Cylinder 3 Misfire Code - Dakota Durango Forum
post #1 of 11 Old 04-03-2012, 10:20 PM Thread Starter
num1hitter
Vehicle: 1998 Dakota
Any suggestions? There is a notable misfire when driving. I am going to change the spark plugs. Do you think I should change the coil as well? Any other thoughts would be appreciated. Thanks a lot.
num1hitter is offline
post #2 of 11 Old 04-03-2012, 10:46 PM
AmberFireDaK
AmberFireDaK's Avatar
Vehicle: 2000 Dakota R/T
Quoted: 2 Post(s)
Send a message via MSN to AmberFireDaK
Start with the plug, then the wire... then the cap and rotor. If all that fails try swapping the injector with another cylinder and see if the missfire follows....
The coil supplies the power to all the cylinders so it can't cause a missfire on only 1
- Justin
AmberFireDaK is offline
post #3 of 11 Old 04-03-2012, 11:41 PM
CarolinaBoyRoss
CarolinaBoyRoss's Avatar
Vehicle: 1998 Dodge Dakota 3.9l
Modifications: Magnaflow muffler, heavy right foot
Change the plugs then if it still says miss fire change the plug wire on the miss firing cylinder for one that works fine and see if it fallows or stays, if it fallows its most likley the wire but if it dosent it could be the coil. also do what AmberFireDak said and change injectors if the wire swap dosent shown any results.
2001 Dodge Dakota Quad Cab
3.9 auto 3.55 anti-spin
Support Our Troops
CarolinaBoyRoss is offline
post #4 of 11 Old 04-04-2012, 02:20 PM Thread Starter
num1hitter
Thanks a lot guys, I will do that and let you know how it goes.
post #5 of 11 Old 04-05-2012, 01:02 AM Thread Starter
num1hitter
I changed all the spark plugs and it seems like it fixed the problem, but the check engine light is still on. Do I have to reset the check engine light or will it reset itself if the problem is fixed?
post #6 of 11 Old 04-05-2012, 02:32 AM
CarolinaBoyRoss
Sounds great that the problem is gone could have been a loose plug wire on the spark plug or the coil, but the check engine light will have to be reset at autozone or orileys if you dont have a scan tool they can do it for free. Then drive it as normal for a day or two and if the code dose not show up again then its fine but if it comes back up then have it scanned at autozone or orileys, it usually takes the computer a day or so for the code to come back up in the computer.
Support Our Troops
post #7 of 11 Old 04-05-2012, 10:00 PM
AmberFireDaK
Quoted: 2 Post(s)
Originally Posted by CarolinaBoyRoss View Post
C... but if it dosent it could be the coil.
How exactly can the coil cause a missfire on only 1 cylinder?
- Justin
post #8 of 11 Old 04-05-2012, 11:04 PM
Shadz
Shadz's Avatar
Garage
Check your injector 3, I did the works with mine and it ended up being a stupid O-ring on the engine side of the injector. It was causing a leak that lead to a misfire.
Shadz is offline
post #9 of 11 Old 12-20-2013, 03:29 PM
morbidfireman
dragons fire
morbidfireman's Avatar
Vehicle: 2000 dodge durango
Modifications: 3" t/s lift and custom skid plate and custom front hitch for now
Garage
misfire issue
2013-12-19_14-20-00_34.jpg...this is what mine turned out to be on a 4.7 2000 durango for #4 cylinder
morbidfireman is offline
post #10 of 11 Old 12-20-2013, 10:52 PM
ScojoDak
Dakota for Life!
ScojoDak's Avatar
Vehicle: 98 Dakota R/T
Originally Posted by morbidfireman View Post
Attachment 63681...this is what mine turned out to be on a 4.7 2000 durango for #4 cylinder
You're lucky. That could have been disastrous!
Dakota for Life!
If you haven't lived for something, you'll die for nothing.
ScojoDak is offline
post #11 of 11 Old 12-20-2013, 11:24 PM
morbidfireman
dragons fire
Garage
aint that the damn truth
