hard start when warm - Dakota Durango Forum
post #1 of 7 Old 03-17-2012, 01:25 PM Thread Starter
6shooter
Resident Craigslist Whore
6shooter's Avatar
Vehicle: One with a bowtie
well my winter beater, 98 Dakota 3.9 auto 4x4, has been acting up since I bought it but it didn't really bother me, as my good truck was still in storage for winter so I couldn't down this one. The problem is that when it's warm (engine temp wise) it starts hard. Sometimes it'll chug along and finally idle up after normal cranking time, but most of the time, it'll crank for a good 3-6 seconds and then finally fire up, and that's with me feathering the throttle. but when it's cold out, like near freezing, and the engine is just being started for the day, it fires up after only a few revolutions. I've got a fuel pressure tester at home, and now that my good truck is on the road, I'm going to do some work on the old dakota, clean the tb, oil change, rear brakes need attention, etc. Just wondering anything strikes you guys right off the bat for me to check.
Hi, my name is Brad, and I have an addiction to Dakotas.
6shooter is offline
post #2 of 7 Old 03-17-2012, 02:06 PM
bogieboy
Outlaws Phone Warden
bogieboy's Avatar
Vehicle: '96 Dakota Ext. cab
Modifications: just your basic 1600 watts of subs in the cab...and a flowmaster for now...oh...and a supercharger
Send a message via AIM to bogieboy Send a message via Yahoo to bogieboy
Sounds like an injector leaking down into the intake..... I know i have one leaking and if i try to start it at temp say 15 min after i shut it off, it is a bitch to start....pops to life at about 9:1 a/f
Insanity: doing the same thing over and over again and expecting different results
big things in the making
bogieboy is offline
post #3 of 7 Old 03-17-2012, 04:26 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 189 Post(s)
Maybe try a new coil. They start acting funny when they get hot if they are starting to go bad. Only other thing would be possibly a coolant temp sensor.
hskrRT is offline
post #4 of 7 Old 03-25-2012, 02:53 PM Thread Starter
6shooter
6shooter's Avatar
hey guys, thanks for the responses. apparently my email notifications aren't working for any of my threads for some reason.
well I cleaned my throttle body and it seems to have fixed the problem. cranks right up now, hot or cold.
6shooter is offline
post #5 of 7 Old 03-27-2012, 04:46 PM
Jenn27549
Vehicle: 2004 Dodge Durango 5.7
Hey guys, I'm having the same problem with my 2004 Durango. I have the 5.7 Hemi in it, and the engine is actually out of a 2008 2500 pickup. The engine only has about 35,000 miles on it but the rest of the vehicle is at 200k.
When we did the swap 2 months ago we replaced and/or cleaned all the components, so I know the throttle body is in good shape and clean. Plugs, battery, coils, etc... all new. When this problem first presented itself we changed the starter, thinking that was the likely culprit, but it still does it and gets worse as time goes on.
Like others I've read about it starts right up when cold. Only when warm does it hesitate. Sometimes a little, sometimes alot. I read elsewhere on here it could be the fuel pump or the CPS sensor, but I don't want to go changing anything without a better idea of which one to start with. Any ideas? No lights or anything are on, and otherwise runs great.
Jenn27549 is offline
post #6 of 7 Old 03-27-2012, 06:24 PM
bogieboy
bogieboy's Avatar
I would start off checking the fuel pressure... With 200k on the clock it could very well be your pump....
bogieboy is offline
post #7 of 7 Old 03-27-2012, 10:17 PM
Jenn27549
Just ordered the CPS Sensor today, only $20. Fuel pressure is fine. Apparently a big problem with them, according to the parts store. I'll update if that fixes it. Should be here tomorrow.
