Looking to do a tune-up - Dakota Durango Forum
post #1 of 17 Old 07-01-2012, 10:28 PM Thread Starter
Zach4542
Vehicle: 2003 Dodge Dakota
I recently got a 2003 Dodge Dakota, its my first vehicle and it runs very good, although I need a tune-up. I asked a shop how much it would be and they said 118, now thats not bad I don't think but they said all it covers is the wires and spark plugs, my dad told me a basic tune up consists of wires, spark plugs, rotor, and distributor cap. I found a tune-up kit online and it was about 50-60 bucks, so I was thinking about attempting to do it myself, what I really need to know is is it hard to do a tune up? And does anyone know a website that can walk me through it, if I can save a bit of money and get the job done myself it would be alot better for me. Thanks for any help you can give, it is greatly appreciated!
-Zach
p.s my truck is a V6
Zach4542 is offline
post #2 of 17 Old 07-01-2012, 10:58 PM
rt99three60
Vehicle: 99 Solar Yellow R/T
Not sure about a website to do a walkthrough, but its easy..The most important part is to make sure you have the wires connected properly to the Cap and the plugs, so the firing order is correct
rt99three60 is offline
post #3 of 17 Old 07-01-2012, 11:57 PM
dirtbiker
dirtbiker's Avatar
Vehicle: 2002 Dodge Dakota
I'd never recommend buying a kit. Just get a good set of wires, Autolite 3923 plugs, and a cap/rotor from Rock Auto/wherever you want. Like rt99three60 said, be sure you have the wires connected properly to the Cap. What I usually do is put the new cap next to the old one, and replace the wires one by one, to ensure I put every wire in the correct place.
2002 Dakota 3.9- Mods: SCT by Hemifever, V8 Throttle Body, Edelbrock Air Cleaner, 2" Lift coils and 2" lift shackles, Clutch Fan delete, 265/70/16 General Grabber AT2's, Air horn.
1979 F150 4x4- Short Bed Reg Cab. 6.9 Diesel/4 on the floor. Lifted 7 inches, built by ME
dirtbiker is offline
post #4 of 17 Old 07-02-2012, 12:23 AM
rt99three60
Yep, That's what i did Since its his first ride i think he should tune it up all by himself, feels good to fix your own shit.
post #5 of 17 Old 07-02-2012, 02:28 AM
Misfit
We Are 138
Misfit's Avatar
Vehicle: 98 Dakota V6 & 03 Cobra
Modifications: CAI,Xhaust,Flux Capacitor
Quoted: 20 Post(s)
Garage
If you have an 03, V6, that would be a 3.7 right? And that is just a baby 4.7, which has no distributor..it's coil on plugs..
Misfit is offline
post #6 of 17 Old 07-02-2012, 03:02 AM
rt99three60
http://www.cars.com/dodge/dakota/2003/ Not according to cars.com Misfit. Its a 04+ Dakota engine option
post #7 of 17 Old 07-02-2012, 03:17 AM
Misfit
We Are 138
Misfit's Avatar
Quoted: 20 Post(s)
Garage
i swear i read/saw somewhere that the last year of the 3.9 mag was like 01-03..idk
Misfit is offline
post #8 of 17 Old 07-02-2012, 03:19 AM
rt99three60
Yeah that is something i could care less to read or know about
post #9 of 17 Old 07-02-2012, 05:00 AM
DartBoy01
DartBoy01's Avatar
Vehicle: '99 Dakota R/T
At MOST this would probably only take about an hour if you have all the tools, even if your a beginner.
DartBoy01 is offline
post #10 of 17 Old 07-02-2012, 05:08 AM
Misfit
We Are 138
Misfit's Avatar
Quoted: 20 Post(s)
Garage
Assuming it is a 3.9 Mag, this is a stupid easy job.
The only part that makes me start cussing is doing the cap/rotor..it's back behind the intake, and under the firewall lip..it's sort of a bitch, can't see much of shit..etc.
As far as the parts, I'd say go with Autolite 3923 regulars..no plat,double plat, none of that crazy shit. Go to Advance Auto or Napa, and get the cap/rotor with brass terminals, works better and doesn't wear out as fast. plug wires, whatever advance or napa's " top of the line" is, Bosch most likely.
While you're already under the hood, clean your throttle body real good, replace the PCV valve, check all your hoses etc..
And make sure you use anti-seize on the plug threads.
Misfit is offline
post #11 of 17 Old 07-02-2012, 05:23 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 190 Post(s)
I'd say skip the Autocrap plugs, especially the 3923s. It's a V6 and he doesn't need one step colder or non-projected tip. Stick with the stock replacements. If you really want to use Autolites, use the 5224s. But I'd personally recommend NGK plugs.
hskrRT is offline
post #12 of 17 Old 07-02-2012, 11:29 PM
Misfit
We Are 138
Misfit's Avatar
Quoted: 20 Post(s)
Garage
I've been running 3923s in my V6 truck for about 8 yrs... never had a problem, runs a little smoother with them..
However, NGK's are good too, that's whats in the R/T
Misfit is offline
post #13 of 17 Old 07-26-2012, 04:23 AM
Rockin360RT
Vehicle: dakota R/T
Not much power
I have a 99 dakota rt. Im new to it but from what i see from driving it.. Not worth the gas. 390km a tank and inless its wet it wont spin the tires and i have 235s on all around. what can i do to clean it up without loose alot of money? Its all stock other then a new cold air intake cone. Please help me out! Thanks
Rockin360RT is offline
post #14 of 17 Old 07-26-2012, 07:29 AM
caleprofiveo
this is dayadge country
caleprofiveo's Avatar
Vehicle: '98 Dakota CC V6 2wd
Modifications: 3.92 9.25" lsd, added rear swaybar, headers, ud pulley, 19lb t-bird injectors, t-bird electric fan, 20% tint...
how many liters does it take to fill it?
ya it's purple...
caleprofiveo is offline
post #15 of 17 Old 07-27-2012, 01:49 AM
Rockin360RT
Vehicle: dakota R/T
Honestly i havent even checked how big the tank is. Its about 100 with gas at 1.27/L. Talk to a guy that says he gets aleast 500km a tank. Thats way better and hes got LOTS of power
