4 wheel drive wont enguage - Dakota Durango Forum
Off-Roading Equipment 4x4 Gear, Winches, Nerf Bars, Off-Roading Chatter.
post #1 of 7 Old 01-04-2012, 06:54 AM Thread Starter
JAnselmi
Vehicle: 2001 Dakota Sport
Modifications: 3 Inch PA Body lift, In Dash DVD
i just replaced the shift motor....but now its still not working....what could it be??? could it just be the switch itself! im at a loss help!
2001 Dakota quad cab-3 inch PA lift, in dash DVD,305/45/22 wheels/tires, lots of time spent in color matching parts, way way more to come....
2001 kawi ZX7R-for speed and speed only
1997 dodge neon-work car used to keep mileage off my truck
JAnselmi is offline
post #2 of 7 Old 01-10-2012, 04:59 AM Thread Starter
JAnselmi
no one has any information?
JAnselmi is offline
post #3 of 7 Old 01-10-2012, 05:33 AM
01dodgedakota
Vehicle: 01 dakota
could be the switch itself if its electric shift
01dodgedakota is offline
post #4 of 7 Old 01-10-2012, 10:25 PM Thread Starter
JAnselmi
thats what i may be thinking, i mean the motor itself was just replaced...no blown fuses or nothing...so maybe its the switch
JAnselmi is offline
post #5 of 7 Old 01-11-2012, 12:38 AM
01dodgedakota
Vehicle: 01 dakota
also im not sure about how these are but i know on my ranger there was a wire that went from the shift motor to inside the tcase(had to be cut to remove shift motor) but i believe it was a ground and it wont work if its not hooked up
post #6 of 7 Old 01-12-2012, 12:20 AM
caulk04
Vehicle: none
Turn the ignition on, move the switch and listen. Do you hear anything?
Yes? Internal t-case issue.
No? Start at the shift motor and work backward until you find the issue.
caulk04 is offline
post #7 of 7 Old 01-25-2012, 02:43 AM
HartBK23
HartBK23's Avatar
Vehicle: 02 Dakota QC Sport 4X4
Modifications: Check out my garage
Garage
I don't know if you've found the problem yet, but if your switch was working perfectly fine and just quit engaging, it might be your TCCM (transfer case control module). If your transfer case switch doesn't light up when you start the truck or when your driving, its most likely a bad tccm. It's basically a computer that can tell if your truck is ready to make a shift into 4X4 or not. It's located way up under the dash and you can pick one up at a scrap yard for around 150$ or order it new from the dealer for 400$. Mine went out on my 02 QC Sport after I replaced the throttle position sensor and disconnected the battery.
-Riley
4.7L V8, Superchips 3865, and a bunch of others. Just look at my garage.
"When people say I drive a small truck, I simply respond that I'm compensating for my large penis."
HartBK23 is offline
