05 Durango suspension shake/wheel hop/wobble - Dakota Durango Forum
Suspensions - Lifted & Lowered Drop Kits, Lift Kits, Shocks and More
post #1 of 8 Old 05-06-2012, 01:54 AM Thread Starter
CUMMIN&CHOW
Vehicle: 05 Rango 05 Ram Cummins
Ok, Fellas,
I am new here, but not new to these rigs, or the automotive world. Let me brief you in on my ride and what I have done to it so far, then on what the prob seems to be.
I drive on 05 Ram 3500 diesel, and wanted something for the wife to drive so I purchased an 05 Rango 2wd 4.7 with a bad transmission for her. I replaced the 545RFE with an almost new unit, put new brakes on it, drilled and slotted rotors, ceramic pads, air-raid intake, full tune up, and synthetic fluid in every single lubricated part. I also installed 3" eibach progressive lowering springs in the back, coupled with air-lift 1000 bags in the rear. Lowered the front about 1" via backing the torsion bars off. Painted lids on headlights, ditched the 17's and threw on some 20" rockstars wrapped in brand new NEXEN sport 275's.
WOW what a different machine now! It went from handling like a lifted jeep to a Supra(well not quite, but close)
That brings me to my problem. Ever since I bought it, it has had a fairly violent shake that occurs every time I hit a decent size bump, going nearly any speed. It has progressively gotten worse, either due to wearing out more, or my mods, not sure which. I think the 20" wheels dont dampen it like the 17s did. The vehicle is aligned PERFECTLY for the ride height it sits at, and all suspension components have been checked. Everything except the lower ball joints are in A-1 condition. The lower ball joints have zero lateral movement, but about 3/16" vertical play. I am ordering some and am going to replace them, but I would really like to know if any of you have experienced similar problems caused by ball joints? I know that I should start with what I know if bad, but the way it shakes, I have my doubts that it is caused by the ball joints. Any thoughts anyone?....
CUMMIN&CHOW is offline
post #2 of 8 Old 05-29-2012, 05:33 PM
02dakotadrvr
Big red
02dakotadrvr's Avatar
Vehicle: 2002 Dodge Dakota 4wd
Have you checked the wheel bearings? Are the tires perfectly balanced? How are the shocks in the front?
02dakotadrvr is offline
post #3 of 8 Old 05-29-2012, 09:47 PM
zclif2601
Chillin The Most
zclif2601's Avatar
Vehicle: moms box
Garage
Originally Posted by CUMMIN&CHOW View Post
Ok, Fellas,
Im slightly confused, a 2wd durango has torsion bars?
zclif2601 is offline
post #4 of 8 Old 05-30-2012, 06:11 AM
petrock
The Anti-RUB
petrock's Avatar
Vehicle: 4.7L '03 Durango SLT
Quoted: 16 Post(s)
+1
3/16ths movement is a lot. Especially when any movement is too much. It could easily be your problem, however, where there is one problem there is often another. So I would check the upper/lower control arm bushings, inner/outer tie rods, rack-n-pinion mounting bushings, sway bar bushings, steering shaft u-joints, shock bushings and mounting bolts, etc. The list goes on. A nice sized pry bar should help. Stick it in various spots and see if you can move the component. There should be no movement.
Good luck...
K&N FIPK
YouTube Channel: Pet Rock’s Garage
petrock is offline
post #5 of 8 Old 06-03-2012, 10:54 PM
Dman98
Your problem is similar to mine; I've been dealing with the bouncing front end for over a year now. When driving 30 mph and I hit a rough patch in the road she acts like I have no shocks. Also when going above 65 mph, I get what some call the death wobble. I've researched and replaced everything that could contribute to this situation. Then I said I'll drive her until it get worst and hopefully the cause will reveal itself. Well it's been a year, It hasn't gotten worst and I don't drive faster than 60 mph. My long trip vehicle has become my around the town daily driver. During routine maintenance I noticed right rear axle seal starting to leak, not enough to cover the brake components. The crankshaft seal looks like it may begin to leak soon, two header bolts are broken and the PPH headers need to be re-coated. The rear main seal needs replacement again, not dripping on the ground yet. I'm trying to decide if I should replace her with something new, or invest the money for the repairs. Not being able to track down the front end issue may be the deciding factor. She has 108,000 miles, the engine runs strong. I'll be watching this post and any info that fixes mine.
Dman98 is offline
post #6 of 8 Old 06-08-2012, 08:03 PM
jack Buaer
jack Buaer's Avatar
Vehicle: 1999 Dodge Durango
Modifications: 5.5 Tuff Country Lift, 33x12.50 15 Goodyear Wranger Kevlars, Upgraded upper balljoints with moog and tierods. 1500Watt inverter with 120 outlets inside truck GFI outside, Onboard air.
Here is what i would check:
Jack the front end up.
place one hand at top one hand at bottom of tire see if it moves back and forth as you push and pull. If this occurs bad Wheel bearings.
now check your upper and lower ball joints if you see over excessive grease or boot ripped more than likely they are bad, Now check your inner and outer tierods see if you have any play in them. if so replace.
Or simply take a few pictures and post there here make sure you get clear pics. I hate to say someone saw Jesus or the Lock Ness monster in them.
jack Buaer is offline
post #7 of 8 Old 08-16-2012, 03:03 AM
rag006
Vehicle: 2006 Durango 4.7
Modifications: K&N 57 series
Ok, Fellas,
did you change anything with the rear sway bar when you installed the new springs I was thinking about lowering mine also
rag006 is offline
post #8 of 8 Old 08-26-2012, 12:05 AM
Dman98
I replaced the gearbox, had the wheels aligned and the problem eased up significantly. I went on a trip, used the cruise control for 60, 65 and 70 mph and had just a slight vibration at 70mph. It would happen only occasionally when I had to slow down, then hit 70 mph again. The gearbox was replaced due to a loose and leaking condition.
Dman98 is offline
