Serpentine Belt size to bypass AC Compressor on 4.7? - Dakota Durango Forum
General Parts Inquiries Can't find it in any other category?
post #1 of 10 Old 01-08-2012, 01:03 AM Thread Starter
J440Cuda
Bleed Mopar Blue
Vehicle: 2002 Durango 4X4
Anyone know what size or part number the serpentine belt would be to bypass the AC compressor on my 2002 Durango 4.7 4x4? Compressor crapped out again (4th compressor if I include the original). I want to just bypass it until I can get it fixed.
Thanks
J440Cuda is offline
post #2 of 10 Old 01-08-2012, 01:28 AM
jmaack727
"][" {[]} {[]} ][_
jmaack727's Avatar
Vehicle: 2 of em.
Try the search. I know of a few threads. Ill post later if you cant find them using the search function.
jmaack727 is offline
post #3 of 10 Old 01-08-2012, 01:55 AM
petrock
The Anti-RUB
petrock's Avatar
Vehicle: 4.7L '03 Durango SLT
Quoted: 16 Post(s)
With the stock belt installed, take a string and wrap it around the pulley's etc and measure the string. Then buy a belt of the same length. You want to do this with the belt on so that the belt tensioner will be able to apply tension to the new belt. Good luck...
K&N FIPK
YouTube Channel: Pet Rock’s Garage
petrock is offline
post #4 of 10 Old 01-08-2012, 02:01 AM Thread Starter
J440Cuda
Bleed Mopar Blue
Thanks guys, I have found some similar threads, but will try the string technique. Sounds like a plan. Thanks again.
Has anyone else had that much trouble with ac compressors? I'm at about 104k miles.
J440Cuda is offline
post #5 of 10 Old 01-08-2012, 04:13 AM
9t9-5.2
Home School Valedictorian
9t9-5.2's Avatar
Vehicle: 9t9-5.2
What are you replacing them with? New, used, rebuilt?
No fear, no doubt, all in balls out
If every American cared enough to purchase one USA made garment per year the impact would be $9 billion. That is a lot of American jobs.
9t9-5.2 is offline
post #6 of 10 Old 01-10-2012, 03:14 AM Thread Starter
J440Cuda
Bleed Mopar Blue
They have always been replaced at the Dodge dealer, and I am pretty sure each one was a re-man.
J440Cuda is offline
post #7 of 10 Old 01-10-2012, 09:34 AM
jmaack727
"][" {[]} {[]} ][_
jmaack727's Avatar
Vehicle: 2 of em.
Im going to go out on a limb and say someone didnt search.
http://www.dakota-durango.com/forum/...ad.php?t=53480
post #8 of 10 Old 02-02-2012, 04:10 AM Thread Starter
J440Cuda
Bleed Mopar Blue
Thanks to jmaack727 for the link and to Dj Wolf for the schematic. I finally got the compressor removed and used Dj's info to bypass with a shorter serpentine belt. Worked perfectly. The system had a full charge, but the clutch is shot, and on initial investigation the compressor seems like it might be ok. Will check further but think I might try just replacing the clutch when I can. Everyone seems to say that issues with the compressor most always cause the clutch to go bad, but I am wondering if there are exceptions? The Durango has sat idle in the driveway a lot this year, sometimes for weeks at a time, in upstate NY weather. Could that be a factor? There is evidence of rust on the ac clutch assembly, but don't know if it was there before it failed. What do you think?
J440Cuda is offline
post #9 of 10 Old 04-11-2014, 02:59 AM
MikePK
Will this work without removing the compressor? If so, what size is the belt?
MikePK is offline
post #10 of 10 Old 09-04-2014, 02:03 AM
Awheeler040186
Vehicle: 2003 Durango SLT 4X4
4in shorter belt worked great even though dumb auto part guy said it never would
My compressor went out and i had to take the compressor off in order to be able to bypass it with a 4in shorter belt but it did work and if I had my proper tools with me to pull just the pully it would have worked without removing the whole thing but its running and sounding great again for a 2003 dodge Durango SLT 4x4 with 290,000 miles on it
Awheeler040186 is offline
