5-Speed Manual Trans for 5.9 Magnum?Whats needed? - Dakota Durango Forum
post #1 of 26 Old 10-26-2011, 04:44 AM Thread Starter
porksoda
Dakota GOD!!!
porksoda's Avatar
Vehicle: 1998 Dodge Dakota 5.2L
Modifications: working on my truck and playing with my saltwater fishtank.
Send a message via MSN to porksoda Send a message via Yahoo to porksoda
Question 5-Speed Manual Trans for 5.9 Magnum?Whats needed?
Well I am trying to get some info for a friend of mine.
He has a 1st gen Dakota that he is building a 5.9L Magnum. He wants to put a manual transmission in it though.
My question is what transmission should bolt right up?
I heard that the 5-speeds from Dakota's will not work. Is that true?
He has a 5-speed manual trans he pulled out of a 3.9L Dakota in the past.
We are wondering if there is anyway to make that work with the 5.9?
If that doesn't work what should we start looking for?
Well thanks a lot guys!
1998 Dakota Sport Painted Viper Red!
Its a work in Progress. Some day it will be a nice truck!
porksoda is offline
post #2 of 26 Old 10-26-2011, 05:06 AM
01dodgedakota
Vehicle: 01 dakota
if its the nv3500 it'll work i believe, i wouldnt try it with the older ax15 trans
01dodgedakota is offline
post #3 of 26 Old 10-26-2011, 05:30 AM Thread Starter
porksoda
Dakota GOD!!!
porksoda's Avatar
He has the AX15 Trans .
So the options are NV3500? Anything else?
What can they be found in?
porksoda is offline
post #4 of 26 Old 10-26-2011, 06:56 AM
01dodgedakota
Vehicle: 01 dakota
i believe the ax15 will bolt up i just doubt it'll handle the 360s power especially if its not stock
post #5 of 26 Old 10-26-2011, 11:58 PM
1999BLKDAKRT
Vehicle: 1999 DODGE DAKOTA R/T
Modifications: SHAKER HOOD, 51.5 BLKDAK TB. HEADERS, MOPAR PCM, 100 SHOT ZEX WET KIT.
Got to Car-part.com select usa, southwest region, 1994 dakota, transmission and pick 4x2 318 from the menu and you will find 2 in texas. These should be the nv3500. Appears that 94-96 are the same and then 97 up is the same, my guess is the sensors are different between the years.
1999BLKDAKRT is offline
post #6 of 26 Old 10-27-2011, 12:13 AM
NoStopN
Got out of Dodge.
NoStopN's Avatar
Vehicle: No-kota
Send a message via Yahoo to NoStopN
I'm sure some Rams came with the 360/5-speed combo. I'm not sure if they are NV3500s. New Venture also built the 4500, but that may have been for the V10 & Cummins.
2002 GMC Sierra reg. cab stepside.
NoStopN is offline
post #7 of 26 Old 10-27-2011, 12:16 AM
01dodgedakota
Vehicle: 01 dakota
i believe the 360 had the 4500
post #8 of 26 Old 10-27-2011, 01:02 AM Thread Starter
porksoda
Dakota GOD!!!
porksoda's Avatar
So will a transmission from a 318 work on a 360?
porksoda is offline
post #9 of 26 Old 10-27-2011, 02:21 AM
jmaack727
"][" {[]} {[]} ][_
jmaack727's Avatar
Vehicle: 2 of em.
Yes just use a 360 flywheel from a 94 1500 ram. Or a 3/4 ton ram eith gas engine and manual trans. Its the same.
jmaack727 is offline
post #10 of 26 Old 10-31-2011, 06:46 AM
modain
I drive with two feet
modain's Avatar
Vehicle: 2002 Dak QC, 2001 Durango
Modifications: Superchips 3715, no chrome, R/T rear sway bar, Monroe Reflex shocks
The Magnum 3.9, 5.2, 5.9 engines and the 3.7, 4.7, 5.7, 6.1 engines all have the same bell housing pattern. The any tranny that fits one of them will bolt up to any of the other ones. For the 5.9 engine you'll need an externally balanced flywheel.
Tranny strength is an item you'll need to settle - just because it'll bolt up doesn't mean it will hold up. There have been a number of people running an NV3500 behind TC'ed and SC'ed 4.7s, and even behind a 5.9 with good results.
Do some searching on Jeep forums. Some guys are putting out much more than stock power through their trannies. The AX-15 put behind the 4.0 engine is the same AX-15 used on Dodge 3.9 and 5.2 trucks. Of course, with a different bell housing.
2002 Graphite QC SLT Plus, 4.7L, NV3500, Superchips 3715, HO Cams, 2003 Intake Manifold, Dwight's 65mm TB, 3.92 LSD, R/T rear swaybar, no chrome
2001 Patriot Blue Durango SLT, 4.7L, 545RFE, Superchips 3715, Fastman 68mm TB, Jeep GC TCM, R/T rear swaybar, 3.55 Open (for now)
1999 Forest Green Dakota RC Sport, 2.5L, NV1500, Jeep 4.0L TB, 3.92 LSD
modain is offline
post #11 of 26 Old 10-31-2011, 06:58 AM
01dodgedakota
Vehicle: 01 dakota
read my 2nd post i said i believe it'll bolt up but i didnt think it'd hold up to a modded 360s power
post #12 of 26 Old 10-31-2011, 11:35 PM
Moparman897
Moparman897's Avatar
Vehicle: 02 Quad Cab, 92 RCSB
[porksoda;2864316]He has the AX15 Trans .
What can they be found in?[/QUOTE]
3.9 rams actually had NV3500's too. That's what I got mine out of.
Moparman897 is offline
post #13 of 26 Old 11-04-2011, 12:27 AM
The G.O.A.T.
Vehicle: 1993 Dodge Dakota
Don't I need to stick 2 a 2wd tranny if am swapping into a 2wd, and same for 4x4 of does it matter?
Also what years of Nv3500 would work on a 93?
Sorry for the thread jack
The G.O.A.T. is offline
post #14 of 26 Old 11-04-2011, 02:53 AM
fastdak
eat cheese or die!
fastdak's Avatar
Vehicle: 2001 Dodge Motorsports
Garage
There are 2 versions of the NV3500. There is the NV3500 HD too. It can handle a little more torque.
RCC member # 74. 2001 Dodge Motorsports Limited Edition. 1 of 13
blk. rc. 4.7l. 5 spd. 3.92 lsd. K&N FIPK. Lakewood traction bars. ARE hard cover with wing. Line X bed liner. Superchips tuner. best 1/8 E.T. 9.653 @ 73.32 best 1/4 E.T. 15.063 @ 90.94 mph. 10/28/05 at Great Lakes Dragaway.
fastdak is offline
post #15 of 26 Old 11-04-2011, 06:38 AM
The G.O.A.T.
How do I tell the difference? Or are there specific years and models I need to look for?
