'99 Durango- Cranks but wont start - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
post #1 of 15 Old 11-25-2006, 12:03 AM Thread Starter
Booda
Vehicle: '99 Durango SLT/ 5.2ltr
'99 Durango-Wont start- UPDATE!
Cleaned the battery terminals and flushed the radiator today.
Had it started a few times after the work was done.
I can hear the fuel pump kick in, and pulled a plug wire and there is spark.
Its just cranks and cranks.
Will the crank sensor or cam sensor still allow fuel and spark if either is bad?
Thanks-
Jeff
Booda is offline
post #2 of 15 Old 11-25-2006, 11:24 AM
Blu-R/T-Du
Just Me
Blu-R/T-Du's Avatar
Vehicle: 00/Dodge/Durango R/T
Crank sensor
I believe the crank sensor will, 'cause that is what I am getting replaced on my Ram. It did the same thing, just cranked but would not start.
Blu-R/T-Du is offline
post #3 of 15 Old 11-25-2006, 01:38 PM
rockadaous
mod-a-holic
rockadaous's Avatar
Vehicle: 1999 Durango SLT + 4X4
Modifications: Working on truck and GSXR
are you still running OEM battery? If so change it. it's done.
If it's a new battery
will it crank if you hold the gas down? If so it's your IAC sensor. it sits on the back of your throttle body. 2 torx screws.
rock 5 Door Whore #5 (Fo Sho)
99 Durango SLT+ 4X4
Interior mods
Lotek gauge pod*redline shifter*nu-image panels*rev glow gauge w/chrome bezel*billetpro knobs*titanium pedals
Exterior mods
Cervinis SS Hood*Keystone spoiler*billet gas door*MB Motoring 20X10*Eagle Goodyear GT II*SS speed grille*vent visor*chrome altezza's*Euro diamond cut headlight & parks,chrome differential cover
Engine mods
Intense Performance stage II w/9" bigmouth filter*180 T-stat*billet caps*mopar valve cover*GSport hose*40 series Flowmaster w/duals*reflexx shocks
http://cardomain.com/id/durang0
rockadaous is offline
post #4 of 15 Old 11-25-2006, 04:34 PM Thread Starter
Booda
Battery is good. Even pulled one from one of my other cars.
I cant get a crank sensor till Tuesday.
My FSM says to test crank sensor with the DRB. So thats out.
That bugger looks like its in a fun spot too.
I hate to start tossing parts at it.
Booda is offline
post #5 of 15 Old 11-28-2006, 06:05 PM Thread Starter
Booda
Replaced the crank sensor and the cam position sensor under the distributer cap.
No luck.
The fuel pump is coming on.
Pulled a plug wire and checked for spark with spare plug. Good.
There is pressure at the fuel rail schrader valve.
I tested the injectors with a spare and they appear to be working.
Even sprayed ether into the throttle body to no avail.
Any other suggestions?
Thanks-
Jeff
Booda is offline
post #6 of 15 Old 11-28-2006, 06:59 PM
realdeal7369
G.F.Y racing president
realdeal7369's Avatar
Vehicle: 2005 dodge magnum rt
Modifications: Cold air intake.
Send a message via Yahoo to realdeal7369
Thanks-
Jeff
coil pack is bad. i had the same thing happen to mine. seems this is a major problem for the magnum motors. replace this first, see what happens. it may be an intermitten thing with the coil. pull the number 1 plug out, and have someone crank it, see if the spark comes through. if so, it aint the problem, and on goes the search. my bet elsewhere would be the crank, or the cam sensor. and i hope that the issue is with the crank sensor, cause the cam sensor is a pain in the ass, nevermind more costly to change.
1997 dakota, 5.2v8, msd wires, trans cooler, K&N cai, 1.6 rr's, stinger 1700 battery, updated big 3. aeroturbine 3030 muffler, high flow cat. conv
realdeal7369 is offline
post #7 of 15 Old 11-28-2006, 07:10 PM
viperkota
Mods Addict
viperkota's Avatar
Vehicle: nope
guessing that you dont have a 4.7.....and i'm not too familiar with the other motors...but if it has it check the TPS sensor (throttle position sensor)...it may have gone bad or just needs to be re adjusted back within its tolerances
i know on the 4.7's that is its out of its voltage range the same will happen
viperkota is offline
post #8 of 15 Old 11-28-2006, 07:24 PM Thread Starter
Booda
THanks for the suggestions. I have the 5.2 engine.
I do have spark to the plugs, at least some spark it seems. The coil was my first thought.
The crank sensor cost me $75 and the cam sensor was $42.
Still no luck.
If someone lives in the West Michigan area, and would let me borrow a PCM, maybe I can rule that out also.
Jeff
Booda is offline
post #9 of 15 Old 11-28-2006, 07:51 PM
durangotrkrt
durangotrkrt's Avatar
Vehicle: 2005 Chrysler 300C Hemi
Modifications: My Truck, boats, bikes
Send a message via AIM to durangotrkrt Send a message via Yahoo to durangotrkrt
So you said there is fuel pressure at the rails. Are the injectors opening when starting? If they arnt then thats a PCM thing i think
SOLD 02/2009 : 2000 Dodge Durango R/T (I miss the truck big time, will have to buy another one eventually)
Currently: 2005 Chrysler 300C HEMI 5.7L Black
2009 Honda CBR600RR Black/Silver
durangotrkrt is offline
post #10 of 15 Old 11-28-2006, 09:45 PM
realdeal7369
did you try starting the truck with the accelerator pressed to the floor for a moment? up till it starts, then let it go? i did this the other day and mine woke right up...later on though it went completely bad, and my coil pack was bad....
just a thought.
post #11 of 15 Old 11-28-2006, 09:58 PM
maddest_hatter
MOPAR or NO CAR!
maddest_hatter's Avatar
Vehicle: 2003 Durango R/T
Modifications: Valve covers, rotor, wires, plugs, battery, air intake
Send a message via MSN to maddest_hatter Send a message via Yahoo to maddest_hatter
4.7s were not an option for the 98 and 99s.
98 = 5.2
99 = Some V6 (I think), 5.2 and 5.9. V6s in a Durangos are useless! IMO
If your 99 is an SLT it has a security system that cuts the engine out if it activated. Try starting it up sith your foot on the gas. If it starts that means your security system is engaged.
I have found turning it on with my foot on the gas gets it started. Run it that way for a minute then turn it off. Then usse your keyless entry to lock and unlock it. Then try starting it again. It should start up. Keep foolin with the security till she runs. This happens a lot to mine when the battery gets disconnected or is loose.
The best things in life have R/T written on them! Five Door Whore #138
maddest_hatter is offline
post #12 of 15 Old 11-29-2006, 05:15 AM
colombiapunk
Denver Durango
Vehicle: 1998 5.2 Dodge Durango with mods growing by the day
ok, dumbest suggestion yet, but it happened to me. If you've taken the distributor out recently, check and make sure you didn't put it 180 degrees off.
I did that to mine, I had spark, I had fuel pressure, I had no warnings from the computer. Everything seemed fine, but it would jsut crank for ever.
Flipped that sucker around and sure enough it started fine.
Just remember to drain the fuel out first. Mine was flooded because it was pumping fuel. Same scenario as you, tied to start it by putting down the tb, and nothing. It was jsut the distributor.
good luck. remember drain the fuel!
1998 Dodge Durango
5.2lt to a GM 14 Bolt with Spool 4.56
MSD ignition and wires
51mm Throttle Body SPAL fans 1.7 HS RRs
Holley Hi-Tek Intake with K&N's
NO A/C! But a Viair w/tank to take care of those tires
37"s and all aorund 24" travel with sway a way coils
High Flow cat and 3" exhast/long hedders
1985 Ramcharger
MSD ignition, distributor, wires, comp cam,
14x4'' intake 4.56 and 35"s
colombiapunk is offline
post #13 of 15 Old 11-29-2006, 07:26 PM Thread Starter
Booda
Well, got it figured out.
It WAS the coil.
Reason I didnt think of it was the engine would try to fire every couple revolutions. Like it was flooded or the injectors were not in time with the spark.
Guess I have a couple spare used parts that are good.
Oh yea, it has been raining like crazy here and my Durango was parked off the drive in my side yard. So I ended up laying in the water and mud to swap the crank sensor. My tarp didnt help much! What a mess.
I wanted to say thanks to those that offered their help and support.
(Now to get my jumper cables out of the tree in my neighbors yard!)
Thanks!
Jeff
Booda is offline
post #14 of 15 Old 10-12-2014, 10:47 PM
toyotaman
Cool dodgeman954
2000 durango 5.9 went to move started for a min then stalled out, now will not start. changed rotor and cap, checked gas pressure, and pulled coil wire off distributor and has spark. it cranks but no start? what to do?
toyotaman is offline
post #15 of 15 Old 10-14-2014, 03:28 PM
Arisley
Reformed Redneck (Sorta)
Vehicle: 2003 Dodge Durango
Modifications: Bone stock
Toyotaman.
You need to start your own thread. Don't piggyback on someone elses.
Arisley is offline
