2001 Durango Stalling - Dakota Durango Forum
post #1 of 9 Old 09-21-2012, 09:06 PM Thread Starter
rustynailer
Vehicle: 2001 Dodge Durango SLT4.7
Modifications: None
Hey guys!
Ive been having stalling issues with my Durango recently. I replaced the engine a couple months back with a brand new one. So I don't if that could be an issue. But I notice that once in a while when I put the car in reverse (after coming to a complete stop of course) or overshoot and put it into second, the car just dies. Starts up right a away usual no problems. Its happened about 3 times now. Just wondering if anyone had any ideas on what could be the problem. Thanks for any help!
rustynailer is offline
post #2 of 9 Old 09-23-2012, 03:50 PM
caulk04
Vehicle: none
Just cut right out or does it go to a real low idle and quit?
caulk04 is offline
post #3 of 9 Old 09-23-2012, 11:15 PM
Wheelinbeauty97
Real men play in the dirt
Wheelinbeauty97's Avatar
Vehicle: 1997 Dodge Dakota SLT
Modifications: Extang Blackmax tonneau, Sony Xplod headunit and speakers, cherry bomb glasspack
Garage
Sounds like your trans is giving you problems....
1997 Dakota 4x4 SLT 5.2L 318 Mostly stock.
2001 Ford Ranger XLT 4x4 4.0 too much to list. Ask if you want to know
Wheelinbeauty97 is offline
post #4 of 9 Old 09-25-2012, 04:45 AM Thread Starter
rustynailer
Modifications: None
Please don't tell me its the trans! lol but yea it does seem like it idles low and then dies..
post #5 of 9 Old 09-27-2012, 02:42 AM
caulk04
Vehicle: none
Kinda petering out like that sounds like it could be a bad IAC motor. It's the lower of the two devices on the driver side of the throttle body.
When you shift into a gear, the IAC needs to allow more air in the engine to maintain idle RPM under that load. If yours is getting lethargic, it could allow a stall.
Many moons ago I finally cured my dropping idle and stalling issue with a new OEM IAC motor. If you haven't done so yet, do a real good cleaning of the throttle body, especially in the IAC ports.
caulk04 is offline
post #6 of 9 Old 10-03-2012, 11:38 PM
midnite
Doesnt Afraid of Anything
midnite's Avatar
Vehicle: 2001/Dodge/Durango
Modifications: car, working, drumset, music,
Send a message via AIM to midnite
clean the throttle body or get a new peice on the throttle body... i forget the name, but its like the air control module?
!!!!!*-5 door whore # 64-*!!!!!
235 RWHP and 293 RWTQ!
Dodgetalk.com - SOTM! (Suv Of The Month) Sept. 09
dakota-durango.com - TOTM Oct. '10
midnite is offline
post #7 of 9 Old 10-07-2012, 04:25 AM Thread Starter
rustynailer
Modifications: None
Yea I am going to clean the throttle body well with some carb cleaner and doing the same with I the IAC port (is it ok to use carb cleaner on the IAC and throttle body?)...I found a write up on how to get to the IAC clean and hopefully have time to clean those while watching some football tomorrow! lol. Thanks again guys!
post #8 of 9 Old 10-18-2012, 11:23 PM
midnite
midnite's Avatar
i would assume so. ive used sd20 on it... im sure just about anythig will be fine, as long as your remove it, and let it dry before replacing it... best of luck. alls it is is 3 screws on th housing of the TB, and the intake hose, and then another 2 screws on the IAC to remove it from the TB. simple once done...
midnite is offline
post #9 of 9 Old 10-19-2012, 12:16 AM
TazRango
Jersey Boy
TazRango's Avatar
Quoted: 243 Post(s)
Yeah use carb cleaner and an old toothbrush to clean the IAC. But DO NOT UNDER ANY CIRCUMSTANCES TURN OR PUSH/PULL THE ACTUATOR. YOU WILL DESTROY THE MOTOR.
Use torrents? Already got two copyright strikes with your ISP? Got a slow upload connection? You need an offshore SEEDBOX! Includes a FREE VPN Endpoint in France, The Netherlands, or Canada (allows you to watch Netflix titles not available in the US!!).
CLICK--> DediSeedbox.com - 1Gbps backbone, up to 1TB storage, unlimited traffic, unlimited concurrent torrents, Secure FTP, VPN, and HTTPS access to files <--CLICK
Originally Posted by Big_Texxan View Post
fuck it, Im going to convert those to HID and stick them in my heads, fogs, tails, double heads, and my butt so I make a halo while shitting. It would be like a holy shit, and maybe one around my penis for that illuminating experience a girl has hahahaahahahaah
"How many times is Biden gonna say something stupid?" -Barack Obama (2008) ▼▼▼▼
"And Neal Smith, an old butt buddy, are you here Neal?" -Joe Biden (2/12/15)
TazRango is offline
