How to remove fan clutch? #$!@~%$)&*+ - Dakota Durango Forum
post #1 of 22 Old 03-27-2006, 01:13 AM Thread Starter
jcm3
U.S. Paratropper, 86-89
Vehicle: 2000 Dakota Quad Cab 4.7
I waited awhile to post this, or I would have been much more negative. I wanted to shoot the engineer who designed the fan clutch assembly.
On my Mustang, the fan and fan clutch are one unit. Remove the four bolts, and off it all comes. 10 minute job for removal and reinstall.
I tried doing that on my Dak at first, but realized that the fan and the fan clutch are two separate parts. I tried everything to remove it, to no avail. When you try to loosen the fan clutch, the water pump pulley moves. I tried everything to get it work loosen, including using a screwdriver through the little holes in the pulley to wedge it against the water pump ridges, and ended up breaking three different screwdrivers. I tried going both ways with the crescent wrench, just to be sure that it wasn't a reverse thread. Sometimes, it is easier to actually tighten to break a stiff nut loose, so I figured no harm done.
I tried having the wife help wedge the pulley lightly with a breaker bar while I tried to use a screwdriver, and that broke the third one. Arrrgggghhhhhh!!!!
I called around to three different auto parts stores, none of them rented a tool that would hold the water pump pulley from the front. They all rented 'universal fan clutch removal tools' but when I asked them to explain to me what they looked like, I knew they wouldn't work. None had nipples of any kind that would fit into the holes on the pulley.
I guess the only way to remove it is with a special Dodge fan clutch removal tool of some kind.
Thoughts?
ps - I am a big car guy, and can usually figure a way to get something done even if I am missing a tool. Giving up was a last resort and pissed me off!!! lol
Black 500 rwhp 6-speed 92 Mustang GT convertible
2000 Dakota Quad Cab 4.7 auto
QUAD SQUAD MEMBER
jcm3 is offline
post #2 of 22 Old 03-27-2006, 02:09 AM
Anthony
Yes it's a lowered 4X4
Anthony's Avatar
Vehicle: 2000 Dakota CC Sport
Send a message via MSN to Anthony
Here's the link to my site on how I removed my Clutch fan. Wasn't hard at all, just becareful you don't cut your finger like I did.
http://www.geocities.com/dak2nv/fan.html
Anthony is offline
post #3 of 22 Old 03-27-2006, 02:19 AM
moparsz
1700 + 1/4 mile passes
moparsz's Avatar
Vehicle: 2002 Dakota 4.7
Modifications: if you can think it, it probably has it
Quoted: 21 Post(s)
Garage
I took mine off the same way you tried, with a small screwdriver through 1 of the holes in the pully and a a wrench
Best pass 2002 Dodge Dakota : 13.302 @ 103.39 MPH and 1/8 E.T. 8.569 @ 82.87mph
Drag Track http://www.youtube.com/watch?v=LCNQhtcXkKE
New Years Eve Burnout http://youtu.be/tnWhrInUB6o
www.AIRRAM.com Discounted Performance Parts with FREE SHIPPING!
moparsz is offline
post #4 of 22 Old 03-27-2006, 02:54 AM Thread Starter
jcm3
Your link is currently unavailable.
I'll check back later.
QUAD SQUAD MEMBER
jcm3 is offline
post #5 of 22 Old 03-27-2006, 03:02 AM
dak-rt-2a-XR
Hemi Powered
dak-rt-2a-XR's Avatar
Vehicle: SRT8 and an R/T
Hey man...fellow paratrooper..although I didnt care for the 82'd....LMAO...
To remove it takes two people.....one man on the wrench that removes the bolt....the other person needs to take a wedge and hold it agaist the TB and lock the fan in place....and tourque like a mofo...it works promise, donr it several times...
Good luck
'08 Charger SRT8 6.1 Hemi with extensive modifications
'11 Durango R/T 5.7 Hemi daily driver
dak-rt-2a-XR is offline
post #6 of 22 Old 03-27-2006, 03:03 AM
Anthony
Anthony's Avatar
I just checked it's working fine :biggthump
Anthony is offline
post #7 of 22 Old 03-27-2006, 03:54 AM
01 Mudslinger
GOTSWAMPERS
01 Mudslinger's Avatar
Vehicle: 2001 DODGE DAKOTA 4X4
Modifications: Hunting, Fishing, Camping, Racing, and Fo Wheeling
i just took a steel rod, placed it on the nut, then got a BFH..(BIG FUKIN HAMMER)... and beat the Hell out of it, finally it loosened up and i turned it the rest of the way with my fingers.
2001 Dodge Dakota 4x4
4.7L V8
Glasspack Dual Exhaust
15x8 Pro Comp 1069's & 33x12.50's
1988 GMC Jimmy
Fuel Injected 350, 700R4, NP208
Front 10 Bolt (Yukon Chromoly Axles) Lockrite Locker
Rear 12 Bolt (Welded Locker)
6" Superlift, 15x10 Bullet holes
38x12.50 Super Swamper TSL's
01 Mudslinger is offline
post #8 of 22 Old 03-27-2006, 05:20 AM Thread Starter
jcm3
Yep, I can see it now. Interesting method. It didn't bend the pulley at all?
Might have to try that. :biggthump
Thanks for everyone's input.
QUAD SQUAD MEMBER
jcm3 is offline
post #9 of 22 Old 03-28-2006, 12:50 AM
Anthony
Anthony's Avatar
Just clamp it tight enought that the vise grips don't come off. It didn't even leave a mark!!
Anthony is offline
post #10 of 22 Old 03-28-2006, 01:04 AM Thread Starter
jcm3
Sweet. I need to get that mutha replaced. It works fine when I first start it (I mistakenly thought maybe it wasn't bad after all), but when it heats up it doesn't have any resistance.
I turned off the truck and times how long it took the fan to stop spinning when it was warmed up and at work, and it spun for about 10 seconds with the car off. Doh!
Thank goodness for the electrical fan. If I had a few $$ I'd replace the electric fan with a better unit (Taurus, Mark VII, etc.), put a better fan controller on it, and leave it at that.
QUAD SQUAD MEMBER
jcm3 is offline
post #11 of 22 Old 03-28-2006, 04:37 AM
BlackDak
BlackDak's Avatar
Vehicle: 01 Flat Black X-AWD V8 QC
Modifications: RC Monster trucks, MoPar
Why not just leave it off? I have had mine off for over a year (along with a bunch of other guys) and haven't had a single problem. Without it, the engine is damn near silent.
BlackDak is offline
post #12 of 22 Old 03-28-2006, 04:50 AM
Anthony
Anthony's Avatar
Exactly, it's so much better with it off!!!
Anthony is offline
post #13 of 22 Old 03-28-2006, 04:55 AM
00dakotav8
OMG 4.7L
Vehicle: 2000 Dodge Dakota
Send a message via AIM to 00dakotav8
Ok so this is a much desired free mod. Anyways what does the electric fan kick in at as far as temps go, and if the temps are too high, how do i make a controller or where do i find one. Nebraska doesnt get much over 100 in the summer so should i be ok, or will the humidity murder me?
2wd CC 4.7L V8 3.55 lsd 3/5 drop, 3k stall sitting in the garage. Best time 15.19 @ 94.45 mph
00dakotav8 is offline
post #14 of 22 Old 03-28-2006, 04:56 AM Thread Starter
jcm3
It's a bit hot here where I live (not as hot as Arizona or anything), and I don't want to put that kind of stress on that small fan. Granted, it is fine without it, but it does run hotter and the fan is on alot without the clutch fan doing anything.
I would like to upgrade to a fan that can handle the duties by itself, but if I push this one too far and it goes out, then I am not in a good situation.
It could be fine, but if I am wrong, it would be risky in my opinion.
QUAD SQUAD MEMBER
jcm3 is offline
post #15 of 22 Old 03-30-2006, 04:59 AM
03blkQC
Daily Driven
03blkQC's Avatar
Vehicle: 03 Dakota Quad Cab
Modifications: Bone stock daily driver
I put a ratchet on the tensioner and applied pressure while using a wrench on the fan clutch. It came off with no problem. We'll see if I need it when it warms up.
03blkQC is offline
