Engine Overheating/Heater Blowing Cold Air - Dakota Durango Forum
post #1 of 3 Old 11-12-2011, 05:52 AM Thread Starter
Davezilla
Vehicle: 2002 Durango SLT 4.7L
I have a 2002 Durango SLT 4.7L with approx. 84,000 miles. A few months ago I had a problem with the engine overheating. I took it to a repair shop, that checked it out & changed the thermostat. That solved the problem for a few months, but within the past 2 weeks I have started having problems with overheating again, mainly in stop & go traffic or city driving while at stop lights. Yesterday I had a coworker mention that my engine sounded like a jet engine. I left the engine running, opened the hood, and stood in front of the vehicle. There was a definite whine that sounded like it was coming from the front of the engine, but I couldn't isolate where in the parking lot at work. In addition, today the heater would intermittently blow only cold air. When it was blowing cold air the engine would overheat. After a few minutes with the heat & fan set on high in the defroster mode, it started blowing hot air again & the temperature gauge dropped back into the normal range. Before this incident with the cold air I thought it was the water pump, but now I'm not sure. Does anyone have any suggestions about what this could be?
Davezilla is offline
post #2 of 3 Old 11-12-2011, 06:51 AM
BrandonBurns85
BrandonBurns85's Avatar
Vehicle: 1999 Dakota R/T
yes sir i know check your coolant level!! same EXACT thing been happening to me and i was way low on coolant dunno where it went but it wasnt all there. lemme know if you need more help/info. i drained what was in it today filled with fresh water let it run awhile then drained all of that... let motor cool filled back up with water and a bottle of peak coolant flush and tonight driving home from work blasting heat and didnt overheat once tomorrow ill drain and fill with proper amount of coolant and water...
also our heater cores are notorious for clogging so get a garden hose adapter and flush both side of the heater core out u be surprised what comes out
Making Big Brake kits for 1997-2002 Dakota-Durangos 2x4-4x4
1996 and earlier Big Brake kits on the way
BrandonBurns85 is offline
post #3 of 3 Old 12-12-2011, 09:59 AM
mitch138
Vehicle: 1998 Dodge Durango SLT
timing belt cover gasket.
mitch138 is offline
Gear in this thread - Powered by O'Reilly Auto Parts
