97 Dakota won't start - Dakota Durango Forum
2.5L/3.7L/3.9L Engines Questions regarding the I4 and V6 Engines
post #1 of 18 Old 03-13-2012, 10:06 PM Thread Starter
eznacho
Vehicle: 1997 Dodge Dakota
Hello everyone let me introduce myself my name is Edson Zuleta, but everyone calls me Nacho.
I have a 97 Dodge Dakota that isn't starting, I will list the things that I have changed on the truck to help further diagnose the problem.
Crankshaft Sensor
Fuel Pump
Map Sensor
Engine Coil
Spark Plugs
Oil Change
New Battery
No check engine light. I might be missing some other things I've changed, will let you know if you mention it.
eznacho is offline
post #2 of 18 Old 03-13-2012, 10:12 PM
AmberFireDaK
AmberFireDaK's Avatar
Vehicle: 2000 Dakota R/T
Quoted: 2 Post(s)
Send a message via MSN to AmberFireDaK
Cam sensor under the distributor cap
- Justin
AmberFireDaK is offline
post #3 of 18 Old 03-13-2012, 10:58 PM
JimLusk
JimLusk's Avatar
Vehicle: 2000 Durango 5.9
Garage
Rather than throwing parts at it you need to do some troubleshooting. Start with the Auto Shutdown Relay. If you turn the key to on (not trying to start, just the run position) you should hear the fuel pump for a second or two. If you hear it, then you need to check fuel pressure. If you don't you need to find out why. Work from there.
1967 Barracuda convertible 440/AT
1968 GTS convertible 340/AT
2004 BMW 330Ci convertible
2000 Durango 5.9
JimLusk is offline
post #4 of 18 Old 03-13-2012, 11:18 PM
TexasCoder
Mean people suck
TexasCoder's Avatar
Vehicle: 2001 Dakota Sport Plus QC
Garage
I am with JimLusk on this one, diagnose it a little further, 3 things are needed for a basic engine to run: fuel, spark and compression. Check to make sure your engine has those three and go from there.
Also, is it a no crank no start or crank no stark, does the engine try to turn over or you get nothing when you turn the key (dead silence)?
TexasCoder is offline
post #5 of 18 Old 03-14-2012, 06:09 AM Thread Starter
eznacho
Thanks yall, its a crank no start I get a spark, what it does is it tries to crank over and as it tries sometimes it actually does start but doesn't stay on only for like half a second or so
eznacho is offline
post #6 of 18 Old 03-15-2012, 02:07 AM
ol' grouch
ol' grouch
Vehicle: 1992 Dakota, 2001 Ram
Garage
Have you made CERTAIN the engine is in time? Besides that, have you run a pressure test on the fuel system? When you turn the key on, you'll hear a short pulse of the fuel pump charging the fuel lines. This may be why it's running for a short time. If the pump doesn't work in the run position, the truck won't run.
Practicing curmudgeon.
2001 Dodge Ram 2500 4X4, 1998 Furd Taurus, 1982 Mercedes 380 SL, 2005 Kawasaki Concours and last but not least, 1992 Dakota 4X4.
ol' grouch is offline
post #7 of 18 Old 03-15-2012, 02:12 AM
jmaack727
"][" {[]} {[]} ][_
jmaack727's Avatar
Vehicle: 2 of em.
I say cam sensor also.
jmaack727 is offline
post #8 of 18 Old 03-16-2012, 05:46 PM Thread Starter
eznacho
Yes I had a mechanic make sure the engine was in time.
When I turn the key on I hear the short pulse of the fuel pump charging the lines.
It doesn't ever really start sometimes when I keep cranking and cranking it will start but only for about half a second or so... never technically "RUNS"
As far as the cam sensor goes, I've looked online for the part and it keeps showing me a crank shaft sensor, is that the same thing? I'm not getting results at autozone website or checker/oreilly's website.
eznacho is offline
post #9 of 18 Old 03-16-2012, 05:48 PM Thread Starter
eznacho
I also tried changing the relay with a relay of the same model # with that one and nothing changes, I made sure the relay hooked up at the ASD slot worked by putting it on the starter relay slot and it wanted to crank, without a relay in the STARTER RELAY SLOT nothing happened.
eznacho is offline
post #10 of 18 Old 03-16-2012, 06:07 PM
TexasCoder
Mean people suck
TexasCoder's Avatar
Garage
I wonder if your MIL (Check Engine Light) is burned out. Have you hooked a code reader and/or scan tool up to it, to see if any codes can be pulled?
post #11 of 18 Old 03-17-2012, 12:19 AM
AmberFireDaK
Quoted: 2 Post(s)
The cam sensor is not the same as the crank sensor... You say you changed the crank sensor so you know where that is. The cam sensor is under the distributor cap and rotor, it's a thin black disc with a single pig tail connector. It's also known as the pick up coil, pick up plate or distributor coil.
- Justin
post #12 of 18 Old 03-17-2012, 12:34 AM
jmaack727
"][" {[]} {[]} ][_
jmaack727's Avatar
Vehicle: 2 of em.
post #13 of 18 Old 03-17-2012, 04:52 AM
JimLusk
JimLusk's Avatar
Garage
You should get a code if the cam sensor is bad. Make sure you have spark. Make sure you have fuel. Make sure you have voltage to the injectors (the PCM provides the ground for them).
2000 Durango 5.9
JimLusk is offline
post #14 of 18 Old 03-17-2012, 04:18 PM
AmberFireDaK
Quoted: 2 Post(s)
I've had 2 go bad, never had a code.....
- Justin
post #15 of 18 Old 03-17-2012, 04:59 PM
jmaack727
"][" {[]} {[]} ][_
jmaack727's Avatar
Vehicle: 2 of em.
same here
