thermostat positioning - Dakota Durango Forum
2.5L/3.7L/3.9L Engines Questions regarding the I4 and V6 Engines
post #1 of 6 Old 10-12-2006, 02:52 AM Thread Starter
remme
which way does the thermostat sit in the engine..i tried following the picture but....it was hopeless, im not mechanically inclined at all...pictures would hep..thanks guys
remme is offline
post #2 of 6 Old 10-12-2006, 03:32 AM
93dakota
Vehicle: 93 Dakota, 93 Festiva(daily beater)
Modifications: playing guitar,working on the truck,crusing
it sits up front inside of your radiator hose, i think
1993/Dakota/V6/3.9/ cold air intake/JBA headers/2 1/4 dual exhaust, balance pipe, no cats, super 40's, 3 turndowns at rear end/Venom 400 chip/Underdrive Pulleys
394 stroker being built in the garage
93dakota is offline
post #3 of 6 Old 10-12-2006, 03:56 AM Thread Starter
remme
yea its sorta next to the alternator, im talking about which way does it sit in the engine itself. i put it in, the way i thoguht it was supposed to face and the seal held until the engine hit 210 and then it just started spuing coolant..so im figuring either the gasket was bad or the thermostat just didnt open, or both ha thanks tho
remme is offline
post #4 of 6 Old 10-12-2006, 02:11 PM
dave2003
Site Supporter
dave2003's Avatar
Vehicle: 2000 Dakota Sport CC
Modifications: 360 Power Shot Intakez, V6 modified TB, HS 1.7 RR's, Superchips
Quoted: 5 Post(s)
The thermostat should have an arrow or some marking on the top of it that you point towards your radiator. That is the way i've put in the last couple i've gotten.
2000 Dakota CC 3.9L 5SPD Man
180* T-Stat, 360 Power Shot IntakeZ, bwdakrt modded V6 TB, Superchips 3715, HS 1.7 RR's , Black Magic 180 Extreme Fan (Clutch fan kicked to the curb!), Summit 8mm Wires, NGK 4291's, EBC Sport Rotors & Hawk Pads, Infinity Reference 6020CS & 6022SI, AMI Locking Fuel Door, Diamond Clear Corners with LED headlights and LED fog lights.
dave2003 is offline
post #5 of 6 Old 10-13-2006, 07:18 AM
WiLieR
Vehicle: Gen-II Dakota
the spring portion of the t-stat sits in the block itself. if you look at the t-stat from the side it will resemble an arrow -|> place it in the block so it points towards the radiator.
WiLieR is offline
post #6 of 6 Old 10-13-2006, 07:59 PM Thread Starter
remme
Ok, Ha, It Wasnt The Thermostat I Got Tat Correct, Dummy Me Forgot I Drained Most Of The Coolant Out, Ha Note To Self : Your Engine Will Over Heat Without Coolant No Matter What Degree Thermostat You Have Installed. Thanks For All The Replies...
remme is offline
