4.7 blown head gasket - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
post #1 of 16 Old 11-25-2012, 08:51 PM Thread Starter
Sweeney
Vehicle: 2001 Durango
Modifications: Cai, BBK BBTB, Superchips, Exhaust
Im considering trading one of my trucks i have for a 00 dakota 4.7 2wd. The guy said it overheated and now blows white smoke.. Would you say head gasket or possibly head related?
Sweeney is offline
post #2 of 16 Old 11-25-2012, 09:00 PM
WRXCarl
\_(ツ)_/
WRXCarl's Avatar
Vehicle: 89 Shelby Dakota
Garage
What will you be giving him in the trade?
1989 Shelby Dakota #1319 - Sold
1991 Dodge Dakota 318 4x2 - Sold
1995 Dodge Dakota 318 4x4 -Sold
WRXCarl is offline
post #3 of 16 Old 11-25-2012, 09:12 PM Thread Starter
Sweeney
87 f150 2wd v8
Sweeney is offline
post #4 of 16 Old 11-26-2012, 12:51 AM
moparman_2004
moparman_2004's Avatar
Vehicle: 2004 Dodge Dakota SLT
Modifications: H.O. cams, sct tunner, fastman throttle body, gibson headers flowmaster exhaust, working on a leather interior, halo headlights, led taillights, ultra 240 retro wheels, cai, sonnax, power wire, cervinis ram air hood, A pillar, polished valve covers,
Quoted: 2 Post(s)
Send a message via Skype™ to moparman_2004
well head gaskets alone will run you about 800 in labor plus parts just fyi
First to do 2008 cams, 4.6l Trick flow lash adjusters, Fastman Throttle Body, Gibson Headers, Flowmaster Exhaust, Power Wire, Sonnax, 2008 intake, Balanced #24 Ford Racing Injectors, Jet 180 Thermostat, SCT Tunner by Hemifever, Custom Valve Covers, Cervinis Ram Air hood, innovative A/F Gauge, halo headlights and blacked out tails, Street Scene Grilles, billet fuse box,mm oil-tranny knobs, shaved tailgate, ARP head studs, cometic head gaskets,billet oil cap/ battery strap, comp cams valve springs, KRC billet fuel rails
moparman_2004 is offline
post #5 of 16 Old 11-26-2012, 09:02 AM Thread Starter
Sweeney
Gaskets are 35 bucks, costs about 40 to get the heads checked and cleaned, and i am mechanically inclined enough to do the labor myself.
Sweeney is offline
post #6 of 16 Old 11-26-2012, 10:03 AM
SH0K0TA
Layin Low
SH0K0TA's Avatar
Vehicle: 1997 Dakota Sport
Modifications: Custom Diamond grille, Halo Headlights, replaced bumper for chrome bumper, chrome fender flares, side mirrors, roll pan and air dam ordered, subs, speakers, and blue neon lights
Send a message via AIM to SH0K0TA
I'm not doubting your ability to do the headgasket...
But the 4.7 has cam over head and had a total of 3 timing chains that are all connected.
It is a total PITA to do the headgaskets on one. That's not counting the tensioners that require "grenade pins" to hold them all the way back... and there is a specialty tool that holds time on all 3 chains.
SH0K0TA is offline
post #7 of 16 Old 11-26-2012, 04:41 PM
moparman_2004
Quoted: 2 Post(s)
Well if needed a have the head gaskets exhaust water pump gaskets that came out of a complete gasket set I have that I done need the rest can be reused
post #8 of 16 Old 11-26-2012, 09:02 PM
01Dak4.7
01Dak4.7's Avatar
Vehicle: 01 Dodge Dakota
Modifications: SCT,h.o. cams, 08 intake manifold,F&B 72mm, ATI underdrive pulley,gibson headers,3.92w/lsd,Zex nitrous kit,centerforce clutch,summit traction bars
Quoted: 3 Post(s)
Im sure they do make a special tool, but setting timing on a 4.7 isn't that hard, did it myself in the driveway with a few zipties and bungee cords and another person to help me was all I needed. I almost think you can pull heads off a 4.7 without removing the timing cover jus don't allow the chain to jump off the cam gear once the cam unbolted from the cam gear I don't see why the cylinder heads can't be removed, but I could be wrong
01Dak4.7 is offline
post #9 of 16 Old 11-26-2012, 10:03 PM
SH0K0TA
Layin Low
SH0K0TA's Avatar
you can do it that way. but you need these triangle looking things to make sure the tensioners don't pop the chains off and then adjust themselves all the way out.
SH0K0TA is offline
post #10 of 16 Old 11-27-2012, 12:38 AM Thread Starter
Sweeney
As far as specialty tools go, i can make them. I have done several different head gasket changes on ohc engines. Its all a matter of the approach to be honest. But it appears that the guy backed out at the last minute anyways.. Thanks for all the comments and help tho
Sweeney is offline
post #11 of 16 Old 11-27-2012, 01:59 AM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Vehicle: 2002 QC RAM 4.7L *SOLD*
Modifications: 2011 Grand Sport Corvette :)
Quoted: 6 Post(s)
Guys before we get some mis information out...
NO you cannot remove the heads without removing the front cover... at least CORRECTLY..
Your guides are attached to your heads... and your tensioners are pressing on the guides... the wedge tool is designed to pressure the chains to the guides within the head... Once you move the head there is no way to keep tension on the guides and or prevent your tensioners from fully extending.
You will need to remove the front cover and rig up some Zip ties to hold the two cam chains from falling off of the idler sprocket in the center...
You will also need to zip tie the cam sprockets to the chain...
once the heads are removed you will need to reset your tensioners by compressing them and installing a pin or paper clip into the hole. This is easiest when done in your hand so removing the tensioner completely will actually make it easier.
If you do not remove the front cover your tensioner will fully extend... and you also risk losing time of your cam chains and idler sprocket... Its just easier to do it right...
SPEED SAFE, AIR RAM
AIR_RAM is offline
post #12 of 16 Old 11-27-2012, 03:28 AM
01Dak4.7
01Dak4.7's Avatar
Quoted: 3 Post(s)
I had forgot about the chain guides that are bolted to the heads, but yea the tensioners would over extend I actually had wound up using small nails to hold mine in place when I reset my tensioners. Anyways def all good information for anyone attempting to remove heads or reset timing etc.
01Dak4.7 is offline
post #13 of 16 Old 11-27-2012, 05:35 AM
Cloned_R/T
Cloned_R/T's Avatar
Vehicle: 2003 Dakota Sport RC
Quoted: 9 Post(s)
Send a message via AIM to Cloned_R/T
Reading all this makes me extremely nervous about blowing a head gasket now.
Mike Zadler
Dart Rallye 1.4L Turbo (new daily driver)
2000 3.9L CC Sport (Sold)
2003 4.7L RC Sport (Sold)
Mods to the 2003 4.7:
Gibson Headers, Magnaflow cats, Magnaflow mufflers, Shaker hood intake with airraid filter, Superchips Programmer 3715, Mopar LSD unit with 3.92 gears.
Previous Personal Best: 15.304@87.25 7/5/11
New Personal Best: 14.993@88.93 4/12/12
Cloned_R/T is offline
post #14 of 16 Old 11-27-2012, 05:51 AM
moparman_2004
Quoted: 2 Post(s)
ya i didnt even wanna screw with mine so im taking mine in
post #15 of 16 Old 11-27-2012, 07:55 PM
01Dak4.7
01Dak4.7's Avatar
Quoted: 3 Post(s)
the timing on the 4.7 can look intimidating but its not bad at all once you do it, funny part bout when I did get mine fixed guy at the dealership couldn't believe I did it on my own. but ive gotten kinda used to that these days older people don't think young guys know how to do much these days
01Dak4.7 is offline
