Replace Upper Ball joints question - Dakota Durango Forum
post #1 of 24 Old 01-21-2012, 09:24 PM Thread Starter
JohnG
JohnG's Avatar
Vehicle: 1998 Dodge Dakota 5.2l
There is a great writeup on replacing upper and lower ball joints on the Dodge Dakota on this site. However the author failed to mention whether or not the front coils had to be compressed.
Does anyone know if I will need to get a spring compressor to change the upper ball joints on my 1998 Dakota ?
Thanks for helping
JohnG is offline
post #2 of 24 Old 01-21-2012, 11:53 PM
9t9-5.2
Home School Valedictorian
9t9-5.2's Avatar
Vehicle: 9t9-5.2
A spring compressor is not needed. Support the truck at the frame with jack stands, compress the suspension with a floor jack enough to get the upper a-frame off the bump stops, leave the shock in place as a safety measure.
No fear, no doubt, all in balls out
If every American cared enough to purchase one USA made garment per year the impact would be $9 billion. That is a lot of American jobs.
9t9-5.2 is offline
post #3 of 24 Old 01-22-2012, 01:49 PM Thread Starter
JohnG
JohnG's Avatar
Thank you
JohnG is offline
post #4 of 24 Old 01-25-2012, 04:04 PM
02dakotadrvr
Big red
02dakotadrvr's Avatar
Vehicle: 2002 Dodge Dakota 4wd
Have fun getting them out..
02dakotadrvr is offline
post #5 of 24 Old 01-25-2012, 04:16 PM
silverback
Mongo lift heavy things..
silverback's Avatar
Vehicle: 01 QC Dakota 3.9L 2WD
I didn't need to compress the coil to get it back in. When I take them out I feed a chain through & lock it down in case it wants to get froggy, just gotta leave enough slack to let the coil fully extend.
QUAD SQUAD MEMBER
silverback is offline
post #6 of 24 Old 01-25-2012, 07:02 PM Thread Starter
JohnG
JohnG's Avatar
I got it done. Thank God.... It took 4 hours The rivets suck. I pounded the drivers side out and it took forever. I ended up partially drilling the passenger side rivets and they popped right out. Thanks for all of your advice
JohnG is offline
post #7 of 24 Old 01-26-2012, 03:03 AM
02dakotadrvr
Big red
...rivets? anyone else seeing the recall he missed?
post #8 of 24 Old 01-26-2012, 07:31 AM
Wrider
The bike-obsessed lunatic
Vehicle: 2001 Dodge Dakota SLT
Modifications: Bone stock for the moment
Recall was for the "second gen" of the "third gens". 2001-2004, 1998 had a completely different front suspension.
01 Dakota SLT 4.7 M/T
Wrider is offline
post #9 of 24 Old 01-26-2012, 07:36 AM
commeeche
commeeche's Avatar
Vehicle: 2004 Dodge Dakota QC
Garage
what was the recall for?
commeeche is offline
post #10 of 24 Old 01-26-2012, 10:40 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 190 Post(s)
'98 did not have a completely different suspension. It was the same as every other year. The only difference was the camber adjustment bar on the passenger side upper on the '00+ trucks.
For the rivets on the uppers, they are easy. Get a grinder, grind off the heads of the rivets, then hit the ball joints with a hammer and they pop right off. No need for a spring compressor or chain to hold the springs together. let the suspension go to full extension. Place a jack under the lower control arm with about 1" of space from the jack to the control arm. Remove the nut from the upper ball joint, then smack the ball joint with a hammer. The ball joint will pop apart using the force of the spring to help, and the jack with catch the lower control arm from hitting the ground.
hskrRT is offline
post #11 of 24 Old 01-26-2012, 01:29 PM
Cloned_R/T
Cloned_R/T's Avatar
Vehicle: 2003 Dakota Sport RC
Quoted: 8 Post(s)
Send a message via AIM to Cloned_R/T
I have a 2000 dakota and never received a recall notice for any of my ball joints. I replaced them 3 years ago with MOOG parts, no problems since. My dad has a 2000 dakota quad cab, he's still on the original ball joints.............
Mike Zadler
Dart Rallye 1.4L Turbo (new daily driver)
2000 3.9L CC Sport (Sold)
2003 4.7L RC Sport (Sold)
Mods to the 2003 4.7:
Gibson Headers, Magnaflow cats, Magnaflow mufflers, Shaker hood intake with airraid filter, Superchips Programmer 3715, Mopar LSD unit with 3.92 gears.
Previous Personal Best: 15.304@87.25 7/5/11
New Personal Best: 14.993@88.93 4/12/12
Cloned_R/T is offline
post #12 of 24 Old 01-27-2012, 02:47 AM
DrPepper
DrPepper
DrPepper's Avatar
Vehicle: '57 Dodge TW-PW
Modifications: Lot's
Quoted: 5 Post(s)
Call the dealer with your VIN #....
they will look it up for you and the R&R is free...but you get their crumby stock joints. No upgrades. Once they do the hard part you can wear them out and install good ones a lot easier.
DrPepper
DrPepper is offline
post #13 of 24 Old 01-27-2012, 03:06 AM
AmberFireDaK
AmberFireDaK's Avatar
Vehicle: 2000 Dakota R/T
Quoted: 2 Post(s)
Send a message via MSN to AmberFireDaK
This....
- Justin
AmberFireDaK is offline
post #14 of 24 Old 01-28-2012, 01:46 AM
9t9-5.2
9t9-5.2's Avatar
Vehicle: 9t9-5.2
Having a CRS moment, Wasn't the recall for 4wd or was it 2 & 4wd?
9t9-5.2 is offline
post #15 of 24 Old 01-28-2012, 03:58 AM Thread Starter
JohnG
JohnG's Avatar
I checked, my 98 Dodge Dakota 2WD was not in the recall. If I am wrong, let me know because I went for alignment and now have to do the lower balls as well as tie rods and sway bar linkage! Thanks Schwab for not telling me that the lowers were bad too!!!
JohnG is offline
