Manual transmission swap - Dakota Durango Forum
post #1 of 4 Old 02-21-2012, 09:11 PM Thread Starter
1997Dakota318
Vehicle: 1997 Dodge Dakota
I am aware of the kiesler kit and it's expensive and rare nature. Having said that I have absolutely no desire, nor the budget for a kiesler. What are the other options as far as manual tranny's go. I already have a 5-speed 318 truck and I am wondering what options are out there since there is little info on this subject. Has anyone put a gen 4 6-speed in their gen 3? What manual trasmissions are compatible? Are there any kits to adapt other styles of transmissions? I need to try to keep this all under $1500 for parts and supplies, labor is not going to be a cost since my father, grandfather, and I will be attempting this if I can get more info. I like the way the nv3500 tows (it feels like I could pull a house off the foundation in 1st--but 1st quicly achieves redline) but I only ever really pull my 10 foot pop up and when in transport a 6th gear would help my mileage alot, so it is worth the investment if I can save gas and hopefully get something with slightly taller gears, if not 6th is good enough. I have even heard a tale about adapting kits to put the mustang t5 behind a magnum...is this true? I would greatly appreciate any input because I have scoured the internet and basically only found the Keisler and not much else...
1997Dakota318 is offline
post #2 of 4 Old 02-21-2012, 09:51 PM
jmaack727
"][" {[]} {[]} ][_
jmaack727's Avatar
Vehicle: 2 of em.
You have to go aftermarket. I suggest searching. There is a parts list to swap in a t56 not using keisler.
If you get the TKO bellhousing from lakewood you can do the same and keep a 5 speed. The rest is up to you. Being you have a 97 though its gonna be difficult if not impossible to get your speedo working since the rear doesnt have the sensor.
Start reading.
http://www.dakotart.com/forum/showthread.php?t=16300
http://www.dakotart.com/forum/showthread.php?t=16232
jmaack727 is offline
post #3 of 4 Old 02-26-2012, 04:02 AM
dakota 2.5L
Vehicle: 1998 dodge dakota sport
Modifications: stock k&n a/f --stock jeep 4.0L tb. --accell mopar/jeep ign.coil w/ apt wire---accell 8.mm ign.wires red---e3 spark plugs---brass dist/cap & rotor---royal purple max ez p/s fluid,synchromax manual trans fluid-max gear diff gear oil fluid - banks torq
Garage
Smile
A 6 speed trans may drop rpm's to low in 6 gear and kill your mpg's more. You can take your engine out of it's power band. But you can change your tire size up one size lg and see a .5 to 1 mpg inpro.And still have a killer 1st gear.You must stay with 3% of oem tire size for that to work..... You don't whant to drop your rpm's more than 200 rpm's... 100 to 150rpm's is the best...IMHO...Remenber oem's match dr/train to work right...to keep the rpm's right...God bless...
dakota 2.5L is offline
post #4 of 4 Old 02-28-2012, 03:44 AM Thread Starter
1997Dakota318
Well it seems as though a 6-speed would just be costly to achieve, seems like my best bet would be to put a Mustang 5 speed in (for the money)
