I'm running 1.7 adjustable roller rockers and have had a hell of a time adjusting them which led to my discovery of the problem.
Here's where I'm at: I pulled off the M1 (to replace w/ my beer barrel) and removed the yoke retainer and lifter yokes. Now, I can slide the lifters up and almost out of the block -BUT-- they run into the head gasket before I can get them clear. My factory shop manual says something to the effect that I should run the removal tool through the head, into the lifter and pull it out. Unfortunately the holes in the head gasket are only large enough for the pushrods. Neither the tool or the lifters can get through.
What have you guys done to remove these things? Thanks!
oneoff99 is offline
post #2 of 6 Old 01-19-2007, 02:52 PM
razman131
Home Owner....
razman131's Avatar
Vehicle: 1999 Dakota R/T
Modifications: to many to list, plus standard bolt ons and suspension mods.
Send a message via Yahoo to razman131 Send a message via Skype™ to razman131
welll.... they should just come out. no need to pull the heads off to change lifters.
i am confused tho... going from M-1 to a BB?? most of us go BB to M-1...
gotta pull manifold
pull rockers/rods
then remove the spyder keeper in the oil valley
should just come right out. the lifters are only like 3 inches long so how they head gasket gets in the way is baffeling
razman131 is offline
post #3 of 6 Old 01-19-2007, 08:46 PM Thread Starter
oneoff99
Yes, I know -it's crazy. I'll try to post a pic here in a few minutes. In the meantime imagine this....looking into the engine valley from the front of the engine, the retainer and yokes are pulled and the lifters are free to slide out. As you try to slide the lifter out,the pushrod end comes in contact with the head gasket. Now the gasket has a about a 3/16" gap between itself and the head as this point. The lifter will come out to just before the roller has cleared the bore ---so it's close but no go. If the holes in the head gasket were large enough to allow the lifter to move up into the head jus a 1/4" more it would be a no brainer-----I'm stumped. I'l see if I can get a pic up here.
Regarding the manifolds....... I just lost too much low end torque. It really helped say 2800 and up, but that's just not where my engine lives 95% of the time. I'll hit 3000 every so often and w/ 4.10 gears I curise at about 23-400 For my needs the beer barrel w/ cut runners will be more appropriate I think.
oneoff99 is offline
post #4 of 6 Old 01-19-2007, 08:48 PM
Danno
Your in-house Mopar guru
Just push up on the head gasket in that area. The stock gaskets really interfere with pulling the lifters out, but it can be done Ive done it many times. So just get your fingers in there and push the gasket up into the head area tighter, and the lifter will then have enough room to come out. You might end up having to tip it slightly as it nears the top to get it to come out cleanly.
Danno
99 BK RC 12.02@109 AKA Vader
98 IB RC 13.59@102
98 DA CC 11.59@118 AKA Barney
05 SRT6 Roadster 13.51@105
70 Road Runner
Danno is offline
post #5 of 6 Old 01-19-2007, 09:22 PM Thread Starter
oneoff99
Well, I haven't figured out the pic posting thing yet, but it sounds like you know my exact situation. I had thought of that but was not comfortable with starting to mash around with the headgasket. I can't tell you how happy I am to hear that you've done this sucessfully. COOL I just couldn't believe that the heads were gonna have to come off to replace the lifters!!
I'll give it a shot and let you know how things go ----Thanks Danno!
oneoff99 is offline
post #6 of 6 Old 01-19-2007, 09:23 PM
Danno
Not a problem!
Danno
98 IB RC 13.59@102
70 Road Runner
Danno is offline
