'01 Dakota Quad Cab Sub Install - Dakota Durango Forum
Audio, Security & Multimedia Speakers, Amplifiers, Subwoofers, Alarms, TV's, Game Consoles
post #1 of 8 Old 03-26-2012, 05:02 AM Thread Starter
Fatjesus71
Fatjesus71's Avatar
Vehicle: 2001 Dakota 4.7 SLT Quad
Lightbulb '01 Dakota Quad Cab Sub Install
Hey,
I have been doing my research for about 4 months now and have found that there is not a whole lot of options for a sub install in the QC's without having to leave out the seats. BUT from bits and pieces I have collected ideas and taken them into consideration when it came down to the time to do the install. I have tried to take pics of my progress but had forgotten to document some steps. I am not completely finished and I am curious who else has done a behind the seat install in there QC and who would be interested in this information?
Fatjesus71 is offline
post #2 of 8 Old 03-26-2012, 05:11 AM
lo1dakota
DAMN
lo1dakota's Avatar
Vehicle: 2003 Quadcab
Modifications: Trucks, Motorcycles
Well what did you do?
lo1dakota is offline
post #3 of 8 Old 03-26-2012, 05:50 AM Thread Starter
Fatjesus71
Fatjesus71's Avatar
I ordered some sub boxes from a place in cali they come in a set of 2 and they come with very specific dimensions so I made sure the subs I wanted would be a good match before I ordered them (Sony Xplod 10") I have always had good luck with them and have yet to blow them regardless of my Planet Audio 1200W Class D amp cranked up. I got the boxes and had to remove the back of the seats so I could trace around them on the back panel. Remove back panel cut out the placement for the boxes. Now I had to remove the cab vents that are fitted into the rear wall of the cab and I cut out some plexi glass to cover those but before mounting with rivets I placed a bead of butyl tape (window weld) around the edge to make it water proof, then cover the edges of the plexi with a waterproofing duct tape (sold at walmart) just for good measure and to cover any sharp edges and then drilled and riveted into place with 1/8 rivets.
Had to remove the jack holder from behind/under the rear pass side seat. To do so, I used a 3/8 drill bit to drill out the 6 spot welds (just small circles on the plate surface). After that I went to my local tractor supply store and got some "Christmas tree" fender holders and found some with 3/8 diameter and placed some waterproofing tape over the holes and pushed the Christmas trees through the holes.
Now took apart the back of the seats and just dealt with the metal framing of the seat. I knew that the subs would hit the bottom framing tube of the seat backs so I cut out the tubing at the bottom of the seat frame and partially the support rods coming from the top of the seat to the bottom and I cut some metal rod and welded it in place so that the support rods weren't just sitting there poking through the back of the seats and if for some reason someone was in the back seat and I got in an accident there is less of a chance of having those support rods going through someones body (just good measure once again). And now I am waiting for my subs to come in at walmart since the older version of 10" xplod are $30 and there is no mechanical/technical difference.
post #4 of 8 Old 03-26-2012, 06:01 AM
lo1dakota
DAMN
lo1dakota's Avatar
What are the dimensions of the boxes? Mainly curious of the mounting depth.
post #5 of 8 Old 03-26-2012, 06:09 AM Thread Starter
Fatjesus71
Fatjesus71's Avatar
It has 2 options when you order them. Here is a link to the specific boxes. You can check the options there.
https://www.soundoffaudio.com/items....a%20Crew%20Cab
post #6 of 8 Old 03-26-2012, 06:18 AM Thread Starter
Fatjesus71
Fatjesus71's Avatar
post #7 of 8 Old 03-26-2012, 06:24 AM
lo1dakota
DAMN
lo1dakota's Avatar
I only want 1.
post #8 of 8 Old 04-01-2012, 03:13 AM
demented04
Vehicle: 2004 Dakota Quadcab 4x4
i dont have any pics but i put a 10" Shallow mount sub in a box i build behind the seat. The box is like 5" deep at bottom, and 2.5" at top and 17" wide. I had to stuff it full of some polyfil to get best results but i think it sounds great. The sub i used is this one http://www.parts-express.com/pe/show...number=295-134. only thing i had to do is remove one of the seat bolts and hand tighten the other so i can still lift the seat bottom up.
demented04 is offline
