2000 Durango - Gear Indicator out - Dakota Durango Forum
post #1 of 5 Old 07-10-2012, 05:25 PM Thread Starter
mike407
Vehicle: 2000 Dodge Durango
Hello everyone,
I just purchased a 2000 Durango, and noticed that the digital gear indicator does not light up most of the time (the letters and the box around the selected gear). Occasionally when parked or in the middle of a drive, it may come on for a minute or so but more often than not, it does not light up. When it does light up, whichever gear I am in, or shifting through, is accurately selected. The digital odometer lights up, and all of the lights for the other non-digital gauges are functioning.
Has anyone had this problem before, or know how this could be fixed?
Thank you!
mike407 is offline
post #2 of 5 Old 07-13-2012, 07:21 AM
TazRango
Jersey Boy
TazRango's Avatar
Quoted: 243 Post(s)
The whole indicator goes out? Or does the PRND21 show up but the indicator box does not?
If the PRND21 is there but the indicator is not, then it's either a bad sensor in the transmission or a loose/bad connector. If the whole thing isn't lighting up and it comes on randomly, it could be a broken solder connection or failing component on the cluster circuit board.
There is no separate fuse for that display - however, it does get its data feed from a separate computer (the TCM). So if the PRND21 is there just with no box, it's also possible the TCM is failing or losing power. Does the transmission shift properly through all four gears? Do you have any codes? Is the Check Engine light on? You can check for codes by turning the key (starting at OFF) ON-OFF-ON-OFF-ON (landing at ON) and watch the odometer. It will flash out P codes separated by ------. At the end (or if there are no codes) it will say PdonE.
Use torrents? Already got two copyright strikes with your ISP? Got a slow upload connection? You need an offshore SEEDBOX! Includes a FREE VPN Endpoint in France, The Netherlands, or Canada (allows you to watch Netflix titles not available in the US!!).
CLICK--> DediSeedbox.com - 1Gbps backbone, up to 1TB storage, unlimited traffic, unlimited concurrent torrents, Secure FTP, VPN, and HTTPS access to files <--CLICK
Originally Posted by Big_Texxan View Post
fuck it, Im going to convert those to HID and stick them in my heads, fogs, tails, double heads, and my butt so I make a halo while shitting. It would be like a holy shit, and maybe one around my penis for that illuminating experience a girl has hahahaahahahaah
"How many times is Biden gonna say something stupid?" -Barack Obama (2008) ▼▼▼▼
"And Neal Smith, an old butt buddy, are you here Neal?" -Joe Biden (2/12/15)
TazRango is offline
post #3 of 5 Old 07-13-2012, 03:21 PM
Intense2000
Intense2000's Avatar
Vehicle: 2000 Dakota
Garage
Send a message via AIM to Intense2000
My truck does the from time to time. It's usually either neutral or sometimes reverse. Quite often it does it when I put it in 1 because I live on a terrible road and this makes going slow downhill easy. Also my O/D OFF light comes on when I'm accelerating hard 99% of the time, but O/D is still on. The indicator lights have been doing that since I got it. The O/D OFF thing didn't start until the Superchips install. It's also kinda rough about shifting into reverse, and there is no interlock/block off for reverse or park. No codes though....
2000 DODGE DAKOTA 4.7 V8 * 45RFE * 3.55 LSD
REFLEXXIONS COWL * GRABBER AT2S * K&N FIPK2 * SUPERCHIPS 3715 * MOPAR TCM * CATBACK DUALS
Intense2000 is offline
post #4 of 5 Old 07-13-2012, 09:51 PM Thread Starter
mike407
The PRND21 and the selector box is, most of the time, completely off. Not just the selector box - it's the whole display. Once in a while it will come on, either mid-drive or when I first start the truck and will accurately reflect the gear I am in. But most of the time it isn't on.
The transmission shifts properly through all gears and the check engine light is off. No other irregular displays are on. I tried the key-turning method you told me to try to get pcodes. It simply showed the mileage, the three dashes (---), then Pdone. Nothing between.
mike407 is offline
post #5 of 5 Old 07-14-2012, 09:36 PM
TazRango
Jersey Boy
TazRango's Avatar
Quoted: 243 Post(s)
Yeah then I think it's a safe bet that it's an issue with the cluster. Do you notice that it comes on after you hit a bump/rough patch/if you hit it? Or is it completely random? Rough patch indicates a broken solder connection, which is relatively easy to fix - once you find it. Completely random indicates an electronic problem, which in the absence of special tools, a schematic and test point values will be next to impossible to fix.
TazRango is offline
