Pic request, 97-99 kota filler neck - Dakota Durango Forum
post #1 of 17 Old 12-14-2011, 02:33 AM Thread Starter
6shooter
Resident Craigslist Whore
6shooter's Avatar
Vehicle: One with a bowtie
Could someone get me a pic of their non-Cali emissions truck's fuel filler neck/lines from the tank to the base of the filler neck??
I have to replace the fuel filler neck on my 98 Dakota, and according to the dealer and the last 9 of my vin, I have a truck with California emissions. The dealer says the fuel filler neck is different than those with normal emissions although all the ones I see online for sale look just like mine. On mine it appears that the rubber section from the filler to the tank is actually crimped on to the neck and has quick disconnects at the tank for the vent and fill tubes. I thought on all my other daks that the rubber parts were just hose clamped on, but could be mistaken. Some help would be appreciated! I bought one from amautoparts on ebay that listed as 97-99 dakota (excl. 99 with california emissions). it said nothing about 98's with cali emissions, so i figured hell with it, I can probably make this one work if I have to.
Hi, my name is Brad, and I have an addiction to Dakotas.
6shooter is offline
post #2 of 17 Old 12-14-2011, 02:44 AM
Misfit
We Are 138
Misfit's Avatar
Vehicle: 98 Dakota V6 & 03 Cobra
Modifications: CAI,Xhaust,Flux Capacitor
Quoted: 20 Post(s)
Garage
Hold on a sec..
Misfit is offline
post #3 of 17 Old 12-14-2011, 02:45 AM
Misfit
We Are 138
Misfit's Avatar
Quoted: 20 Post(s)
Garage
I had to crop it and shit, otherwise you couldn't really see it too good. Maybe this helps, it's all I got.
Misfit is offline
post #4 of 17 Old 12-14-2011, 02:50 AM Thread Starter
6shooter
6shooter's Avatar
thanks man, that's helpin. It looks so far just like the one I have... other than the fact that yours isn't crumbling into pieces when the wind blows the wrong way lol. Do you happen to remember if the rubber hoses are clamped or crimped onto the steel neck?
6shooter is offline
post #5 of 17 Old 12-14-2011, 02:55 AM
Misfit
We Are 138
Misfit's Avatar
Quoted: 20 Post(s)
Garage
I want to say they were clamped, like big ass hose clamps. But I'm not 100% on that. This was my last Dakota, I don't have it anymore, so it's not still tore apart in the driveway where I could just walk out and check it.
Misfit is offline
post #6 of 17 Old 12-14-2011, 02:57 AM Thread Starter
6shooter
6shooter's Avatar
ok man, thanks for the help so far tho!
6shooter is offline
post #7 of 17 Old 12-14-2011, 02:59 AM
Misfit
We Are 138
Misfit's Avatar
Quoted: 20 Post(s)
Garage
I looked, but that's the best picture I have of the filler neck. All the others is something obstructing direct view to confirm clamped or crimped. sorry man.
Misfit is offline
post #8 of 17 Old 12-16-2011, 02:27 AM
Rahhstah
Rahhstah's Avatar
Vehicle: 1997, Dodge, Dakota CC
Modifications: M1 Intake, 1.7rr, Gibson SS Headers, CAI, eFan, 360 swap, 46re swap.
Quoted: 7 Post(s)
My 97 appears to be crimped on / compression, it's not a hoseclamp that could could be removed easily.. I took some pics, but, idk what i did with a USB cable for it. I'll add pics when I find the cable.
pics aded
Rahhstah is offline
post #9 of 17 Old 12-16-2011, 02:41 AM
NUF SED
Vehicle: 99ccbeast
Had to cut mine outon my 99 and put new one back with hose clamps, no pics tho
NUF SED is offline
post #10 of 17 Old 12-16-2011, 05:06 AM Thread Starter
6shooter
6shooter's Avatar
thanks for the help, guys. the filler neck should be here saturday, so I'll see how it goes.
6shooter is offline
post #11 of 17 Old 12-23-2011, 07:37 PM
ehrenb
Vehicle: 1998 Dodge Dakota
hey let us know how this goes... i've gotta do the same thing on my '98. not looking foward to it but it's gotta be easier than the water pump and harmonic balancer I just did... right? lol
ehrenb is offline
post #12 of 17 Old 12-23-2011, 10:25 PM Thread Starter
6shooter
6shooter's Avatar
Well, got it in. I had to carefully cut away the outter crimp rings and remove the hose from what was left of the original filler neck. On mine, it looked like the tubes were a little long anyway, so I cut about an inch off each hose, leaving enough of the flat part to hose clamp around. I slid the hoses on the metal tubes and left them loose, installed the upper flange with the screws, then clipped the tubes back into the tank. I then took and adjusted the hoses to where they weren't too stretched, but not too loose, and had plenty of meat to clamp on. She's good to go now.
6shooter is offline
post #13 of 17 Old 12-23-2011, 10:38 PM Thread Starter
6shooter
6shooter's Avatar
I just did the water pump in mine, too. Worst part about that is the top 1" hose thats buried underneath the accessory drive bracket. Shitty part about mine is the pump was almost new looking at the fins, but the seal went out and was leaking out the weep hole so I had no choice.
6shooter is offline
post #14 of 17 Old 12-23-2011, 11:16 PM
ehrenb
thanks for the info.
ehrenb is offline
post #15 of 17 Old 04-13-2012, 07:49 PM
knameerf
Vehicle: 1997 Dodge Dakota
Yoooooo 6shooter will be ordering the pipe tonight but was wondering how you gently removed the crimpted clamp... does the two hoses as they got to the tank can they be simply unscrewed they both turn and the smaller w/ a clicking sound and the other main moves somewhat easy... should I attempt to unscrew them to more gingerly take of the crimp? Or anyone else care to reply eh?
knameerf is offline
