Front end Humming Noise - Dakota Durango Forum
post #1 of 6 Old 12-06-2011, 11:50 PM Thread Starter
Irrenhaus
Vehicle: 2002 Durango Sport
Hello:
I know this may have been ask before but. I have a humming noise in the front end of the truck is louder at lower speed but not at higher speeds.
I replaced the inner and outer tie rods recently and also installed new disk rotors no new pads, the old ones were still more than 50% good and thats when the humming noise started. I have replaced the wheel bearings last march and ball joints last summer. Tires are almost new. I lifted the truck on both sides and spin the wheels and I do not feel any griding or vibration the only thing I hear is the break pads scraping a bit on the rotors.
I do have a clonking noise on the steering colum when I move the wheel from side to side in park about 2 inches, but it is the Intermidiate Shaft that needs to be replaced. It is on order already.
Its a 2002 Durango, 4.7 2WD with about 156000 miles on it.
Any suggestions.
Irrenhaus is offline
post #2 of 6 Old 12-06-2011, 11:58 PM
ramayer
ramayer's Avatar
Vehicle: 1999 durango (5.2L)
if you replace the rotors, you should always replace the pads...my guess is the pads are chattering on the new rotors.
mods: Functional ram air hood, 17" rt rims, 3" Magnaflow cat back, Eddy shorty headers,JBA y-pipe, RHS indy heads, 1.6 RR, comp cam .480 lift, MP valve springs, Comp cams double roller timing set, modified kegger intake, TB by Dwight, Grille craft inserts, Infinity Reference speakers all around with 10" Infinity sub in custom fibreglass enclosure, flip down DVD.
ramayer is offline
post #3 of 6 Old 12-07-2011, 12:26 AM Thread Starter
Irrenhaus
Okay thanks, I do have a brand new set, I will put them in tomorrow morning.
post #4 of 6 Old 12-07-2011, 01:55 AM
ramayer
ramayer's Avatar
while you have it jacked up before you pull the wheels, try checking the wheel bearings also. grab the wheel at 12 and 6 O clock and check for any movement...it may be a bad wheel bearing also.
ramayer is offline
post #5 of 6 Old 12-07-2011, 01:55 AM
ol' grouch
ol' grouch
Vehicle: 1992 Dakota, 2001 Ram
Garage
Originally Posted by Irrenhaus View Post
Hello:
Any suggestions.
Maybe it's humming because it doesn't know the words.
Sorry, I'm tired and my sense of humor comes out at odd times. Swapping rotors and reusing worn pads, even slightly worn can cause this quite often. If that doesn't take, try rotating your tires front to back.
Practicing curmudgeon.
2001 Dodge Ram 2500 4X4, 1998 Furd Taurus, 1982 Mercedes 380 SL, 2005 Kawasaki Concours and last but not least, 1992 Dakota 4X4.
ol' grouch is offline
post #6 of 6 Old 12-07-2011, 04:31 AM Thread Starter
Irrenhaus
Ohh don’t worry I am thankful for the help. I have already went thru bad wheel bearings, cmon is a Durango, now the replacement were not timken bearings so that can be a problem. The truck is park now until I solve, this but I will replace the pads in the morning do a quick test drive and if the noise is still there new wheel bearings it is.
I will post the findings.
And again thanks for the help.
Cheers
