[HOW TO][BRAKES] Replacing Front Pads and Rotors - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
post #1 of 28 Old 10-11-2012, 10:47 PM Thread Starter
BigJay55
Condoms prevent minivans
BigJay55's Avatar
Vehicle: 2002 Durango SLT+
Modifications: 2002 HO Intake manifold, K&N FIPK, E-Fan, Gibson SSCC headers and cat-back exhaust, SCT by Hemifever
Garage
This is how to replace your front pads and rotors on a Gen I Durango 4x4. This may also be pertinent to other trucks (Dakotas, R/Ts, 2wd trucks) but you'll have to check.
As always, use your head and be safe! Proper prep and precautions means you end the day alive and in one piece.
Parts Required:
  • 1 pair rotors
  • 1 complete set of pads
  • 1 tube of high temp brake lube
  • 1 tube high temp silicone slider grease
Tools Required:
  • 1 3/4" socket (1/2" drive)
  • 1 7mm hex Allen socket (3/8" drive)
  • 1 Johnson (breaker) bar (1/2" drive)
  • 1 3/8" drive ratchet
  • 1 3/8" drive torque wrench (ft/lbs.)
  • 1 long flathead screwdriver
  • 1 large C-clamp
  • 1 can brake cleaner
  • 1 caliper painting kit (Optional - if painting calipers)
1. Clean and open master cylinder reservoir.
2. Loosen lug nuts using Johnson bar, but do not remove.
3. Raise and support truck. If not using a lift, support truck using jackstands and chock the rear wheels.
4. Remove lug nuts, remove wheel/tire.
5. If painting, now is a good time to clean the calipers using paint kit.
6. Using the 7mm hex Allen socket and 3/8" drive ratchet, remove the 2 slide pins that hold the caliper onto the knuckle. They are on the inboard side of the calipers, and are sunk into deep rubber grommets.
7. Using the screwdriver, gently pry the caliper spring off the outboard side of the calipers. WARNING - They are under tension, so they will pop and fly. Be careful!
8. Using the screwdriver again, gently (from the top) pry the caliper and pads away from the rotor. You should have the screwdriver pointed toward the rear of the truck, resting on the edge of the rotor. DO NOT LET CALIPER HANG BY THE BRAKE LINE! Either place it behind the rotor, or wire it up using wire or a coathanger.
9. Remove rotor by pulling it straight off the studs.
(Note: There may be round discs on the studs holding the rotor in place. These can be pried/cut/broken off and omitted on reassembly.)
10. Remove the pads. On the outboard, use the screwdriver to pry the spring off one side of the caliper and slide it down. The inboard pad just pulls straight out of the piston dish.
11. Using the C-clamp, press the piston back into it's bore.
(Mod Note: It is best to use a block of wood or the old brake pad between the piston and C-clamp. Phenolic pistons can get brittle and they can crack if you use the clamp directly on the piston.)
12. Install new rotor by sliding it onto the studs. Avoid touching the contact surfaces as much as possible.
13. Install inboard pad by pressing springs into the piston dish.
14. Install outboard pad by sliding spring clamp over outside of caliper and pushing up into caliper. Note - a slight film of brake lube makes this easier.
15. Lube slide pins with high temp silicone slider grease. DO NOT use regular petroleum-based grease!!
16. Lube adapter plates with high temp brake lube, then slide caliper/pad assembly onto rotor.
17. Install slide pins using 7mm hex Allen socket. Torque to 22 ft/lbs.
18. Install the caliper spring. This can be tricky - use your screwdriver and some patience, but make sure it's seated properly.
19. Give the rotor a little blast of brake cleaner and wipe it off with a clean rag.
20. Reinstall the wheel/tire, lower truck, tighten lugs. Close master cylinder reservoir.
21. Follow the manufacturer's recommended bed-in procedures.
22. Clean up!
Note - If painting (like I did) paint the caliper AFTER installation. Just be careful to not get any paint on the rotor, bleeder or pads.
[/SIGPIC][/SIGPIC]5 Door Whore #236
.020" over rebuilt 4.7, H/O cams and intake
Gibson SSCC headers, Gibson cat-back system, 180* stat, FAL electric fan, K&N FIPK,
Fastman 70mm TB
SCT by Hemifever
Lowered 2", Bilsteins, 20" Chromes during the summer...
BigJay55 is offline
post #2 of 28 Old 10-13-2012, 04:53 PM
doDgeBoy0211
Vehicle: Durango
Has anyone ever heard of break adjustment?
doDgeBoy0211 is offline
post #3 of 28 Old 10-13-2012, 06:36 PM Thread Starter
BigJay55
BigJay55's Avatar
Garage
Yep. On the rear drums.
Fastman 70mm TB
SCT by Hemifever
BigJay55 is offline
post #4 of 28 Old 10-31-2012, 04:47 AM
Alpine247
Vehicle: 02 Durango
Nice write up! How the EBC Rotor's & Pads compare to stock??
Alpine247 is offline
post #5 of 28 Old 10-31-2012, 05:07 AM
Big_Texxan
American Rebel.
Big_Texxan's Avatar
Vehicle: 2001 Dodge Dakota
Modifications: Some shit that makes it go fast, like really fucking fast
Quoted: 46 Post(s)
Garage
Yes^ i would also like to know.
MANY MANY MODS!!!!!!!
Im from Texas!
Im still right!
Vehicles:
2001 Dakota Quad SLT 4.7. The "Murdered Mopar"
1966 Ford F-100 Restomod, traded a motorcycle for it
Big_Texxan is offline
post #6 of 28 Old 10-31-2012, 05:49 AM Thread Starter
BigJay55
BigJay55's Avatar
Garage
I like 'em. Certainly feels like I have more grab. Only thing I don't like is they are a little noisy. I don't sound like a city bus, but there is a squeal when I first touch the pedal. I release and reapply, it goes away... Until they cool down, then it returns. It's not loud, but it's there.
Fastman 70mm TB
SCT by Hemifever
BigJay55 is offline
post #7 of 28 Old 11-10-2012, 02:00 PM
reyesl
reyesl's Avatar
Vehicle: 2000 Durango
Garage
squealing front brakes
I did the same type of replacement on my Durango, the squealing stopped after I removed the pads...redressed the contact surfaces...replaced pads...No squeals as yet.
2000 Durango SLT
2007 Jeep Liberty
2004 X-Type
2004 Vanden Plas
reyesl is offline
post #8 of 28 Old 11-10-2012, 08:35 PM Thread Starter
BigJay55
BigJay55's Avatar
Garage
how did you redress the contact surfaces?
Fastman 70mm TB
SCT by Hemifever
BigJay55 is offline
post #9 of 28 Old 11-11-2012, 02:58 AM
reyesl
reyesl's Avatar
Garage
The appropriate method is to use sandpaper, sanding disc, scuff disc, or steel wool to remove the glaze. Since I do my repairs on a smooth concrete surface and on my own vehicles…..yes, I just place the pads contact side down and “wax-on, wax-off”.
If the rotors need de-glazing, use sandpaper, sanding disc, scuff disc, or steel wool to remove the glaze. (part of the break-in by some manufactures)
Note: The above methods are for recently replaced Pads and Rotors, on old/worn units, you will most likely need to replace all or some of the components.
2000 Durango SLT
2007 Jeep Liberty
2004 X-Type
2004 Vanden Plas
reyesl is offline
post #10 of 28 Old 01-04-2013, 06:18 AM
mopar_man2013
'00 DakotaSport QC 4X4 V8
mopar_man2013's Avatar
Vehicle: '00 Dakota Sport QC 4.7V8
Garage
Well put together. Thank you.
Can someone do a quality how to equivalent to this for the rear drums? Including determining what size drum (in ").
mopar_man2013 is offline
post #11 of 28 Old 01-04-2013, 12:28 PM
reyesl
reyesl's Avatar
Garage
I have photos of a rear brake job that I will post in a few days. I have to search my computers, don't remember where I saved the photos.
2000 Durango SLT
2007 Jeep Liberty
2004 X-Type
2004 Vanden Plas
reyesl is offline
post #12 of 28 Old 01-14-2013, 06:19 AM
GillaFunk
Vehicle: 1999 V8 4x4 SLT Extended
Quoted: 2 Post(s)
Not to change topic but......I just replaced, basically, my entire front brake system (pads, rotors, lines, calipers, master cyl, booster). My pads are dragging and bleeding doesn't seem to solve the issue.
I didn't know about lubing the adapter plates.
How likely could lubing the plates resolve the issue?
Btw....nice write up. I opted for Wagner heavy duty pads all around, an hd drilled slotted rotors After finding the stock pads insufficient. Hd pads are noticibly an improvement, but the new master cylinder and brake booster REALLY made the difference. With 100k miles, these components seemed to make the most improvement.
rockAuto had the BEST deals on everything.
GillaFunk is offline
post #13 of 28 Old 01-14-2013, 03:31 PM
reyesl
reyesl's Avatar
Garage
Unfortunatly I can not locate the photos and will not be doing another rear brake replacement for another few years.
2000 Durango SLT
2007 Jeep Liberty
2004 X-Type
2004 Vanden Plas
reyesl is offline
post #14 of 28 Old 01-14-2013, 05:39 PM
GillaFunk
Quoted: 2 Post(s)
Really, if you pick up a chiltons guide and do one wheel at a time, you will be fine. I hadn't done drum brakes in about 15 years. Used the Chilton guide, watched a YouTube vid and it was pretty straight forward.
post #15 of 28 Old 01-14-2013, 08:33 PM
Nhshaw75
Nhshaw75's Avatar
Vehicle: 2001 Dakota CC
Garage
Send a message via Skype™ to Nhshaw75
Same here. Not that bad of a job. I did the same thing. Chilton and YouTube. You'll learn pretty quick
V6 2WD Dakota, CAI, minor cosmetic and dress up items.
http://www.builtwithblood.com/forums/index.php
Nhshaw75 is offline
You may not post new threads
